Question about New Balance 1400 Treadmill
The belt on my New Balance 1400 has become kinked up. I tried adjusting it by loosening it up, straightening it out, then tightening it back up, but it kinks up again. Before it kinked up for the first time, I noticed the belt slipping a bit. Any help is much appreciated.
    President:
  • New Balance Master
  • 832 Answers
Unfortunately once the belt has a crease that all she wrote. Belt replacement is the next step.Call Fitness Quest they are the makers of your treadmill @ 1-800-321-9236
Posted on Jul 31, 2010
Testimonial: "Thanks for the help! "
  • Paul Malley
    Paul Malley Dec 26, 2015
    The belt on one of my treadmills creased
    I noticed that on the underside there was a cotton cloth liner that was breaking up.
    I ripped that off, and whilst the belt is not exactly wonderful it runs ok, which it didn't do before.
    Tensioning it up took most of the adjustment.
    Good for a few more miles perhaps!!!
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
Belt keeps sliding from side to side
You have not properly aligned and / or adjusted the tension. If it is SLIDING then you do not have enough Rear Tension. Once you get the right amount of REAR TENSION, then you have to adjust the left right (balance the belt). Your belt should go straight, right now you have it too far to the FRAYED SIDE. Turn the Machine on, have your Hex Wrench in the Bolt and turn it slowly CW and as the belt come back to Center, watch the adjustment. If it continues to go past, then loosen it a little until you have the right balance. Remember REAR TENSION FIRST... THEN BALANCE for Alignment
Mar 03, 2014 | Proform Crosswalk 395 Treadmill
Timing belt
TIMING BELT & SPROCKETS R & I
NOTE: Some procedures may differ slightly due to engine
construction.
Removal
1) Remove all necessary air ducts. Position No. 4 piston at
TDC of compression stroke. Align timing marks. See Fig. 2. Remove fan
and fan shroud. Remove belts. If necessary, remove radiator and
splashguard.
2) Prevent engine from rotating and remove crankshaft timing
pulley retaining bolt. Remove upper and lower timing belt covers.
Remove spring from tension pulley. Loosen adjusting bolt and move
pulley toward water pump. Remove timing belt.
CAUTION: Ensure pistons are at TDC when rotating camshaft or damage
may result.
Inspection
1) Handle timing belt carefully. Avoid twisting or kinking
belt. Do not allow belt to become contaminated by water, oil, dirt or
other contaminates. Inspect belt for cracks or damage. If necessary,
replace.
2) Measure tension pulley spring length and force. Spring
length should not exceed 2.76" (70.2 mm) and spring force should not
be less than 197-347 lbs. (27-48 kg).
3) Replace tension pulley spring if not within specification.
Installation
1) Pull tensioner fully toward water pump side and
temporarily tighten retaining bolt. Ensure No. 4 cylinder is at TDC on
compression stroke by rotating crankshaft until keyway aligns with
mark on front crankshaft seal housing (12 o'clock). Rotate camshaft
until timing mark on cam gear (arrow) aligns with mark on upper
camshaft cover (notch). See Fig. 2.
NOTE: When timing marks are aligned as stated above, No. 4 piston
is at TDC on compression stroke.
2) Position timing belt over crankshaft sprocket, oil pump
sprocket, camshaft sprocket and tensioner in that order. Ensure belt
is positioned in sequence given and without slack between sprockets.
Loosen tension sprocket adjusting bolt allowing spring tension to
tighten belt. Tighten adjusting bolt temporarily.
3) Temporarily install crankshaft pulley bolt and rotate
crankshaft 2 complete revolutions in opposite direction of engine
rotation, until marks on crankshaft and front oil seal retainer are
aligned again. See Fig. 2. Loosen tensioner lock bolt, allowing
tesioner spring to fully adjust tension. Tighten tensioner lock bolt.
4) Install timing belt covers. To complete installation,
reverse removal procedures. Tighten all bolts to specification. See
TORQUE SPECIFICATIONS table at end of this article.
Fig. 2: 2.3L & 2.6L Timing Alignment Marks
Courtesy of Isuzu Motor Co
Dec 13, 2010 | 1989 Isuzu Pickup 2WD
I want to change two belts (A/C and Alternator) on my 1999 Mitsubishi Mirage 1.5 car. What steps I am suppose to do.
First, feel the tightness of your belts. You will have to tighten the new belts to the proper tightness. If they are too tight, they will wear the bearings prematurely. If they are too loose, they will slip.
