Question about Stihl Chainsaw Cutoff Saw Flywheel 08 S Ts350 P835
TS350 saw , no spark, replaced ignition mod. and still no spark ? Thanks
    Problem Solver:
  • 14 Answers
Hi make sure you On/off switch is good as mine screwed up after 2 weeks because of the dust and dirt. Check your plug wire also for resistance if you didn't get a new one with the module. But I would check the new one anyways so you don't keep pulling off your flywheel. Jim
ps make sure it's still magnetized.
Posted on Sep 22, 2012
  • 45 Answers
Clean flywheel and check coil try new plug
Posted on Sep 09, 2010
How do I gap ignition module on a TS350 Stihl concrete saw?
I thought the unit was under the flywheel, in this case there is no gap to set it just screws to the crankcase and you re fit the flywheel.
Sep 18, 2012 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Need repair manual for stihl ts350 super
Download Link:
This service manual contains detailed descriptions of all the repair and servicing procedures specific to this power tool series.
1.stihl ts350 parts manual
There are separate handbooks for servicing procedures for standardized parts and assemblies that are installed in several STIHL power tool models. Reference is made to these handbooks in the appropriate chapters in this manual. As the design concept of models FS 120 FS 200 FS 300 FS 350 FS 400 FS 450 and FR 350, FR 450 is almost identical, the descriptions and servicing procedures in this manual generally apply to all models.
2.stihl ts350 parts service manual
Jul 05, 2012 | Saws
What gas to use for TS350
Gasoline cut-off saws are a simple and extremely robust tool that will easily last for many years if treated with respect and maintained regularly .
During normal operation it is absolutely imperative that the correct fuel/oil mix is always used. An incorrect mixture leading to a lack of lubrication is by far the easiest way to ensure an untimely death for your cut-off saw.
Here's a list of regular cut-off saw maintenance tips that will keep your machine running and running:
Jul 20, 2011 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
I have a stihl ts350 cut off saw and if i put fuel into the carb choke flap opening it will start and run for a few seconds then dies like it ran out of fuel i have took the carburater apart and cleaned it...
Hi and welcome to FixYa. I am Kelly
You are going to have to rebuild your carb and get a
GASKET & DIAPHRAGM KIT
  • TILLOTSON DG-2HL/DG-5HL
  • Fits all HL model carburetors
One of your many diaphragms or gaskets is leaking even though it is clean all it takes is a pin hole to cause havoc!
This link provided as a picture reference only:
http://www.gardenhirespares.co.uk/product/173
http://www.gardenhirespares.co.uk/images/1100_orig_listing.jpg
US source for the same kit:
http://ssl.jackssmallengines.com/jacks-checkout/shopping-cart.aspx?CFID=179837&CFTOKEN=92541317
Make sure to download this 8 page manual to help you with the carb repairs:
http://www.tillotson.ie/docs/techinfo_HL_US.pdf
Just make sure you have good fuel flow to the carb fuel inlet from the gas tank with a good rate of flow.
When you finish it will work great if you did it properly. You will for sure have to adjust the fuel mixture screws after the re-build.
Thanks for choosing FixYa,
Kelly
Mar 30, 2011 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Ts 360 no spark
The problem could be with the kill wire grounding out on the housing or the ignition coil could have gone out. Take out the spark plug and dis connect the kill wires off of the coil. NOTE: If you do not take out the spark plug to test for a spark then you run the risk of the unit starting up and not being able to shut it off. With the spark plug out of the engine and the kill wires dis connected. Put the spark plug boot on the spark plug and rest the spark plug on the engine (anywhere there is bare metal from the cylinder is O.K.) pull on the recoil starter and see if there is any spark present. If there is still NO spark present then you need to replace the coil. If there IS spark then you need to replace the kill wires with a new set.
Mar 29, 2011 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Why won't my Stihl TS350 Cutoff saw go to full revs? It starts well.
I would inspect the intake side of the piston behind the carburetor. The most common problem with cutoff saws with no water kit is fuel reversion. that is wear on the intake side of the piston that has removed over 10% of the machining marks like this:
If you do have wear like this consult a Stihl Gold certified dealer like www.arcolawn.com for parts and tools to repair it.
Good Luck
Dec 11, 2010 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
I have a Stihl TS350 demo saw that a family member gave me. I used an inline spark tester and it's getting a week spark at tester, but nothing at the plug(old or new plug). I took off the flywheel, and it...
TS350's got electronic ignition after serial number 13927613 early 1985 - yours must be earlier than this, possibly European specification. Before messing with the point gap, try cleaning the contacts with 'wet and dry' type abrasive paper....tear off a strip and fold double along long edge so that abrasive is on both sides (you could use a fine nail file/board) and pull through closed points so that it cleans up the oxide coating that builds up through non use. Finish off with a dab of electrical cleaner or similar 'safe' solvent (brake and clutch cleaner) and maybe a shot of air.
Nov 04, 2010 | Garden
I have a stihl ts350 demosaw I'm not getting any fire
Follow the two wires and look for scuffs broken or worn insulation. Sometimes easy to find by turning off the garage lights and pulling the rope (arcs can be seen easier this way). The wires use common ground to kill the spark through the switch. These wires are known to wear through the insulation after years of use and they inadvertantly ground out the ignition coils. Repair the wires with heat-shrink tubing or electrical tape as needed. Or replace the wires entirely if they are in very poor condition.
Hope this is helpful,
Dolf-
Nov 10, 2009 | Garden
One burner will not spark for ignition.
The spark mod. needs to be replaced again. Check and make sure that the wires are connected to it good though and that they have a good connection. If all looks well though you will most likely need to replace that spark mod. again. Let me know if you have any other questions and if this was helpful. Good luck.
Jan 22, 2009 | Viking VGIC485-6G Gas Kitchen Range
Stihl Chainsaw Cutoff Saw Flywheel 08 S Ts350 P835 Logo
840 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
rlev_7
Level 1 Expert
Spud Howell
Are you a Stihl Saw Expert? Answer questions, earn points and help others
