Question about Tanaka 30" Double Sided 24cc Hedge Trimmer
Stihl petrol hedge clippers.engine starts o.k,runs for 10 mins;then stops.will not start again until it has cooled down,then it starts o.k.
    New Friend:
What is the spark plug gap on my stihl petrol hedge trimmer
Posted on Jul 28, 2013
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Could be the air filter needs replacing
Posted on Jul 31, 2010
I have a stihl 2 stroke petrol whipper snipper. It seems to have over heated at the reel end. I have smoke and grease spewing out at that end (metal neck at the reel end) have I fried it?
Sounds like you have a straight shaft trimmer version that have got bad bearing(s) that needs replacing. It probably will take the whole gearbox as a replacement item.
Jan 20, 2015 | whipper snipper stihl fs 38
Why does a Stihl hedge trimmer stop after 20minutes
I'm not familiar with your particular machine, BUT...
That symptom can be caused by lack of lubrication leading to main bearing wear and progressing failure.
As the bearings wear, they generate MORE HEAT, which causes metal "swelling," in the beaarings, and thus constriction.
As this problem slowly escalates, it gets to the point that the engine doesn't have enough power to continue to run, BUT...
After the engine has cooled down, it will run again.
IF this is the case in your machine, this problem can't go away, but will continue to escalate until the bearings finally fully seize!!!!!
May 06, 2014 | Garden
Why does my hedge trimmer die after a few minutes operation
This sounds like worn main bearings beginning to seize. Worn bearings generate more heat which causes the metal bearings and their races to 'swell," thus getting tighter and generating more heat until the drag of the bearing friction is greater than the power of the motor. Eventually you can't restart it until the engine has fully cooled down.
Apr 30, 2014 | Poulan Pro PP2822 28CC Hedge Trimmer
Stihl ts400 starts run then runs poor and cuts out
This could be caused by one or more of several things, but it sounds like worn main bearings beginning to seize. Worn bearings generate more heat which causes the metal bearings and their races to 'swell," thus getting tighter and generating more heat until the drag of the bearing friction is greater than the power of the motor. Eventually you can't restart it until the engine has fully cooled down.
Apr 22, 2014 | Garden
10 min. run time
Sounds like the vetilation hole in the gas cap is plugged, so fuel feeding out pulls a slight vaccuum in the tank. Flow stops until some air leaks in. Clean the cap or leave it loose.
Dec 02, 2017 | Garden
Starting procedure for stihl 012 av
Full choke, stop switch on run. Pull rope handle 3-4 times or more until it "tries to start" (it will not start, but it will try to for a split second) move the choke lever to the half-choke position and without pulling the throttle, poll the rope handle until the engine fires and runs for 4-5 seconds then fully open the choke to the run position, let it warm up for 25-30 seconds (don't forget to let it cool down about 45-60 seconds before you turn it off!) and then proceed to use it.
Aug 07, 2012 | Stihl Garden
Stihl HS 80 stops after a while
Check the fuel tank vent, it could be creating a vaccum in the fuel tank which is stopping the carb from drawing up the fuel. Then you're having to wait till the pressure in the fuel tank equalises again.
Jun 22, 2012 | Stihl Ignition Coil, Module Air Gap Guage...
My trimmer cranks good and starts off running good. After about 5 and sometimes as long 10 mins it will suddenly start running 1/2 speed. I 'm guessing something is getting hot and causing it to miss fire?...
the ignition coil is shorting out...it's a stihl thing...seen it too many times...get another coil...if it's new, it's under warranty (a dealership "must" repair to get warranty)...
May 31, 2010 | Garden
How do you set the carb screws on a stihl d12 avt chainsaw? how many turns for high an low?//?????
I would start by opening each 1 turn. Then 1/2 turn until I got it running. While running, set the low by turning the screw out until the saw starts to slow down. Then turn in until the same thing happens. Set the screw about 1/2 way in between. Do the same with the high but do it while running at a higher RPM. Do not run it wide open unless you have the chain in wood, cutting. Good luck...Lee
May 28, 2010 | Oregon Scientific Complete Carburetor for...
Tanaka 30" Double Sided 24cc Hedge Trimmer Logo
429 people viewed this question
Top Tanaka Garden Experts
john h
Marvin
Marvin
wadingriver
wadingriver
Are you a Tanaka Garden Expert? Answer questions, earn points and help others