Alternator Belt Removal
  1. Loosen the alternator lock nut.
  2. Loosen the adjuster bolt.
  3. Rotate the adjuster bolt counter clockwise to release the tension on the belt.
  4. Remove the belt.
Similarly for the compressor belt
  1. Loosen the lock nut.
  4. Remove the belt.
5. Install the new compressor belt
6. Rotate the adjuster bolt clockwise until the belt is tight like it was before you removed it.
7. Tighten the lock bolt.
8. Install the new alternator belt
9. Rotate the adjuster bolt clockwise until the belt is tight like it was before you removed it.
10. Tighten the lock bolt.
11. enjoy life
Oct 12, 2010 | 1999 Mitsubishi Mirage
How do you change alternator belt on 1997 mazada 626
heres a diagram to help you, loosen the bottom bolt a few turns then loosen the top bolt then loosen adjusting bolt to loosen belt, use the adjuster to tighten the new belt then tighten top and bottom bolts, hope this helps,8a841eb.gif
Oct 04, 2010 | 1997 Mazda 626
My balance shaft belt broke while I was driving. It stripped some of the teeth off the timing belt and Im pretty sure it jumped time. I need a diagram to show the timing marks and how to get it back in...
see diagrams from autozone.com. Cam sprocket has an "UP" label, but also 2 scribes on the sides to align to upper head surface. The critical part of the job is keeping tension on the side of the belt that is opposite from the tensioner as the tensioner is released onto the belt. The timing marks must be aligned when the job is done.
4256a1c.gif To install:
  1. Install the camshaft timing sprocket so that the UP mark is up and the TDC marks are parallel to the cylinder head gasket surface. Install the key and tighten the bolt to 27 ft. lbs. (37 Nm).
  2. Install the crankshaft sprocket so that the TDC mark aligns with the pointer on the oil pump. Install the spacers with their concave surfaces facing in. Install the key. If equipped, install the TDC sensor assembly back into position before installing the timing belt.
  3. Install and tension the timing belt. Use a 6 x 1.0 mm x 25 mm bolt threaded through the cam belt tensioner plate to temporarily hold the tensioner.
  4. Temporarily install the crankshaft pulley and rotate the crankshaft counterclockwise 5-6 turns to be sure the belt is properly seated.
  5. Set the No. 1 piston at TDC for its compression stroke.
WARNING If any binding is felt when adjusting the timing belt tension by turning the crankshaft, STOP turning the engine, because the pistons may be hitting the valves.
  1. Rotate the crankshaft counterclockwise so that the camshaft pulley moves only 3 teeth beyond its TDC mark.
  2. Loosen, then retighten the temporary cam belt tensioner bolt.
  3. If the rear balance shaft sprocket/gear case assembly was removed, perform the following:
    1. If the rear balance shaft was moved, rotate the balance shaft until the 6 x 1.0mm x 100 mm bolt can be installed into the maintenance hole to the scribed line.
    2. Align the notch of the balance shaft sprocket edge with the pointer on the gear case. Install the rear balance shaft sprocket/gear case assembly using a new O-ring coated with fresh engine oil. The balance shaft sprocket should be installed in the TDC position. The pointer on the gear should align with the pointer on the oil pump housing plate.
    3. Tighten the mounting bolts to 18 ft. lbs. (25 Nm).
  4. If the front balance shaft sprocket was removed, perform the following:
    1. Install a suitable and sturdy screw driver or drift through the maintenance hole in the shaft behind the sprocket to hold the front balance shaft.
    2. Install the front balance shaft sprocket and mounting nut. Torque the nut to 22 ft. lbs. (29 Nm).
  5. Make sure the balance shafts and crankshaft are in the TDC position.
  6. Remove the crankshaft pulley, and if removed, install the balance shaft belt drive sprocket.
  7. Install the balance shaft belt, making sure the balance shafts and sprockets are still in the TDC position.
  8. If removed, install the balance shaft belt tensioner and tension the balance shaft belt.
  9. Loosen, then retighten the tensioner adjusting nut to 33 ft. lbs. (45 Nm).
  10. Remove the 6 x 1.0mm x 100mm rear balance shaft holding bolt.
  11. Temporarily install the crankshaft pulley and rotate the crankshaft 2 revolutions counterclockwise, stopping at TDC.
WARNING If any resistance is felt, stop immediately and determine the cause.
