Question about Sony PS-LX250H Turntable
Records turning at approximately 33 not 33 1/3. A
Records turning at approximately 33 not 33 1/3. A bit slow. turntable hardly ever used.
  • Sony Master
  • 5,515 Answers
If it's not the belt some have speed preset controls which sometimes are found underneath (perhaps covered up) or they are on a pc board inside (accessed by underneathed).
Posted on Aug 01, 2010
33 Records are playing a bit too fast on my Wockoder Record Player... Is there any way to fix this?
Lots of quality turntables have a speed checker and a limited amount of speed adjustment.
Many ordinary record decks use a synchronous motor, the speed of which is regulated by the Hz of the mains supply and with mostly fixed gear ratios it is impossible for them to run faster - slower is the usual problem.
I expect there will be types driven by a dc motor and regulated by a switch mode power supply but I know nothing about them.
I suggest you begin by learning something about your turntable.
Dec 27, 2017 | The Audio Players & Recorders
Record player turntable runs too slow. How to troubleshoot?
If this is a belt drive turntable the belt might be in the wrong position or is slack due to wear.
Jun 12, 2017 | Audio Players & Recorders
Crosley CR40 playing 33 1/2 too fast? What can I do to slow it just a little bit?
I would get a vintage turntable and not a new one inexpensive one. The new record players do not last.
Apr 20, 2014 | Crosley Stack-O-Matic CR40 Turntable
What's the correct way to use the strobe light to set turntable speed?
The turntable may have a pattern on the edge of the turntable. If not you need a turntable strobe disk that you place on the turntable like a record. The pattern on the disk or on the edge of the turntable will be marked for 50 Hz or 60 Hz frequency.
The strobe marks on the disk or on the turntable are for 33 RPM and 45 RPM and for both 50 & 60 Hz mains frequency.
To adjust the turntable for the correct RPM, turn on the strobe light and the turntable set it to 33 RPM and shine the strobe light on these marks and adjust the speed setting until the 33 RPM marks appear steady and not moving. You may want to check it for 45 RPM as well.
Make sure you use the correct mains frequency marks ie. the 50 or 60 Hz that your electricity system uses.
Feb 25, 2011 | Audio Players & Recorders
What is required to convert 78rpm records to mp3 format?
The cartridge must have a stylus for 78rpm records. If the turntable does not have a 78 speed play it back at 45rpm. Record it and using the software you have or get one such as Audio Cleaning Lab, just select the option to convert from 45 to 78. You can then carry out any audio modifications to clean it up, then save it as an MP3.
Never use a 45/33 stylus to play a 78 and never use a 78 to play a 45/33 record.
Nov 07, 2010 | ION Audio TTUSB10 Turntable
Spins too fast
Check that the belt [under turntable] is`nt twisted or the 33/45 speed button is`nt sticking on 45rpm
Feb 26, 2010 | ION Audio iTTUSB Turntable
My TEAC P688 is stuck in chipmunk mode for a large record - how do I slow it down?
Sometimes on the base of the turntable (under side) there are two presets one for the 45 speed and one for the 33. They might be hidden under a label or something. You might even have to go inside to find them. Anyway a small flat head screwdriver inserted in it should adjust the speed. You might have to work out which controls 33 speed. And of course if it is below you will have to figure out how to adjust it with a record playing. "Get out and get under!!!!" as they said about cars!
Jun 28, 2009 | Teac P-A688 Turntable
I have an old Sony Stereo Music System HP - 169 with a BSR Precision Crafted in Gt. Britain turntable ... everything works except the turntable won't do a thing. Table won't go around on its own .... when...
SEYLEVITT@JUNO.COM.
THERE IS A 3/4 CLIP THAT HOLDS THE TURNTABLE, SO IT DOES NOT COME OFF OF THE CHANGER. THAT CAN BE FROZEN TO THE LOWER SECTION.
(1) CAN YOU SPIN THE TURNTABLE WITH YOUR FINGER? (YES) (NO)
(2) DO YOU HAVE TO FORCE IT TO MAKE A 360 DEGREE REVOLUTION????? (YES) (N0)
(3) IF IT TURNS FREELY, AND YOU PUT THE
LEAVER IN ==MANUAL== 33 1/3 DOES THE TURNTABLE SPIN, BUT WILL NOT PLAY RECORD AT THE 33 1/3 SPEED., IT TURNS SLOW.
(4) REPLY TO SEYLEVITT@JU8NO.COM
I HAVE NOT KEPT THE E-MAIL THAT YOU ARE READING. ANSWER WITH MY QUESTION, BY THE NUMBERS.
SEYLEVITT@JUNO.COM
SEYMOUR LEVITT
Jun 25, 2009 | Audio Players & Recorders
Old record player spins too slowly
it sounds as if the rubber belt is to slack however also worth checking ithe attachment to the spindle itself is not loose 2make sure the belt is the correct type
Feb 09, 2009 | Crosley Traveler Turntable
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
Sony PS-LX250H Turntable Logo
218 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
