Question about Samsung SyncMaster 940B Monitor
Hi. I want to power my syncmaster 940b from 12 volt in a boat. do you have a wiring diagram?
  • krister_halv Aug 01, 2010
    Thanks !!!
    Inverter is a way to run the monitor but its a waste of energy to convert 12 v to 220 v and then back to 13 v.
    I will look into the manual later.
  • 11,361 Answers
Here are the service manual: http://elektrotanya.com/?q=showresult&megnev=Samsung%20&megnev2=940B%20&kategoria=&kat2=all
You may be better off getting a small inverter that convert 12vdc to 120vac @ 100watts or more.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 01, 2010
12 24 SYSTEM 2 BATTERYS BOTH WIRED SEPARATE GOING TO THE BOW OF BOAT 4 HOLE PLUG 3 WIRES GOING TO TROLLING MOTOR 12 24 SWITCH 12 OFF 24 ONLY RUNS ON 12 AND STOPS ON OFF BUT NOTHING ON 24
It is likely to be a function of the switch to place both batteries in parallel in the 12 volt position and in series in the 24 volt position - this is likely to make the switch and the wiring fairly complicated as the motor could be wired internally in a variety of ways and the switch will also need to send the right voltage down the right wires.
I suggest you first ensure both batteries are fully charged and in good order. Once you are certain of that it is time to inspect the switch and wiring and test the voltages. A wiring diagram would make the task much easier.
Mar 14, 2018 | Boating
Boat wiring diagrams
Check you have a real good ground at the the guage and the tank sensor. Most likely (black) wire. 12 volt systems on boats are often ground problems.
Aug 14, 2014 | Boating
Wiring diagram for installing a tv on a boat
Depends on whether this is a 12 Volt TV or a 120Volt. If a 12 volt, then fused and direct to battery. This is done this way as you do not want any other circuit to feed through it. You may want to add a diode to insure that if this is a unit with its own batteries, there is no reverse draw.
If a 120Volt, you need a power inverter which is also isolated from other systems. For shore power 120Volt, there should be a circuit panel and it may have open taps.
Jan 24, 2012 | Boating
My samsung 940b it has a clear bright screen ( as normal ) just for 2 seconds then the screen turns dark but you can see very very dim Window logo.Turn off the power ( does not matter for how long ) when...
Shine a flash light onto the monitor, if you can see icons/desktopon the screen then you know you need a new monitor!
You should be covered under warranty!
Mar 02, 2011 | Samsung SyncMaster 940B Monitor
Wanting to install motorguide 24v trolling motor in boat, will it work on just 12 v system
No. you can put in extra batteries and use it, but you must remove you charging system from them to use it that way. Not really practical.
Mar 21, 2010 | Electrical Supplies
Where can I find a wiring diagram to install a generator into a boat? I know how to wite the 110 volt side but where do I connect the 12 volt power from the generator into the 12 volt distribution panel?
Installing a generator into a boat is critical to be done correctly. You need to contact the manufacturer of your generator for approval, and wiring diagrams. If done incorrectly (which if you are connecting 12v from gen), you may create eddy fields that can cause galvanic corrosion, not to mention electrical shock hazards.
If your generator isn't marine rated, then don't install it into a boat.
Portable generators can be used, but don't hardwire those into a boat. Just use extension cords to the appliances you want to power.
Nov 22, 2009 | Northern Tool Electrical Supplies
Convert portable batteries to 12 volt boat ststem, Eagle Super Pro I.D
Cut the battery wires where they hook up to the machine. When cut they might need some more wire spliced to them. Get some alligator clips to put on your red and black wires to hook right to your boat battery. When not in use on the boat get a small 12 volt battery, cheaper then two 6 volt disposables.
Aug 10, 2009 | Eagle Fishmark 320 Portable Fishfinder
SyncMaster 940B
Sounds like you have a video card problem. If it works on someone elses PC and not yours. Replacing this video card on your PC should fix it..
May 14, 2009 | Samsung SyncMaster 940B 19" LCD Monitor
Installing tv in boat
You can But I would not connect it directly unless I had a regulator or isolation device between the set and the boats power. if your boat has 110 volt capability just be safe and use the adaptor.
Sep 15, 2006 | Sharp Aquos LC-15S1U-S 15 in. EDTV-Ready...
Samsung SyncMaster 940B Monitor Logo
405 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