  1. Recheck that all of the TDC marks align for both the camshaft and balance shafts.
  2. Loosen, then retighten the tensioner adjusting nut to 33 ft. lbs. (45 Nm).
  3. Remove the 6 x 1.0 mm x 25 mm bolt used to secure the camshaft timing belt tensioner.
  4. Remove the crankshaft pulley and install the lower cover.
  5. Install the crankshaft pulley, lubricate the bolt threads and both sides of the crankshaft pulley bolt with fresh engine oil and tighten the crankshaft pulley bolt to 181 ft. lbs. (245 Nm). Do Not use an impact wrench.
See Figures 19 and 20
              Fig. Fig. 19: Holding the rear timing balancer shaft-4-cylinder Odyssey
            Fig. Fig. 20: Aligning the front timing balancer shaft-4-cylinder Odyssey
            1. Install the upper timing cover and the valve cover. Be sure the seals are properly seated.
            2. Install the side engine mount. Tighten the through-bolt to 47 ft. lbs. (64 Nm). Tighten the mount nut and bolt to 40 ft. lbs. (55 Nm) each.
            3. Remove the floor jack.
            4. Install and tension the alternator belt.
            5. Install the power steering pump and tension its belt.
            6. Install the splash shields.
            7. Reconnect the positive and negative battery cables. Enter the radio security code.
            8. Check engine operation.
            Sep 20, 2010 | Honda Odyssey Cars & Trucks
            How do i put timing belt and water pump?
            REMOVAL & INSTALLATION of timing belt: Fig. 1: View of the timing belt cover 91163p64.gif
            Fig. 2: Loosen then timing belt tensioner using a ratchet and short socket 91163p65.gif
            Fig. 3: Matchmark the direction of rotation of the timing belt 91163p67.gif
            Fig. 4: Once loose, pull the belt off the camshaft pulley 91163p71.gif
            1. Disconnect the negative battery cable.
            2. Turn the crankshaft to align the timing belt matchmarks and set cylinder No. 1 to Top Dead Center (TDC) on the compression stroke. Once in this position, the engine must NOT be turned or disturbed.
            3. Remove all necessary components to gain access to the cylinder head and timing belt covers.
            4. Remove the cylinder head and timing belt covers.
            5. There are 2 belts in this system; the one running to the camshaft pulley is the timing belt. The other, shorter one drives the balance shafts and is referred to as the balancer belt or timing balancer belt. Lock the timing belt adjuster in position by installing one of the lower timing belt cover bolts to the adjuster arm.
            6. Loosen the timing belt and balancer shafts tensioner adjuster nut, but do not loosen the nut more than 1 turn. Push the tensioner for the balancer belt away from the belt to relieve the tension. Hold the tensioner and tighten the adjusting nut to hold the tensioner in place.
            7. Carefully remove the balancer belt. Do not crimp or bend the belt; protect it from contact with oil or coolant. Slide the belt off the pulleys.
            8. Remove the balancer belt drive sprocket from the crankshaft.
            9. Loosen the lockbolt installed to the timing belt adjuster and loosen the adjusting nut. Push the timing belt adjuster to remove the tension on the timing belt, then tighten the adjuster nut.
            10. Remove the timing belt. Do not crimp or bend the belt; protect it from contact with oil or coolant. Slide the belt off the pulleys.
            11. If defective, remove the belt tensioners by performing the following:
              1. Remove the springs from the balancer belt and the timing belt tensioners.
              2. Remove the adjusting nut.
              3. Remove the bolt from the balancer belt adjuster lever, then remove the lever and the tensioner pulley.
              4. Remove the lockbolt from the timing belt tensioner lever, then remove the tensioner pulley and lever from the engine.
            12. This is an excellent time to check or replace the water pump. Even if the timing belt is only being replaced as part of a good maintenance schedule, consider replacing the pump at the same time. To install:
            13. If the water pump is to be replaced, install a new O-ring and make certain it is properly seated. Install the water pump and retaining bolts. Tighten the mounting bolts to 106 inch lbs. (12 Nm).
            14. If the tensioners were removed, perform the following to install them:
              1. Install the timing belt tensioner lever and tensioner pulley. NOTE: The tensioner lever must be properly positioned on its pivot pin located on the oil pump. Be sure that the timing belt lever and tensioner moves freely and does not bind.
              2. Install the lockbolt to the timing belt tensioner, do not tighten the lockbolt at this time.
              3. Install the balancer belt pulley and adjuster lever.
              4. Install the adjusting nut and the bolt to the balancer belt adjuster lever. Do not tighten the adjuster nut or bolt at this time. NOTE: Be sure that the balancer lever and tensioner moves freely and does not bind.
