Question about JVC GR-D350US
I have a JVC model # GR-D372U and the camera is saying to eject and reinsert tape, but when I go to do so, the tape will not come out. The camera does not function all the way so that I can even get the tape out!
ctf1800
  • 4402 Answers
SOURCE: JVC GR-DVL520 Problems
try tapping it on the side.
-only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
-when and if you do get E- errors do a complete rewind or fast forward to the end of the tape in order to pull out tape slack. Then remove battery and tape for a while. If still screwed, then yes, sharply tap (not hard!) on the closed tape door. That may reposition those tiny switches that I mentioned earlier and get you going again.
-NEVER, EVER, EVER, leave tapes in the machine when not in use....it creates problems for the heads and the mechanisms.
-Don't leave the battery on the camera when not in use for extended periods of time. It can create problems with respect to resetting the computer controlled logic.
-there are little switches and interlocks that provide electrical feedback about the mechanical status of things to the main processor of the camera (ie. tape/no tape in camera, door open/closed etc). Over time, the mechanics get out of adjustment because of usage, humidity and certainly rough handling. So: treat the mechanisms very, very, very delicately. Don't use/store the camera in humid conditions, hot conditions or very cold conditions. Certainly don't leave it in your car---ever!
-get the camera "cleaned and ajusted" regularly to avoid these problems. (I know...more $$$$)
-I keep bags of dessicant in an insulated camera bag with the camera to maintain dryness and optimal temperatures during storage.
Posted on Dec 20, 2007
  • 4 Answers
SOURCE: jvc video camera model gr-d53as shoft ware cd
please let me know how to install the product drivers
Posted on Apr 05, 2009
SOURCE: JVC Camcorder Model # GR-D270U
I thought this was a camera issue, but it ended up being a tape issue. So it shouldn't matter if you have the same model of the JVC mini camcorder as I did or not. Anyway, the tape has a tab that "locks" the tape to keep from recording over it accidently. I moved that tab and it started working. If your tape is stuck in the camera, you may have lost the tape already. Try to get it out of the camera without damaging the tape or the camera...more importantly the camera. You may have to take it to a professional to prevent damage. If you get it out undamaged, check to see if the tape is locked or not. Move the tab and try the tape in the camera again (unless you're afraid of it getting stuck again). In that case, try it in another camera. That's how I discovered that this was a tape issue rather than a camera issue...because I tried the same tape in a different camera and got the same error message. Don't despair if your tape comes out with part of it sticking out or crumpled, as long as it's not broken, you can salvage it. Even if it's broken, you can probably salvage the majority of the tape by taping it back together (call a professional, you may need special tape for this), just don't touch any of the undamaged tape or pull it out of the cassette too far and all you will lose is the damaged portion. I actually couldn't see the tab well enough to tell if it was in locked or unlocked mode since it's so tiny and my close-up vision is getting blurry, but I moved the tab to opposite of what it was and that seemed to do the trick. My mistake was in trying to save money with the cheaper tapes...next time I'll spend a little extra for the better tapes to avoid all this headache. Hope this helped. Have a great day!
Posted on Apr 08, 2009
RixsFixes
  • 2200 Answers
SOURCE: I am looking for a new owners manual for a JVC
Hi
Your users manual can be downloaded directly from this link
http://books.jvcservice.com/booklist.asp?Model=GR-D72U
Hope this helps. Please do rate this answer. Many Thanks.
Posted on Aug 31, 2009
jyackle5
  • 8197 Answers
SOURCE: I need a manual for m0del GR-D85OU
You can get the manual here.
http://resources.jvc.com/Resources/00/01/13/LYT1803-001A.pdf
Good Luck
Posted on Nov 20, 2009
I have a JVC GR-D30U I get error E)$ eject and reinsert tape unit in safe mode. I can not eject the tape to reinsert it.
HI,
Please reset it.By removing the battery for 10min and then insert it back.Let me know the result.
Sep 01, 2008 | JVC Cameras
I have a JVC GR-D75OU video camera. When I turn
i have jvc movie camera when i turn it on it says protective cap is on how do i fix this
Nov 30, 2009 | JVC GRD775 / GR-D775US / GR-D775US MiniDV...
Unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
JVC GR-D30U Digital Video Camera error E04
there was a hole under the tape deck.. u can try to force;y open it right there
Sep 01, 2008 | Cameras
Jvc digital video camera mini dv gr-d244u
I have had the same problem...usually had success by taking off the battery, putting it back on, turning the power off and on, etc.  It has always gone back in eventually.  I also tried re-charging the battery and replacing.  Could this be an old battery problem?  Mine is 4.5 years old.
Jan 06, 2008 | Panasonic Palmcorder PV-GS9 Mini DV...
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 27, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC-GR-D371U
Sep 25, 2007 | JVC GR-D370 Mini DV Digital Camcorder
JVC GR-D350US Logo
137 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
