Question about Frigidaire Ovens
I HAVE an old Frigidaire Electric Range Mod RS 30-32EM 29172 on the oval tag. I can not find parts reference. I am only looking for a couple of things now. One is an oven rack. it is 22 7/8" x 15 3/4". I see a newer rack which is 16 1/8" which is too big, I think. the oven door may not close. I'm also looking for a heat control rheostat,dial for the rt front burner. I am having a tough time locating. Thanks
SOURCE: Oven doesn't heat
Its are a wall oven or range???
Model number please
Posted on May 11, 2008
  • 833 Answers
SOURCE: Frigidaire ES400 oven controls
Contacts are fused.  Get a new one, cut the power and replace it.
Posted on Nov 12, 2008
  • 28 Answers
SOURCE: lighting an old Frigidaire gas oven
Sounds as though the pilot light in your oven went out. On the inside of the oven there should be a small hole about the size of a 50cent piece on the floor of the oven. Turn on the gas for the oven, light a matchstick or rolled up piece of paper, stick it into that hole and it should light, monitor the oven for 30 seconds to see if it starts to heat. SAFETY 1st!
Posted on Dec 23, 2008
  • 17 Answers
SOURCE: Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Posted on Jun 09, 2009
protek480
  • 1723 Answers
SOURCE: Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 20, 2009
Need part number for LP conversion kit
Good Morning Friend,
I understand you are looking for the part number for the LP conversion kit for your Frigidaire range. The LP conversion kit part number is PCK4200. I hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Oven elements not working
Good Afternoon Friend, thank you for your inquiry!
I see that you are having trouble with both your bake and broil element on your Frigidaire range. Can you think about what may have happened prior to this occurrence? For instance, did you notice any error codes or strange noises? Also, do you have an electric or gas range? May I please have your model number? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side. With this information I can assist you better in pinpointing the problem. Thank you! -Z
Jun 06, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
What is the input - 120v or 240v?
Hello Seth Kwao - If you are referring to a gas range it is recommended to use a receptacle of 120v and a receptacle of 220v for an electric range.
Sep 25, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How i take the top off
to remove the top to access the surface burners their should ba couple screws in between the lower part of the cooktop and the upper part of the oven door. by opening the oven door and looking up at the bottom of the cooktop you should see those screws.
BEFORE ATTEMPTING TO REMOVE THOSE SCREWS BE SURE TO DISCONNECT POWER TO THE RANGE
GENE
Sep 18, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I need a oven temp probe for mdl fgf352sbwa . the probe body is 10" long . Anywhere I search I only see reference to 3" and 6" long probes. Any Ideas.
The temperature probe you are looking for is actually part of the thermostat and not available seperately. Part number is 316028600. Search this number on ebay for considerably better prices.
Eric
Aug 17, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Okay,
When you purchase.
How/when it happen.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire oven overheating
I would say that the oven thermostat is malfunctioning, and you will probably need a new one fitting.
Make sure the sensor inside the oven has not become detached, as this will make a differance.
Plz leave feedback.
Ta.
Dec 09, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
63 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
