Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
The filter wasn't changed for a couple of weeks and lots of leaves fell in our pool, I changed the filter put more salt but the pool water is getting greener and greener every day, what can I do? Intex Krystal clear, salt water CG-56601. I thought of shocking it but don't want to put chlorine in as daughter is allergic to it.
  • Intex Master
  • 8,404 Answers
Shock your pool ... take it to about 20 ppm and run the filter 24 hours a day. Brush the sides. When the pressure goes up 10 lbs over fresh start pressure, backwash or clean your cart as appropriate. Is your salt cell calling for more salt? Salt is persistent in the water (like CAL, salt doesn't just go away. The only way you loose either is by splash out and/or backwash.) If you dont know the level and your cell will not tell you, get tghe level checked at your pool place. You should have around 3200 ppm salt. Dont expect your salt system to keep up with the green stuff when the green stuff is established. You MUST use dry or liquid CL to overcome. You MUST brush the pool sides and bottom. You must run the filter 24 hours.
Between the green stuff and the sun, the CL your cell is making is consumed almost as fast as you make it.
Get your Cyanuric acid level to 80 ppm.
I hope this helps you ... Thanks for your interest in FixYa.com
Posted on Aug 01, 2010
Two weekends ago I came back from a 4 day trip to a green stincky pool. Low flow, we cleaned the filter and scrubbed the algae, by morning a beautiful sight. Yesterday after not look at the pool over the...
You should definitely shock however the best solution for solving an algae problem, which is what you have, is using a product called
Algimycin 2000
this will clear up your pool in about 24 hours
US Parts Center
Aug 18, 2011 | Intex Automatic Salt Water System for ...
We have a 18x48 ultra frame intex pool. It at first gave us a lot of problems saying low salt so we cleaned the cell with vinegar and it began working no probs for the past 3 weeks. On the weekend I went...
I can't explain all of this but to get the rid of the green and reduce the salt level you need to drain half the water and refill. At this you need to shock it so the chlorine is up to about 10 ppm. You need some way of testing to tell this. If your chlorinator is ok then when you start the pump and chlorinator it should continue cleaning it out. The dead algae will be filtered out with the filter. If the flow slows down you will need to clean the filter with a water sprayer on a hose. I hope this helps.
Aug 09, 2011 | Intex Automatic Salt Water System for ...
Hi, I have let my intex above ground pool go green over winter and with summer approaching don't know if I need to add extra salt or something else to get the pool ready for swimming. It is a 14 foot,...
You need to get liquid chlorine and add about 2 liters and let your pool filter run for a couple of days and in the mean time clean your filter twice daily. If the pool at this stage is still a little green add more chlorine and broom the bottom to stir it up. After this as once your pool is back to almost normal, clean the the filter again and add clarifya. To keep your pool in good condion over summer buy 2 pool floaters, put 2 chlorine tablets in one and blue block pool sparkle in the other and each week add 1 liter of chlorine. Hope this helps you as i have the same pool and i do this and don't have any problems. You can also add salt to your pool if you like but dissolve it in water before you add it to the pool.
Oct 25, 2010 | Intex Automatic Salt Water System for ...
We put a salt system in in March of 2010, and starting in August, have had problems with black residue forming on the sides of the pool and bottom. The light is crusted with a blue green substance that...
Well what your describing should have nothing to do with whether it's salt or not. What your describing is a bad algae problem. Only so much can be done without actually seeing the pool. Depending on how well you are maintaining your chemicals, and what chemicals you are putting in the pool lots of things can happen. The blue green that wipes right off sounds like algae. The black can also be algae, or if the PH has been too low in the past, then metals can dissolve into the water, and when PH goes high, then metals come out of solution and leave black or brown staining. High calcium also leaves white, tan or brown staining depending on the chemistry of the water. removing stains from vinyl pools can be difficult to impossible depending on the situation. If your maintenance guy can't answer these questions I'd seriously consider changing companies, or getting a second opinion at least.
Sep 20, 2010 | Intex Automatic Salt Water System for ...
We have a 15' by 48 " pool with an Intex saltwater chlorinator.About two weeks ago the low salt light started flashing .We ended up adding way too much salt (160 lbs)because the low salt light kept...
