Question about Siemens HF87950GB Convection Microwave Oven
Hi. We own a Siemens Microwave Oven Model HB86K.70. It is a fitted unit. We see to be experiencing a problem in that it does not heat sufficiently at 900 over short period - 1 to 3 min. Can you help? Ari Efstathiou
2 Suggested Answers
SOURCE: Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Posted on Feb 26, 2008
Siemens quantum speed combi .. The microwave turns on but does not heat
Hi there more then likely to be the magnetron and or the power unit,this can be expensive to fault find without parts to fit to test,I would go with the magnetron first , if you would like more info let me know
Mar 02, 2015 | Siemens Microwave Ovens
Tip
MICROWAVE POWER TEST Hi Everyone, In this tip I will show you how to easily test...
Hi Everyone,
In this tip I will show you how to easily test your Microwaves power. If it is sufficient, or if it is not heating effectively anymore.
Non heating Microwaves are a common issue, and the most likely component that is faulty is the Magnetron - These days Magnetron's are quite expensive (usually about 50% the price of a new Entry Level Microwave). Low heating could mean a Magnetron becoming faulty (unlikely, as a Magnetron either works, or it doesn't work)
Tools required: A Normal Glass (Heat-resistant, in other words Microwave friendly), Water (Room Temperature) , a Centigrade Thermometer (Can get this at any Pharmacy)
Procedure:
1) Fill a glass with approx. 125 ml water. Use water at room temperature (from the tap), avoid using refrigerated water as this will work against the test we are doing.
2) Measure the initial temperature of the water with the thermometer (It should be between approx. 10 & 20 degrees).
3) Place the glass with the water about 2 cm away from the center of the Microwave Oven plate.
4) Heat the water at full power (The highest setting possible on your Microwave) for 70 seconds.
5) Stir the water (For 5 - 8 sec).
6) Measure the final water temperature with a thermometer.
7) If the increase is 45 degrees or more, then your microwave is heating sufficiently, if not it could mean replacing the Magnetron, or purchasing a new Microwave.
I hope this guide as helped you. If it has, please rate it accordingly.
on Apr 23, 2011 | Microwave Ovens
Main oven wont heat
Thank you for your post, Allison! I understand that you are having concerns with your microwave oven heating. This could be because of several factors, such as: loss of power to the microwave, a displayed error message or a faulty magnetron. Please ensure that your household power circuit breaker is not tripped and that your appliance is not displaying an alpha-numeric error message or code on your control panel. If you notice an error message please comment and let me know so that I can help you further. Otherwise, if you do not notice any errors and have sufficient power you are more than likely experiencing a faulty magnetron. The magnetron is the sole component that allows the microwave to heat. This is not a typical do it yourself repair so I recommend contacting a professional to confirm this and complete any necessary repairs.
Thanks,
Chris
Dec 18, 2013 | Electrolux E30MO65GSS Convection Microwave...
Siemens Innowave 'n890l6u5 rsgs'
sadly you destroyed the unit only option is replacement of same
Aug 11, 2017 | Siemens Microwave Ovens
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
Kenmore microwave model 721.80033700 won't heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Glass door for a Siemens microwave hf 879
I've the same problem. Inside glass broke while heating.
May 20, 2010 | Siemens HF87950GB Convection Microwave...
Ge over the renge microwave runs but no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hjdhjd
Feb 13, 2010 | GE JVM2070 Microwave Oven
Microwave works but won't heat
heatman101
iooit
Aug 09, 2008 | GE JES1238 Microwave Oven
Siemens HF87950GB Convection Microwave Oven Logo
138 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
