Question about Home
We have just moved my girlfriends hot tub from her old home to her new place. I was intending to just put a plug on the wires and plug it into an external socket at my girlfrienSs new house. However when i came to do this there were 2 black wires and a green and yellow (earth). HOW DO I DO THIS
  • 308 Answers
Depending on if the motor for the tub is 120v or 215/230v follow these instructions....
120v - connect each black wire to it's own spade terminal and the green/yellow wire to the round ground tab on the new plug.
215/230v - follow the same procedure, but when complete, make sure that you are connecting to a 215/230v outlet, if it is a standard 120v outlet, you will most likely blow a fuse, or even worse the motor.
There should be a name plate on the motor that will tell you if the motor is 115v or 215/230v.
If the motor is 120v, you will have one "Line" wire, and the other is "Neutral" In A/C wiring it does not matter which is which due to the fact that the "Line" and "Neutral" alternate there current 60 times a second
If the motor is 215/230v then both the black wires are considered "Line", meaning that they both are carrying current at all times.
Hope this helps
Posted on Jul 31, 2010
Plug wires diagram
Place plug wires in order, from shortest to longest on ground beside vehicle, or on a portable work table. Carefully match the length of the shortest one to the shortest on motor. Lay the new wire alongside the old and remove one end of old, attaching the same end of the new one and then do the same to the other end. Fairly simple so far, so repeat this procedure with all the remaining ones one at a time, being carefull to only remove one end at a time, and also be sure of plug wire lengths. Note wires are routed the way that they are to keep them from contacting any hot surfaces or moving parts. Last step: put hands on hips and admire the fine job you just did!
Nov 11, 2013 | 1997 Mercury Mountaineer
Tip
Single handle tub mixet hot and cold water valve
if you have a single handle tub valve and it starts to not work properly for instance if its gettin less hot water and more cold water it may be time to replace the mixet stem ,what you will need a flat head screw driver a philips head screw driver a pair of needlenose and a pair of channel locks turn off the water main to your home, remove the handle there is a clip at top remove the keeper clip then pull out the old stem take it to your home depot get a new one also get some stem grease to put around the black rubber o rings so your stem last for a long time the grease is also for the handle turns eazy put back in put clip back just remember how you took old one out so it is in the same position turn water main back on and try it out
on Mar 12, 2010 | Plumbing
The heater isn't heating the hot tub and a code comes up "PRS" and says to clean/service the filter. how can i do this myself at home to get it to heat the hot tub again.
PRS means that the heater is not sensing pressure in the plumbing.
Make sure that the pump basket is clean.
Make sure pump is flowing freely as it should (no blocked skimmers or returns)
Make sure filter pressure is where it should be. If this is a cartridge filter, remove and clean the cartridges. If its a sand filter or a DE filter just do a long backwash.
Make sure any heater bypasses are closed.
If you know the water is flowing freely, and you still see this code, you must replace the pressure switch. It should cost about $35 for the part at a retail store. It is located on the top side panel opposite of the water connections. It looks like a round disk screwed into the header, with two wires coming from it. Just unscrew the old part, and using teflon tape, screw in the new part.
Connect wires, and restart the heater. It does not matter in which place you put the wires.
Dec 30, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Dont know where to start with placing new plug wires on my '96 360 engine.I have the firing order, but where do I start my first plug wire? Do you have a diagram ?
Take the old wires off one at a time. Compare the old wire to the new wires and find the new one that is the same length as the old one. put the new wire on routing it exactly as the old one was routed. Move on to the next wire. As long as you replace them one at a time you can't mess anything up.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 08, 2010 | Dodge Ram B350 Cars & Trucks
I wanna flush and change tr. oil at home.Is it hard?
no just takes about 1 hour you need to get a tranny filter and 6 quarts tranny fluid and a drain pan then you have 12 bolts holdin the pan in {trick if you only loosen 3 lower bolts you can control the flow of where oil comes out} then you take out old filter spray all bottom there with carb cleaner to clean out the gunk and scrape old gasket off then put in new filter and new gasket and put bolts back in then fill her up and your done you do need get a new gasket tooooo
Sep 25, 2010 | 2002 Toyota Sienna
How do you replace a flow switch in a spa, or hot tub
turn off the power to the spa. remove the cabinet under the topside remote to expose the equipment compartment. You should see the flow switch, it's usually a threaded 3/4" plug with a single grey wire coming out of it. Most of them are threaded into a tee or a special transparent fitting. If the water level in the spa is above the flow switch, you may have to drain the spa down unless you're very fast about getting the new switch in. Unthread the old switch and thread the new one in. Follow the wire on the old one to the spa pack. You'll have to remove the screws on the cover to expose the circuit board. Follow that wire into the spa pack to see where on the circuit board that it is plugged in. It may be good to run the new wire to have in place as soon as you unplug the old one you can install the new one with no question as to where it plugs in.
Reinstall the cover on the spa-pack and turn the main power back on. Make sure that the arrows on the new flow switch are facing the correct direction (direction of flow). Once you have the spa on and it starts back up, run everything to check for leaks and proper operation. If the flow switch was the only problem, all your faults should be cleared and you should be in good shape. If there are no leaks, you can reinstall the cabinet panel.
The new switch should already have teflon tape on the threads, if not, use teflon tape, apply the tape in the direction as if you were threading a nut onto the threads. You only need a few wraps of teflon tape, too much can crack the fitting you threat the new flow switch in to.
Nov 03, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
I just picked up a hot tub and i need to know how to wire it for 110.
First you need a supply or a home run to your panel, or you can tie on to another circuit. With hot tubs you should ALWAYS use a GFCI (ground fault circuit interrupter) breaker or device or you could die from electrical shock (water and electricity don't mix!!!!!!) if its a hot tub its not likely that its 120v because of the heating elements and pump usually they are 220-240v make sure you are using the right voltage or you could burn up any controls and your wasting money. Make sure there is a good ground, GFCI devices need a ground to work properly. Other than that, black or other dark colors are hot, white and gray are neutral, green is always ground. Get yourself a tester and find the hot lead it should read 120v to ground or neutral. Be very careful with wiring its not always done correctly you have to check with a tester. With 220-240v you have two hots, a ground,and no neutral unless the appliance specifically calls for it. this can be very dangerous and if you don't have any experience you should probably call a professional. GOOD LUCK
Oct 30, 2009 | Electronics - Others
How to turn on hot tub
Check at the plug in if it has a normal plug like in your home first. Should be a set of buttons there, called a GFI. One is test, and the other reset.Push reset to see if spa comes on. Most spas dont have an actual on button. Check breaker box for popped breaker also, maybe tub is having problems, and needs a service call. Also larger tubs ussually jave a gfi or fuse box outside, close to tub. Kirk
Dec 01, 2008 | Pool & Spa
Using 4 wire plug on 3 wire dryer
YES TAKE THE GROUND WIRE OF THE NEW PLUG AND CONNECT IT TO THE FRAME OF THE DRYER UNDER AN EXISTING SCREW OR USE A SELF TAPPING SCREW THE FOUR WIRE SYSTEM WAS PUT INTO THE CODE MOSTLY TO INSURE GOOD GROUNDING ON MOBILE HOMES AND THE METHOD WILL WOKE FINE AS I HAVE GIVEN YOU
Nov 16, 2008 | GE Dryers
Home Logo
46 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
