Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Should the water on a pool heater come out warm and how long should it take to heat an intex 15ft pool to a reasonable temp
  • 297 Answers
Both of your questions depend on one important issue.
What is the BTU's of your heater. The more BTU's the quicker it will heat and also keep it to a specific temp easier
Posted on Jul 31, 2010
I get a E90 code on my Intex Hot Tub and it is not heating the water.
recirculation pump or heater element or temp sensor
Nov 20, 2016 | Intex Pool & Spa
Intex purespa displays current water temp but will not turn on or start filter/bubbles. Bought 1 mo ago: just set it up a week ago. Was working fine for 1 week. TrI'd unplug and reset. Any ideas??
is displayed temp less than 2 degrees than setpoint temperature ? its possible this situation will disallow the pump to go to high speed and the air infusers to work till spa heats back up , or can be a heater fault as well
Aug 15, 2015 | Intex Pool & Spa
Every time I put the heater on the jets turn on wont go off unless I turn the heater off.
some more infromation would be great, but the jets turn on to run water through the heater to heat the water, do the jets turn off once the water has heated to the thermostate set point.
Dec 20, 2014 | Intex Pool & Spa
I have a laars jandy 250 lt gas pool heater that only heats luke warm. The heater cycles normally then heats up but stops before reaching operating temp. No service lights and thermal switches are g
I do not have a handy but mine has a temperature setting at the heater and one on the remote. it is possible that one of the settings is low. the pool or spa temp is sensed at the heater and with the water temp located in the pool lines. so both the control board and the heater are sensing the water temperature.
Oct 09, 2014 | Jandy Laars Lt 250,000 Btu Heater
Why does intex filter pump warm water into pool?
im not aware of this unit having a heater on it if your saying that running the filter raises the temp in pool , ck to see if the pump is facing south east , if so move entire pool to a NW side , or add some sort of sun shade to pump
Jul 07, 2014 | INTEX Sand Filter Pump
Heater only warms water to 98 degrees
temp sensor or if control box make sure heater set to 104
Nov 27, 2013 | Sta Rite Sr333na Max E Therm Pool & Spa...
What chlorine should i use for my pool?
You should use granulated CL in this pool. Maintain CL at 5 ppm - check daily.
Jul 20, 2010 | Intex 15' X 42" Easy Set Pool Complete...
Intex spare parts
intexstore.com ,not very much
Jun 22, 2010 | Intex Easy Set Pool 15x36
How much salt to start with a 15ft round pool
Assuming you have the Intex salt water system and the easy set pool, here's what the manual says:
15x33" - 65 pounds (80 for metal frame)
15x36 - 65 pounds (100 for metal frame)
15x42 - 80 pounds (110 for metal frame)
15x48 - 95 pounds (N/A for metal frame)
hope this helps!
May 28, 2010 | Intex Automatic Salt Water System for ...
Heater will only heat spa water to luke warm.
sounds like it may be the thermostat on the heater. You are correct to check the filter first. if it is clean then it is probably the thermostat
Dec 19, 2008 | Jandy Laars Lt 250,000 Btu Heater
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
146 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
