Question about Goodman Heating & Cooling
Cant get compresser to run - Goodman Heating & Cooling
  • llee71 Jul 31, 2010
    I've got a line voltage control circuit on a goodman split heat pump modle # WM10FR/15FR
    can't get the contactor to pull in
  • 532 Answers
Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that can not start.Many times The device you will use is the "Super-Boost.The Super-Boost could save you from having to purchase a new air conditioning compressor or system.
The Supco super boost can save stuck compressor by increasing the compressor's starting torque by 500%.
The Supco, Super-Boost is a solid state relay and hard start capacitor no loose parts or complicated wiring. Just wire it across your run capacitor.
I after using the super boost the compressor did not run, then you will have to replace the compressor with a new one.
Thanks.
Posted on Jul 31, 2010
  • llee71 Aug 01, 2010
    it has a line voltage contactor . the signal to call for cool does not enguage the contactor . the commpresser is fine it's on a goodman split heat pump so I'd like to know how to check for the voltage to the contactor to get the thing to run .
  • 3,230 Answers
Well if the fan of Air Conditioner run but only the compressor not run then first of all you can check out the followings -
1. Is the thermostat knob turned to the proper setting?
Is the compressor motor running?
The compressor is a football-sized case. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of the followings -
Compressor, Relay, Thermostat, May be Burnt wiring, Bad selector switch or Capacitor......
Please post the model number of your Air Conditioner for further help or information.......
Good Luck!!
Thanks
    It's a goodman model WM10fr/15fr
    The controles go to a curcit board and the contoctor will not pull in top run the compresser all the wires are ok . I can push in the contactor and the compersser wroks just fine .I just can't get a the contacter to pull in . The thing has a curcit board that runs the unit and the wires to the contactor are all ok . it does not have a 24 volt controls looks to me no transformer to check out .
1994 nissan pickup, runs rough. wont hardly run. cant find the problem.
It could be many different things. Check the vacuum lines. Check spark plugs. Check compression in engine, check fuel lines filter and injectors or carb. It's sounds like a misfire which can be caused by incorrect fuel, spark, or compression. And sometimes they run rough because vacuum pressure is incorrect or line is leaking. Start with the basics and go from there
Aug 28, 2014 | 1994 Nissan Pickup
I just replaced the fuel jets in my 88 trooper II so why wont it start now it just turns over
1988 , that is and old car, and has EFI ,?
has carb. ????? we cant guess this and 88 is transitions year.
to get help , tell engine size and if carb or EFI, we cant guess. that.
is this the gas engine or diesel, yes, they sold both, sigh.
i guess, gasoline petrol engine.
1: gave it a tune up yet?
2: does it have spark on all cylinders?
3: Yes,1&2 does test fuel work.? runs for 3 seconds?
4: will not run on test fuel check compression , a cheap tool.
5: ok compression is good, but runs on test fuel.
6: bad fueling. fix that. (cant help with out engine type, EFI type or CARB facts.
btw, all these facts are on alldata.com if you choose to look.
now the engine line up
preplexing, huh, we cant see engine, so cant help. at all.
2.0 L G200 I4 (UBS13)
2.3 L 4ZD1 I4 (UBS16)
2.6 L 4ZE1 I4(UBS17)
2.2 L C223 diesel/turbodiesel I4(UBS52)
2.8 L 4JB1 diesel I4
2.8 L 4JB1-T turbodiesel I4
2.8 L LH7 V6
2.8 L LL2 V6
Aug 11, 2014 | 1988 Isuzu Trooper 2 Door
RM 80 1986-1987 wont start
put compression gauge in spark plug hole and if its less than 100psi then you need a new oversized piston and rings ! gaskets also !!!
Jan 25, 2014 | Suzuki Motorcycles
Fuel pump wont come on
ok, you never said how you know that>?
1: pressure zero
2: crack fitting dribble tests?
3: cant hear it ( i cant either cranking,)
some cars about 1/2 only run the jump cranking and running.
not just key on. (FSM is the only book that answers this tricky question)
some cars have ECU flash updates that change this rule.
so read the TSB on that..
why not post the symptoms so pros can answer.....?????
1: cranks ok
2: no start.
3: spark is good and compression all good, on all cylinders
if compression is low on all , the timing belt fell off, and BOOM !
4: spark good, you try test fuel.
a: runs for 3 seconds, suspect no injection.
b: dont run, at all bad that, check compression at WOT on all cyl.
suspect bad injection;
A: check pressure cranking, (no key on, but cranking)
i get 30psi, its good.
i get 5 psi or 0 , bad pump or now 12vdc to pump cranking.
B: pump at 30pis cranking
so i run a NOID lamp test on all injectors,
it fails... (ask for how to go past here...... longer story....
more complex than you though , huh?
Dec 01, 2013 | 1999 Toyota Camry Solara
Mercury 2007, 3.5 4 stroke
Engines can be troublesome sometimes.. I dont think there is any reputable shop that cant quickly identify and repair this issue without too much problem. I would assume the issue lies in the carb\fuel pump area but compression reading before is mandatory to identify if the engine can run effectively first. What is the compression reading? I can steer you better once I know. Thank you, Lewis
Sep 07, 2013 | Boating
Running very sluggish losing power up hill
test the compression on the engine with a compression tester simply screws in the place off the spark plug and then kick the engine over couple off times and when the pressure cant go any higher give me that reading e.g.125psiedb0e69.jpg
Oct 31, 2009 | 2006 Honda ANF125 Innova
CD BURNER NEED TO BE CLEANED BUT YOU CANT TAKE IT OUT
go to computer store and get a CD or DVD cleaner disc. and a can of compressed air.
open the CD buner door and use the compress air, then insert the Disc and let it run few times.
Apr 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Blurry internet phot's
kindly brief your question again as i cant understand your question
Dec 03, 2007 | Computers & Internet
Heating & Cooling Logo
90 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
