Question about Casio FX-115ES Scientific Calculator
How do you find out chi squared on a casio fx 9860G SD calculator?
  • Casio Master
  • 8,073 Answers
The following screen captures are from another Casio Graphing calculator so the menu screen may not look yours. However the instructions are identical.
Here is a sequence of screen captures to illustrate how to do it.
Turn calculator ON. Use arrow to highlight STAT and press EXE
Press F5 DIST
Then select F3 CHI
Choose Cpd or Ccd
If you choose Cpd : you must enter the Chi value you want, and press EXE, then the number of degrees of freedom (df) and press EXE. The Execute command is highlighted. This allows you to perform the actions
indicated by the Thumbnails at the bottom of the screen: calculate a value or Draw the how do you find out - bc12533.jpgn.
In thehow do you find out - 6965ab1.jpgove I took Chi=1, and df=3 and pressed the CALC menu.
If I press the DRAW menu instead, the distribution is displayed.
If you want the other distribution Ccd, press Ccd instead in screen capture 4.
Posted on Aug 04, 2010
What is an Ma error casio fx-9860gii
Ma error means Mathematical error.
Check input values and make corrections to ensure that values are within allowed limits.
Please Check the manual for the calculator. It is available on the Casio website. Here is the link.
fx 9860G fx 9860G SD Calculators Manuals CASIO
Aug 30, 2014 | Office Equipment & Supplies
Casio FX - 9860G SD have complex equations??
Your question (?) is not clear so I will not try to guess what you really mean.
Be it as it may, the Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Apparently it will take coefficients that are real, and will give a Ma Error if any coefficient is complex.
Mar 16, 2012 | Casio FX-9860G Graphic Calculator
Mar 16, 2012 | Casio Office Equipment & Supplies
Mar 16, 2012 | Casio FX-9750GPlus Calculator
Can you calculate indefinite integrals on the casio fx-9860G
Unfortunately, the Casio FX-9860 G does not have a Computer Algebra System or CAS. For this reason it can only calculate definte integral over a given interval. The lower and upper limits must be supplied. The result will be a number.
Casio calculators that have a CAS are the Casio ClassPad CP330/ 300Plus/ 330, or the Algebra FX 2.0.
Feb 08, 2012 | Casio FX-9860G Graphic Calculator
Prime factorization using Casio FX-9860G Graphic Calculator
There is a program called Prime Factor Analysis on this site. It is written for the FX-9750GPlus calculator but I suspect you should be able to use it on the FX-9860G. To access the site you must have an account. You can register and it is free.
Jul 30, 2011 | Casio FX-9860G Graphic Calculator
I have the Casio FX-9860G Slim, how do i do logs with something other then base 10?
Use the logab function in the catalog. For example, to calculate log base 2 of 32:
OPTN F4 F6 F4 2 , 3 2 ) EXE
Dec 15, 2010 | Casio FX-9860G Graphic Calculator
My casio fx-9860G au, wont copy equations from statistic mode to graphic mode. can you please tell me how i can fix this?
Just in case you did not find the Copy function I am including this screen capture from the FX-9860G SD.
The function is available at the bottom of the screen that displays the regression curve. Press Copy and select a function Y1= or Y2=. The next time you press the Draw tab the scatter plot and the regression curve will be displayed on the same screen.
Aug 15, 2010 | Casio FX-9860G Graphic Calculator
How do I look up chi square table on a casio fx-9750G plus?
Press F5 DIST
Then select F3 CHI
Choose Cpd or Ccd
indicated by the Thumbnails at the bottom of the screen: calculate a value or Draw the distribution.
In the example above I took Chi=1, and df=3 and pressed the CALC menu.
Jun 21, 2010 | Casio FX-9750GPlus Calculator
Hello, I have a casio fx-9860 GII, and the sd card is stuck in it... how can I fix it?
To extract the SD card from its slot, you press with a finger on the edge. It should pop out a bit. Pull it out.
If it refuses to pop out, either you did not press hard enough to feel it move inside or ejection mechanism in calculator is defective.
Apr 25, 2010 | Casio FX-9860G Graphic Calculator
Casio FX-115ES Scientific Calculator Logo
2,407 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