              5. Install the springs to the tensioners.
              6. Move the timing belt tensioner its full deflection and tighten the lockbolt.
              7. Move the balancer its full deflection and tighten the adjusting nut.
            15. The crankshaft timing pointer must be perfectly aligned with the white mark on the flywheel or flex-plate; the camshaft pulley must be aligned so that the word UP is at the top of the pulley and the marks on the edge of the pulley are aligned with the surfaces of the head.
            16. Install the timing belt over the pulleys and tensioners.
            17. Loosen the bolt used to lock the timing belt tensioner. Loosen, then tighten the timing belt adjusting nut.
            18. Turn the crankshaft counterclockwise until the cam pulley has moved 3 teeth; this creates tension on the timing belt. Loosen, then tighten the adjusting nut and tighten it to 33 ft. lbs. (45 Nm). Tighten the bolt used to lock the timing belt tensioner.
            19. Realign the timing belt marks, then install the balancer belt drive sprocket on the crankshaft.
            20. Align the front balancer pulley; the face of the front timing balancer pulley has a mark, which must be aligned with the notch on the oil pump body. This pulley is the one at 10 o'clock to the crank pulley when viewed from the pulley end.
            21. Align the rear timing balancer pulley (2 o'clock from the crank pulley) using a 6 x 100mm bolt or rod. Mark the bolt or rod at a point 2.9 in. (74mm) from the end. Remove the bolt from the maintenance hole on the side of the block; insert the bolt or rod into the hole. Align the 2.9 in. (74mm) mark with the face of the hole. This pin will hold the shaft in place during installation.
            22. Install the balancer belt. Once the belts are in place, be sure that all the engine alignment marks are still correct. If not, remove the belts, realign the engine and reinstall the belts. Once the belts are properly installed, slowly loosen the adjusting nut, allowing the tensioner to move against the belt. Remove the pin from the maintenance hole and reinstall the bolt and washer.
            23. Turn the crankshaft 1 full turn, then tighten the adjuster nut to 33 ft. lbs. (45 Nm). Remove the bolt used to lock the timing belt tensioner.
            24. Install the lower cover, ensuring the rubber seals are in place. Install a new seal around the adjusting nut, DO NOT loosen the adjusting nut.
            25. Install the key on the crankshaft and install the crankshaft pulley. Apply oil to the bolt threads and tighten it to 181 ft. lbs. (250 Nm).
            26. Install the upper timing belt cover and all applicable components. When installing the side engine mount, tighten the bolt and nut attaching the mount to the engine to 40 ft. lbs. (55 Nm) and the through-bolt and nut to 47 ft. lbs. (65 Nm).
            27. Connect the negative battery cable.
            For water pump removal and installation contact me:
            Jul 12, 2010 | 1997 Honda Civic
            2005 Nissan Sentra 1.8S, with AC - how to replace belts?
            first of all you don't have to loosen the pulley,this will no solve the problem,well you already loosen the adjuster,good,bot thing you have not done i will tell you now,on the power steering pump where the belt pass there is also a bolt that hold it ,you must loosen that also,then after you will see the pump moving on the two position that means you will see the belt loosen on 1 position an d the position it will tight the belt,try that man.............
            Aug 23, 2009 | 2005 Nissan Sentra
            How do you adjust tension for drive belt
            first you need to figure out if you have an automatic tensioner or an adjustable one. so look at the pullies which ones are not accesories (ie not an alternator pully, power steering.) some pullies will just be on there own not driving anything. is this pully connected to something like this O>o <--this end is the pully.
            pully mounting bolt ^ ^arm with hole for rachet
            or does it look like the pully is attached to a threaded pole.
            the auto adjuster need a rachet to pull back on it (because it's spring loaded) while you install the new belt.
            the other need the nut on the pully loosened and the threaded pole loosened will move the pully removing tension from the belt (opposite will tension the new belt).
            tighten belt until you can only twist it in half.
            Jun 25, 2009 | 2003 Toyota Camry
            Hoover 200 m unbalanced and noisy on spin cycle can't balance it
            hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
            Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
            Step 2: Remove the old belt and stretch a new one into place on the pulleys.
            Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
            Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
            Sep 13, 2008 | Washing Machines
            New Balance 1400 Treadmill Logo
            861 people viewed this question
            Top New Balance Exercise & Fitness Experts
            Matt Olenzek
            Matt Olenzek
            Howard
            Howard
            Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
