Question about Nintendo DS Lite Console
I have just changed the top screen and now when i turn it on the screen flashes and turns off
    President:
  • 1,139 Answers
Depending on which screen flashes tells you which screen is faulty. If the screen you have just changed flashes then it is the bottom screen that is faulty. However I have known the DS to be rather sensitive when it comes to connections. Take the DS apart again and reinsert the ribbon cables that connect the screens to the motherboard. This will hopefully correct the problem.
Hope this helps.
Posted on Aug 01, 2010
I had exactly this problem after replacing the top screen on a DS Lite. The problem was that I had not seated the top screen's ribbon cable deeply enough in the connector. Once I set it deeper, the unit worked.
Posted on Sep 06, 2010
How do you turn the flash off on a hp photosmart 435 camera
Hi hookerglen.
NOTE The flash does not work while recording video clips.
To change the flash setting, press the Flash button on the top
of the camera until the desired setting appears on the Image
Display. The camera remains in the current flash setting until
you change it or turn off the camera.
please fellow the instructions in the picture bellow aid you use your hp cameras flash light better.
let me know if it works for you.
Thanks.
May 11, 2011 | Cameras
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
The time is flashing on the screen and it continues to flash. Can't turn on the unit, change time, etc? It's like it is locked out somehow.....do I need to push a couple of different buttons to turn it on?...
Check the red key protect button on the front top left of the radio. If it is activated there will be a key icon on the screen. Press it once to deactivate it & the key icon should be gone & the rest of the buttons should work.
Nov 19, 2009 | Sony Walkman SRF-M70 Radio
Timex 1440 sports watch. How do you turn off the chime on the hour every hour?
Hi aburns983,
You can easily change the time and turn off the chime of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Nov 05, 2009 | Timex 1440 Nylon watch
I recently got a new HP lap top running windows vista.
I just did a service call with a similar situation . That person had the same problem , it was a virus, I had to re-install Windows.
Sep 11, 2009 | HP Pavilion dv4000 Notebook
The bottom screen flashes on and then turns off
This is a typical top screen fault.
If when you try to power on the top screen flashes. and the system immediately powers of then its the bottom screen fault, and visa versa.
If you are lucky it may be the zif connector connecting the ribbon cable to the motherboard, but its 90% probable that you need to replace the top screen. these are available on ebay. Watch lots of youtube tutorials before attempting this because its quite tricky and easy to damage the new top screen wifi speakers and mic ( connecting the new cable properly is quite difficult the first time.)
Best of luck.
If u live near wolverhampton i will do it for a tenner ... pete.
Aug 13, 2009 | Nintendo DS Lite Console
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Turn on, verizonwireless shows for 3 minutes, then screen flashes
I figure I need to reload the software but what do I know? The screen flashing occurs on top of the verizonwireless title page. Charging it didn't help. I have to take the battery out to turn it off.
Jun 07, 2009 | Motorola Mobility Moto Q
Flashing Light and Ringer
flashing light means ur phone is turned on and working properly and go to ur profile menu then click for personalised then change for ringer type
Mar 13, 2008 | Lands Phones
Turning off the flash
This camera has four flash modes and each time you press the button the mode changes. As you press the button you should see the indictor in the upper left side of the screen.
1. In automatic flash, the camera will decide if you need flash or not. This mode does not have any indicator on the screen
2. Forced flash, this will cause the flash to be constantly on. The indicator looks (kind of) like a lightning bolt.
3. Slow Syncro, this mode slightly delays the flash and is used to lighten up the background more the foreground. The indicator looks like the lightning bolt with SL next to it.
4. No flash, this will turn off the flash. The indicator looks like a lightning bolt enclosed by a circle with a diagonal line through the lightning bolt. (similar to a no parking sign).
The mode you want is the circle and diagonal slash over the top of the lightning bolt.
If you don’t see the indictor changing on the screen the switch behind the button is malfunctioning.
Dec 27, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Nintendo DS Lite Console Logo
248 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
