Question about Goodman GMS90703BXA Heater
My son has a Goodman GMNT furnace in his cabin. Last spring the furnace would try to start and quit. We would turn the thermostat up and restart it a couple more times before it would keep working. Now, nothing works. We can't even get the furnace fan to turn on manually. Thermostat problem, curcuit board problem or where do we start looking? Thank you.
    President:
  • 1,515 Answers
Hi, on the board you will have a 3 to 5 amp fuse, plug in type just like your auto fuses. It probably blew it which shuts power down on the furnace. It kill power to the thermostat also. If the furnace would try and start and shut back off, you will have what is called a flame sensor that runs along side of the pilot. It is white porcelein, round about about 5" long with a metal tip coming out the end. The other end plugs on the board. The metal tip is in the pilot flame and when they get dirty they will shut the unit off very fast. You can use steel wool to clean the tip or real fine grade sanding cloth. After cleaning this flame sensor it continues to cycle on and off, you should have a led light on the board that will flash. It may have a number of flashes, for instance 4 flashes long and 2 short ones what ever the amount. On the inside of the panel, you will have a code chart and it will point you to the problem according to how many times it flashes. They almost trouble-shoot them selves. If you remove the panel, most have a kill switch on them for safety. So, when you take it off and you have no power to anything and the fuse is good, this door panel switch is around the perimeter that opens the contacts just like your home refrigerator does for the light but works backward the that. Tape it down and it will restore power so you can leave the panel off when checking this out. This will be a easy fix for you. Please keep me posted and be kind when rating me as I know you will. Let me know the outcome as I keep all of your information on hand.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
PS Be sure to remove tape if you have a switch and make sure the panel is installed right so it closes the switch. Best to you.
Posted on Aug 01, 2010
Electric furnace/air handler short cycles
check that the replaced thermostat is the same temp degree setting of the last one
Dec 16, 2013 | Goodman Heating & Cooling
My Goodman GMNT 120-5 furnace is not coming on.
First I believe you will need to begin by reading this=>
Goodman GMNT120-5 Service Instructions
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download.
If you have questions please let me know, Sea Breeze
Nov 03, 2012 | Heating & Cooling
Goodman GMNT furnace - should I be able to get remove the access control panel easily?
Check the front of the unit and you should see 4 5/16 screws . I believe the outer 2 screws undo the top cover .Remove it first, and remove the inner 2 screws, and the lower door will come off. Good luck. Vern
Feb 21, 2010 | Goodman GMS90703BXA Heater
I have a goodman gmnt 100 b furnace 2 stage when the gave valve turns on and floods the heat exchanger with flame then the squirl cage fan turns on and i loose the the flame
If you are getting flame distortion when the blower comes on it usually means a cracked heat exchanger which can lead to carbon monoxide, get your furnace checked by a qualified tech..
Jan 31, 2010 | Goodman Furnace Draft Inducer Blower ...
Goodman GMNT furnace goes into 'lock-out'.
The brain has to have constant verification of flame. If the burner ground is corroded then you will get the condition you prescribe.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 08, 2009 | Heating & Cooling
I have a goodman GMNT gas furnace Propane it lights off I have a blue flame for about 3 seconds I hear a click on the circuit board and the flame goes out this is doing it constantly. could you please help...
Hi!!! If the flame turns on then off and on then you should change your flame sensor on the gas furnace..YEs flame sensor is shorted..The flame sensor is located by the valve burners it has one wire and is white..Good luck..
Jan 03, 2009 | Heating & Cooling
Furnace start buts shuts off
It sounds like you have an obstruction in the exhaust vent. Thats why when you bybass the pressure switch it runs ok. Steve
Dec 15, 2008 | Goodman GMS90703BXA Heater
Support on changing out the heat exchanger on gmnt 080
1st, take a picture of where each wire goes to. Look in the owners manual for an exploded view of how it goes together. The heat exchanger most likely comes out from the front of the furnace. You will have to remove and reinstall every componant inside the furnace to get it out. Suggestion, replace the whole furnace. It will be cheaper.
Sep 18, 2008 | Goodman Heating & Cooling
Goodman GMS90703BXA Heater Logo
124 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