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Aug 29, 2010 | Intex Automatic Salt Water System for ...
We change our pool that we have had for 10 years over to the intex salt system. 4ft X 24 ft round above ground pool. 13500 gla water. We put in 10- 40lb bas of pool salt and have ran the system for the 12...
The pool is green because you didn't take the metal out of the water first. It is too late now to do that ... you will just have to let the filter grab it. It may trake several days. Run the filter 24/7 for those couple days for best results.
Next time you fill your pool ... get a sequestering agent to grab the metals before you introduce CL to your pool. Use the sequestering agent according to the container instructions.
Your salt level should be around 3200 ppm, is it?
Jul 07, 2010 | Intex Automatic Salt Water System for ...
Green water with salt water filtration system- HELP
you can not blindly just add salt
you need a salt test kit that reads #'s, not color
Get your salt content to as close to 3000ppm as you can any lower than 2800 and you will not produce enough chlorine and any more than 3500 and it will taste bad and could make your water cloudy or trigger high salt alarms
Also remeber to run filter only for 24 hours after adding salt
you also need to realize that a pool goes green for many reasons lack of sanitizer,heat,sun,rain,sun tan oil, 3 of swimmers
A pool need to be turned over at the bare minimum of 3-4 times in a day.
Intex filters are not sufficient to properly do the task
only a good sand filter and seperate pump of about 1 horse will really keep a pool sufficiently cleand but if you follow my advise you can do it with the intex
lets start with the filtering I believe your pool is around 5000 gl
if you have a 2000 gl ph pump then you need to be filtering 7 1/2 -10 hours just to keep your pool clear you do the math for you
as for grnerating your chlorine time varies depending on the situations I mentioned earlier
it is good you are using a stabilizer but that only goes so far if it was hot and sunny and a lot of use chlorine will get ate up any way
And make sure your algaecide is a non foaming kind and stick to the directions
now to your problem at hand
you now need to as you did shock it but you also need to use a lot of elbow grease and remeber this is going to be tedius
Clean your cartridge with the garden hose blast it in the folds as hard as you can
start your filter again and now add 2 gallons of chlorine or house hold bleach
let filter for 12 hours and then with a pool brush not the bristles under your vacuum head scrub the sides and walls continue filtering until you see the settled algae and then vacuum
now clean your cartridge again and repeat if the chlorine is still high you do not need to add but if it went low again then add 1 more gallon
continue doing this until you can see a huge difference
once you can then start with your algaecide again
at this point overdose it as directed on the bottle once your chlorine is low enough to get in then you need to get in and brush under the seems
with the intex liner there are too many seams and folds that need to be addressed
another hint is to have 2 filters one drying while the other is in the unit
a wet freshly cleaned filter does not work and trap particles as well as one that has been dried
Another good chemical to use is a water clarifier this helps minute particles that you can not see clump together thus making it easier for thr cartridge to trap
good luck and if you have any more questions you can e-mail me through this site
Jul 09, 2010 | Intex Automatic Salt Water System for ...
My water was crystal clear when delivered. I added the salt, ran the filter pump for 24 hrs as instructed. Turned on my Intex saltwater pump and within an hour water is green. Cannot find anything on...
I am not impressed at all with these salt water chlorinators.Shock the water and keep the filter running next day add a powdered chlorine.filter still running. check the balance with test strip in about four hours.If chlorine level is good start vacuming the algee off the bottom of the pool. Now throw away the salt generator and stay with the chlorine packs every week to two weeks continue to monitor with test strips
Jun 17, 2010 | Intex Automatic Salt Water System for ...
Have put 280 lbs of salt in my 9300 gaoole pool and still getting the low salt light. What is the next step? Just set up the pool last week but the chlorine converter is from late last year. It did not...
By my calculations you are about 50 lbs over the requirement. Which code are you getting? I'm guessing code 91. Have you removed and cleaned the electrolytic cell from the chlorinator? I get lots of calcium on mine from hard water from the well requiring a cleaning at least once per week. If you get this working and get a warning that you now have too much salt you'll need to drain off water and re-add to get the salt content correct.
Jun 04, 2010 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
229 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
