Question about HP Pavilion dv6t Notebook
Does this card support dual screen mode? I just bought a monitor that I'd like to use with my HP Pavilion dv6t. I can't set the resolution higher than 1366 x 768. I am told that if the video card must support dual screen mode to be able to do that. TIA
  • 55 Answers
Dual screen mode? You mean dual monitor mode?
But anyways, the maximum resolution that you can obtain on your Pavilion dv6t is 1366x768 unless you attach an external monitor. Even then, only the external monitor can go above 1366x768 resolution. You're laptop screen will remain at 1366x768 max.
Ericthecmh
Posted on Sep 30, 2011
Buzzing sound and the screen freezes with horizontal lines on the screen
if you use external monitor works ok?or same situation?
its sounds like a failure of the graphic card
Oct 06, 2012 | HP Pavilion dv6t Notebook
Change the resolution on my Samsung B2030 LCD Monitor
1600X900 is a higher resolution than that of 1280X1024. Therefore 1600X900 is a better resolution. If you would like to run at the lower resolution simply right click your desktop screen and click properties. Then on the settings tab use the slider bar to adjust the resolution. Lower to the left and higher to the right. If the desired resolution is unavailable then you could try downloading and installing the latest drivers for your graphics card installed in your computer.
Your card will either be AMD/ATI Radeon or Nvidia. You will need the model number of the graphics card, the latest drivers may increase resolution support for your card.
Also look on the bottom right hand side of your screen for an Nvidia Control Panel logo in green. Right click it and select the option to "change screen resolution" This may provide you with additional resolution options.
Take care!
damnor01
Nov 02, 2011 | Samsung B2030 LCD Monitor
Monitor only works at start up. then I must use optional monitor. occasionaly monitor will work for a short time
You may need to change the resolution on the screen, in windows, you may find the "Display Options" under "Control Panel", usually this problems is caused by the computer having a hight resolution than the supported by the monitor, for your specific monitor the available resolutions are:
Support of video modes up to 1280 x 1024 at a 75 Hz refresh rate from the manual at:
http://h10032.www1.hp.com/ctg/Manual/c00264775.pdf
That means you have to chose a resolution lower than 1280 x 1024 and a frequency lower than 75 Hz. Anything higher than that on the resolution or frequency will cause the monitor to display a "Out of Sync" message and turn off shortly thereafter.
Thanks !!!
Mar 06, 2011 | HP Pavilion F1703 17" LCD Monitor
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Spec: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00485268&lang=en&cc=us&taskId=101&prodSeriesId=1130384&prodTypeId=382087
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
  2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
  3. Scroll down to highlight Enable VGA Mode , and press ENTER .
  4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor.
May 20, 2010 | HP L1506 15" LCD Monitor
W17e says "input not supported"
Hi - here's what I found about your wide screen monitor:
The HP Pavilion w17e LCD wide-screen monitor has the following features:
  • 1440 x 900 factory-set resolution
  • Supports VGA analog signal video input
  • Plug and play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Energy Star compliant
Download & install the drivers for the monitor based on the version of Windows you are running from the HP site below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=pe&dlc=es&product=3377546&
Once the drivers are installed, your issues should be resolved - the driver will allow only the modes that can be displayed on the monitor - probably giving you options for resolutions you hadn't seen before.
Sep 29, 2009 | Acer AL1916W 19" LCD Monitor
HP Pavilion dv9000t display works only in VGA when on AC
After analysis your issue with display, it's seems your laptop's display card gets corrupted or faulty....
so request you visit at HP service centre and ask him for resolution.
Thanks
Sushant
Jul 06, 2009 | Computers & Internet
I bought second hand monitor samsung syncmaster750s..when i plug it the icons become blurry and become large and i cannot set my resolution...i use the vga mode because when i start it normally..it au
Normally if you go in VGA mode the screen will be installed and when rebooting in normal mode it will set itself.
In VGA mode the resolution is 640x480 and you can't set the resolution higher, so what you are experiencing is normal.
From what you are saying it seems that the driver installed from windows is the wrong one, you can try to run windows update to see if there is a driver for it or go on samsung website.
You can get the driver from samsung here :
Samsung 750s driver
If after that it doesn't work check on the internet for compatibility issues with your graphic card, since some of the newer cards can have compatibility issues with the older CRT screens.
Jun 01, 2009 | Samsung Computers & Internet
I have my HP Pavilion hooked up to my new Acer al2216W monitor. The image comes up on the monitor but keeps flashing on and off constantly. How do I make the screen stay on?
Video Card problem. This can be caused by your onboard video card or a separate video card installed on your AGP or PCIE slot. Either way, try changing your display settings first. Set it at a lower or higher refresh rate and lower or higher bit and resolution settings.
Mar 09, 2009 | Acer AL2216WBD LCD Monitor
Moniter wont work
Possible reasons for this is a defective video card or the monitor itself or Windows installation failure. First, isolate the problem by swapping a working monitor to your system and check if the problem still persists. If it still doesn't work, then video card is the culprit. Some defective video cards function only on the lower resolution settings, which is the default resolution in the installation process of Windows XP. When the installation is finished, boot loader set the user interface to a much higher resolution which the defective video card is incapable of.
To further verify this, try pressing F8 and start Windows XP in a Safe Mode. If it boots properly, then Windows XP is incapable of going across the normal mode.
Jul 18, 2008 | HP Pavilion MX70 17" CRT Monitor
Monito going to sleep
I have the same problem. Monitor states going to sleep and the pc goes dead
Jul 03, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion dv6t Notebook Logo
123 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
