Question about Sony CFD-606 Boombox
It appears one cd got off center, the cd stopped
It appears one cd might have gotten off center. The cd stopped playing, and now the disc trays won't open.
  • 231 Answers
SOURCE: Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Posted on Dec 03, 2007
  • 223 Answers
SOURCE: stuck cd discs
I think there are a couple of faults here. The first one is maybe a faulty motor on the eject mechanism. The second one is a faulty laser unit as it is not scanning the disc. Hope this helps.
Posted on Oct 05, 2008
SOURCE: CD tray does not open.
you need to change the motor belt charge of the tray
Posted on Jul 23, 2009
SOURCE: sony mhc-mg310av cd changer wont release cd
Check if the tray got a belt and change it
Posted on Oct 02, 2009
Warf135
  • 137 Answers
SOURCE: disc tray will not open. I've turned on &off
This problem is caused by a loose drive belt in the eject mechanism, you need to open the ps2 and replace the drive belt...
Take off the top cover, then take off the cover from the top of the dvd drive mech... then carefully remove the disc tray and you should see the belt near the front. Replace that belt and it should work fine again
On a couple of rare occasions the drive motor has been found to be faulty, but usually replacing the belt will fix it
Posted on Jan 27, 2011
Help!!!!
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
Jun 04, 2013 | Audio Players & Recorders
My RCA 5 Disc changer (RP-8065) won't open.
Try to download the service manual to your set from net. It will have all details.
May 22, 2012 | Audio Players & Recorders
Tray #1 won't read cd most of the time
Hello
Insert a lens cleanig disc into the device and play it at least three times. If the fault is due to any dirt or dust accumulated on lasser pickup lens, thei will rectify the problem. If this does not help you, the laser pickup lens unit of your device should be replaced with same type and number. The lens cleaning disc can be bought from most of the electronic sparepart shops at your town, and won't cost more. OK.
Jan 29, 2012 | American Audio Mcd810 Dual Mp3 CD Player...
RCA RS2664 Stereo wont play CD in any of the trays but seems to try to scan to play.
Hello
The laser pickup unit's lens may be dirty or dusty. Just put a lens cleaning disc into the tray, and play it at least three times, by ejecting the disc each time, and reinsert in in to. The lens cleaning disc can be bought from most of the electronic spare part selling shops at your town, and won't cost more. If it dose not help you, the laser pickup unit of your RCA device should be replaced with same type and number. OK.
Jan 25, 2012 | RCA RS2664 Shelf System
My sony dvd player will not allow the tray to eject. when the eject button is presses "tray locked" appears on the screen
Follow this procedure to lock and unlock the disc tray.
IMPORTANT: This procedure will only work while a disc is inserted in the player and when the disc is playing.
While a disc is playing in the Blu-ray Disc player, press the SYSTEM MENU button on the remote control.
After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control. NOTES:
If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode. Each time this procedure is performed the disc tray will either lock or unlock.
Jan 02, 2011 | Sony BDP-S300 Blu-Ray Disc Player
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
My 360 wont ******* play
i had the same problem. listen to your xbox cd rom and if you hear it start up and kinda skip or make a weird stopping sound then your disc drive/ cd-rom is wearing out. either send it in or do what i did and start by just giving the center to the center left above your cd-rom a nice few taps in a row while its spinning before it stops. fairly good knocks on the case will help it. i ended up really hittin mine a lot of time in row after about a month. sometimes it will put rings on your games thought but they buff out. i even took it apart but theres not much you can do
Feb 28, 2009 | Microsoft Xbox 360 Console
CD's won't play in other machines
Your problem is an easy one.....you need to "finalize" your completed/burned CD first...then it'll play in tray A...and others. Good luck....from Middleman
Feb 07, 2009 | RCA CDRW120 2-Disc CD Recorder
CD Player not working
i have an older machien here its a mini hifi system fw 540c it wont play any cd's i put into it it skips tru all 3 trays and than says no disc or disc not finilised. i had it in storage for about 4 months over a winter worked fime b4 can some one tell me what could help before i trow it away (>-_-)> ty<(-_-<)
Mar 04, 2008 | Teac GF-350 CD Shelf System
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
26 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
