Have an echo in the speaker system - Computers & Internet
    Novelist:
  • 150 Answers
OK, What is the speaker connected to ?
Is this a PC with a fancy audio card and software ?
Have you activated any fancy special DSP effects
(such as echo, reverb or concert hall effects)
within the audio card settings or software applications ?
DO you have a microphone attached (internal or external)
that is causing feedback?
do you here a howl or a whistle sometimes, when the speakers
get closer to the PC?
Check the Windows Volume Control, both record and playback.
If there is a microphone setting, mute it.
Hope this gets you started, otherwise give us
more info
Martin
Posted on Apr 24, 2008
My new Vizion tv has a vizion sound bar, the sound comes out with an echo, how do I correct?
Your TV speakers should be turned all the way down or off when you use a separate sound system such as a soundbar. Using them with the soundbar may cause echoes and the TV speakers do nothing to improve the sound.
Look at your TV's audio menu. If you can, turn the TV speakers off completely at the menu. Also see if you can set the analog audio output to "variable." This will allow you to control the soundbar's volume with the TV remote.
Jul 08, 2017 | Echo Computers & Internet
How do I connect conventional speakers to Alexa?
  1. Set your Echo Dot and external speaker at least three feet apart. When Echo Dot is close to external speakers, it may be more difficult for Alexa to hear the wake word and other requests.
  2. Turn your external speaker on.
  3. Plug one end of an audio cable into your speaker and the other end into Echo Dot. All audio from Echo Dot now streams through your external speaker.
May 21, 2017 | Computers & Internet
Echo through speakers
Unintended reverberation, or "echoing," from your computer speakers is a common problem that can arise from improper setup of your audio properties.
Resetting all of your audio information to default will correct this problem, allowing you another chance to strike a good balance to satisfy your audio tastes.
This can be accomplished by accessing the Sounds menu in your operating system.
Select the "Start" menu from the bottom-left corner of your screen, and click on "Control Panel." Find the "hardware and Sound" button and click to select.
Click on the sound icon and select the third tab labeled "Sounds" in the window that appears. A list of sounds will appear, beginning with "Asterisk." Click on a sound to highlight and select test.
Listen to hear if the echoing problem occurs.
If it does, you need to configure your speakers or check to see if it is a third-party issue.
Select the first tab labeled "Playback" from the same window. Right-click on the "Speakers" icon. Click on "Configure Speakers" from the top of the list.
Choose a setup from the list that appears and select test to test different sound configurations for the speakers.
Listen to decipher if one configuration has less echo than another. If so, choose the speaker configuration without the echo to fix the problem.
However, if none of the configurations remove the echo, you need to attempt to troubleshoot the issue from "Safe Mode."
Turn on your computer if it is off or restart your computer. Continuously press the "F8" key until the "Advance Boot Options" screen appears.
Use your arrow keys to navigate the screen, pressing down until you have highlighted the "Safe Mode" option. Hit "Enter" to select. Wait for the drivers to load.
Log on from the "Administrator" account. Test the sounds again, and if the echo does not occur, the cause is a third-party driver or service.
hope this helps
Sep 15, 2012 | ASUS Computers & Internet
Mic Echoes
Echo is caused by a number of variables. Are you in a large room with mic extended away from you? Mic too far away will create echo. Also try turning down the gain for the mic
Jan 22, 2010 | Dynex Voice-Certified PC Desktop...
Echo Problem
Try one or more steps to reduce echo:
1. In Device Settings, under Mircophone test make sure that 'Auto Adjust Audio' is checked. It automatically sets the audio and reduces echo.
2. Right click in the class window to open up the context menu. Click Settings in the menu. Macromedia Flash Player Settings window opens up. Click on microphone icon and check 'Reduce Echo' option.
3. Uncheck boost in microphone device settings.
4. Use a headset and not desktop speakers.
If a class participant (may be an attendee or a presenter) is experiencing echo then all other class participants are required to make settings at their ends. Preferably, the presenter may transfer control to the attendees one by one and identify the system generating echo.
Jan 16, 2010 | Acer 90.00012.30B Computer Speakers
System echos when dvd is in. When I mute the Bose sytem I can hear the TV sound without the echo.
The echo you hear is the audio delay between your TV speakers and Bose speakers. Muting (or lowering the volume) on the TV will eliminate the echo. Some TVs have a setting to turn of TV speakers entirely, allowing you to listen to your TVs audio strictly through your Bose system.
Dec 20, 2008 | Bose 3·2·1 II System
All sounds on my computer sound like they're in an echo chamber
I had this problem. I right clicked on the speaker icon at the bottom right hand corner of the screen, selected playback devices, left clicked to highlight the 'speakers' (realtek in my case) then clicked properties in the lower right of the open window, clicked on the enhancements tab, and found that my sound effect properties had been changed to auditorium. I clicked the selection arrow and changed the enhancements to 'none'. Oh happy day! No more echo.
Dec 14, 2008 | JBL CREATURE II Computer Speakers
I pluged in my speakers but the sounds are very low and wierd
you cant get echo on a specker there not made for that just normal sound
Nov 16, 2008 | Ozaki DT-500 3-Piece Speaker System...
Sound echo
I found that the best way to avoid this problem is to mute the television speakers or, if you can, turn off the speakers. There seems to be a very brief delay between TV and theater speakers, causing what sounds like an echo. hope this helps.
Oct 20, 2007 | Audio Players & Recorders
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
