Question about Canon CanoScan 3000ex Flatbed Scanner
Error in scanner. Turn off scanner and follow instructions in manual.Scanner driver will be closed. (code:201) Unable to open TWATN source Please check connection Then re-start Toolbox.
    Scholar:
  • 126 Answers
This error can be caused by many different issues. Try the following resolutions in order until your issue is fixed-
1. You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
2. unistall and re-install drivers-
1. Place the CanoScan Setup CD-ROM into the CD-ROM drive.
2. When the CanoScan Setup Utility menu appears, click the option to 'Uninstall the Software' and then follow the prompts.
3. Disable Third-party Software
Software applications that are active during installation can cause errors, installation difficulties and even abort the installation.*1 Close all running applications, including anti-virus programs, before installing Canon Software. You can also prevent these applications from starting through 'System Configuration Utility' (also referred to as 'msconfig') in Windows 98/Me, Windows XP and Windows Vista.
If your computer is part of an office network: Network permissions, security software, etc. may be interfering with proper communication. Please contact your System or Network Administrator before attempting to disable software on your system.
a. See your applications' documentation for instructions on how to close it.
b. If you are unable to locate the documentation or the application appears to be running after it is closed, disable the startup items in the Windows 'System Configuration Utility'.
c. If disabling startup items in 'msconfig' does not correct the issue, disable non-Microsoft related services in 'Services' tab of 'System Configuration Utility' window.
d. Attempt to install the Canon software (drivers). If the drivers were already installed, uninstall them (keep the third-party software disabled) and then reinstall the drivers.
e. After installation is complete, set 'msconfig' back to 'Normal Startup'.
//javaftper
Posted on Jul 31, 2010
Unable open twain source please
This is an issue with the Driver Installation, Get the drivers Uninstall and reinstalled from the CD.
May 11, 2013 | Canon CanoScan LiDE 25 Flatbed Scanner
If I try to scan or copy some files, it writes me: 'Error in scanner and follow instruction in manual. Scanner driver will be closed.(Code:201)'. Please help
copy and paste the link below to your browser...
http://www.google.com.ph/search?q=CanoScan+3000F+Flatbed+Scanner+code+201&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Mar 01, 2011 | Canon CanoScan 3000F Flatbed Scanner
When i try to scan i get this message: unable to open TWAIN source Please check connection then re-start Toolbox the connections are tight
Driver mismatch - the driver of the scanner has forgotten the location of the TWAIN driver because another software has been using it lately. Follow this
http://weblogs.asp.net/jeffwids/archive/2009/11/02/canon-scanner-unable-to-open-twain-source.aspx
Feb 20, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
My canoscan fb620u shows device offline.
It your using a newer windows you probably need new software. Try Vue Scan it worked for me on Windows 7 64bit and I have the same scanner. With out dated software it wont recognize the scanner. Hope it helps
Dec 24, 2009 | Canon CanoScan FB620U Flatbed Scanner
By Massoud on Mar 28, 2008" " When i try to snan ,i come up with a aignal"Error in scanner . Turn off scanner and follow instruction in manual,scanner drive will be closed(Error 201)
if that scanner is powered by the USB port .. you might want to try a different port or a powered external port .. sometimes some USB ports cant supply enough power ..
Dec 23, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan LiDE 20
already install the scanner driver but still can't working properly.
Sep 04, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Error 201
Which scanner is this? Error (201) usually indicates some sort of power issue...such as the scanner is not getting enough power. If this is a USB powered scanner you may try connecting to different USB ports on the computer.
Mar 28, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CANON 3000F
If you are runnnig XP or Vista this will happen
Go to Start/Programs/Accessoris/System Tools/Compatability Wizard
Reset the machine for Win 98
Mar 20, 2008 | Canon CanoScan 3000F Flatbed Scanner
Canon CanoScan 3000ex Flatbed Scanner Logo
2,133 people viewed this question
old marine
old marine
