Question about kawasaki Fh641v 21hp 21 Hp Riding Lawn Mower Engine ()
Yaz/Kees zekw52210 w/ 300 hr kaw fh641v.At 1/2 throttle,Eng runs well nr 1 cyl but nr 2 runs intermittent. At full rpm,same intmit Opn. New plugs same complaint.
  • 6,826 Answers
Did you check the wires to the coil, and also, how much gas is coming through?
Also, did you check the compression to make sure it has enough compression on the cylinder? check for a bent valve?
Wish you luck on this diagnosis and repair.
Posted on Jul 31, 2010
Saw will not rev up to full rpm when you pull trigger it revs up to 1/2 to 3/4 throttle and starts cutting out.
Engine may be too worn or may have run out of oil at some point, compromising the bearings.
May 13, 2015 | Garden
My 03 wrangler will not rev past 3,500 rpm
Do you have a trouble code for the throttle position sensor ?
If you have normal fuel pressure, the TPS would be the next thing to check. Problem could be in the harness between the sensor and the computer too.
Jul 20, 2012 | 2003 Jeep Wrangler
Taurus intermittent misfire cyl 1 and 2
Do a leak-down test or at least a compression test
Jul 06, 2012 | 2003 Ford Taurus
Getting a intermittant misfire and an occasional srvc eng soon light sthe code says misfire cyl 1 but after i reset the light i goes back to intermittant missing
Check your ignition coils. If you don't have a coil for each plug then I'd bet thats going to be your problem. That or your spark plugs. I'd start with the coil that cylinder 1 runs through first though.
Nov 14, 2010 | 2001 Ford Mustang
CH25 Kohler on a Kees mower. Back fires under light loads
you must have the throttle at full at all times when under load driving and mowing, back fire is do to much fuel. if your running throttle at full than look at the carburetor and then the wiring (short)
Oct 12, 2009 | Garden
Jaguar x type 2004 2.5 petrol V6, 38500 miles, codes P0171, P0174
Have exactly the same issue on 04 jag x type 2.5. So far have replaced fuel filter, air filter k&n, plugs ngk. Codes cleared, same issue. Seems to appear when air temp is cold and eng is warm.
Am replacing upstream O2 sensors and cleaning MAF next. Will keep you posted if it clears up. Did you ever find the cause?
Aug 25, 2009 | 2002 Jaguar X-Type
88 Yamaha 70 starts,idles,no more than 2100rpm at full throttle
hi motor is only running on 2 cylinders
is the plug wet on no1 if so then swap over the complea tset up /coil ,lead ,plug with no 3 if no3 now has problems we know where we stand if no 1 ok then coil is breaking down under load try it in the dark sometimes tracking will show up better if the plug was dry then it is carb or r/valveswap carb /a ball ache i know but it will prove it one way or another hope this helps merlin v 12
Aug 25, 2009 | Boating
kawasaki Fh641v 21hp 21 Hp Riding Lawn Mower Engine () Logo
55 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
