Question about HP Pavilion dv8230us Notebook
Pavillion dv8000 increase resolution
What exactly do I need to buy in order to enhance the resolution of this laptop?
More video memory? what kind?
another video card? isn't it part of the main board?
Thankyou
  • joe68 Apr 27, 2008
    thankyou my mind is in peace now...How come this great laptop is enclosed in a such poor resolution...
    God forgive them for they do not know what they are doing...
    Scholar:
  • 103 Answers
You cannot upgrade the video card on this model without replacing the motherboard. Even if you did, you would have to verify that the LCD could also handle the resolution you desire.
Posted on Apr 24, 2008
I have an LG W3000H which should be able to get excellent resolution (2560 x 1600). But, I'm only getting 1280 x 800. And, I can't increase the resolution any further. I'm using a Dell latitude 6410...
The limit is due to your video card in your computer, did you try to install the monitor driver on your lap top for this monitor since it needs the inf file for the computer to know what kind of resolution this monitor can support. You also may not have enough memory for the video card since it is shared memory with the CPU.
Oct 01, 2010 | LG W3000H-Bn Monitor
Where can I buy a lower price HP PAVILION DV8000
It's much better to buy the battery from the manufacturer's website. The transaction is a lot safer and reliable. Take there are two categories of battery the ORIGINAL and REPLACEMENT. Normally the highe mAh capacity has the longer battery life. The price of REPLACEMENT batteries are much lower than the ORIGINAL batteries.
You can view the product on this site:
http://www.shopping.hp.com/webapp/shopping/product_detail.do?product_code=EF419A
Thanks.Cheers!
Apr 21, 2010 | HP Pavilion dv1000 Notebook
My hp dv 8000 Pavillion laptop will turn on and then it immediatly shuts down after 5 seconds or so
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
and if this doesn't help
then try to take out the ram or memory chip from the computer and place it back.
Jan 12, 2010 | HP Pavilion dv8000 Notebook
Acer laptop 2310 series, 5yrs old 40 GB HDD; 256 MB DDR.Windows XP. Can i add more memory & if so how much?
Yes you can. You can increase the memory up to 1GB. If you are going to keep the memory inside then you should buy a 512 MB memory card, making your computer run on 768 MB of memory. If not then replace it with a 1 GB memory card. Remember, this computer can only support a maximum of 1GB total memory. The price depends on the memory module. The higher it is, the higher the price will be. Go to your local computer store for the price.
Dec 19, 2009 | Acer TravelMate 2300 Notebook
Cannot allocate hypermemory
I've noticed that in the bios you can't increase Dedicated video memory because the max for your laptop is 256 but if you check your overall video memory with the shared memory added on by right clicking on your desktop and clicking screen resolution, go to advanced settings, and it should show your adapter with the amount of total graphics memory, the dedicated video memory (video memory of video card), system memory(Mine is 0), and shared video memory ( Ram being accolated together with the graphics card making more video card memory in all). If you switched to XP however, you will probably have less video card memory. Everything should be fine if your on your laptop's default operating system (Mine is windows 7 home premium).
Oct 19, 2009 | Acer Computers & Internet
Dv8000 not charging, flashing lights
its the motherboard. hp is aware of this issue. please visit their site and type in your model number there has been release a limited service enhancement to replace motherboards affected by this. there is another solution that has worked somewhat, which is to update your current bios to the most current and then go into your device manager and unistall the microsoft acpi-compliant control method battery under batteries there. i have found that to work often, in the event it does not you should really try the enhancement warrant, i sent out 2 units today for that same problem
good luck!
ruben
Jul 15, 2009 | HP Pavilion dv8000z Notebook
Screen gone wild
If your external video is working, most likely your VGA controller is good. Your laptop is using the same controller to control internal and external video. It could be two things that would cause your problem:
1. LCD VGA cable that connect your LCD to the laptop
2. Bad LCD VGA connector on the board(cold soldered joints)
3. BAD LCD panel
Any of the following repairs will require disassembling of your laptop.
Regards
May 27, 2008 | Acer Aspire 4520-5582 Notebook
Limited video shared memory 64mb
Hi icr
You better try to increase the virtual memory of your system as seems you would nt be able to increase the pre allocated video memory to your video device.
The virtual thing you can do by going to the my computer's properties and then in advanced tab you find performance options .Here you can tweak your virtual memory accg to your systtem memory
Waiting for your appreciation
Feb 15, 2008 | HP Pavilion dv1000 Notebook
Cannot change resolutions.(monitor)
This could be caused by a variety of problems:
1. The video/graphic card does not support that resolution because:
a. it does not have sufficient display memory (at least 2 or 4 megabytes is requiered, if you don't have this amount buy a new video card)
b. the video card driver has not been installed properly or is corrupted (reinstall the video driver)
2. The monitor does not support 1024x768 resolution
Change your resolution, follow this procedure:
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx?mfr=true
Please provide your entire system specifications, including the monitor.
Dec 21, 2007 | Intel D915PCM Motherboard
HP Pavilion dv8230us Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
