Question about GE Monogram ZDBN240NBS Stainless Steel Beverage Center, Beverage Shelf on Full-Extension Slides, 12...
Making lots of noise after repairs
My undercounter beverage center stop cooling yesterday. Had a repair man came and fix it. He said it was the motor on the fan not working. Had it repair by putting in a new motor for the fan. Now it's making lot of noise.
the dr
  • 447 Answers
SOURCE: Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Posted on Dec 02, 2007
docjohn174
  • 943 Answers
SOURCE: how do you access the evaporator fan on a GE model GDS18LBR refriderator?
hi the fan is located under the floor of the fridge 6 screws on the floor remove the floor remove foam . replace the motor. thanks the appliance doc
Posted on Oct 16, 2008
sawdust46694
  • 398 Answers
SOURCE: Making a loud noise sounds like Fan
ok first i want you to pull your Refrigerator and look for a part of a loaf of bread or something else that has got inyour fan. hope this helps. if you don't find anything you may have a bad bearing on one of your fans. there are to fans one under the rear, and one inside the Refrigerator that you here when the door opens and closes pay close attn: to both!
good luck sawdust46
Posted on Aug 03, 2009
garing
  • 998 Answers
SOURCE: freezer works, refrigerator doesn't
replace control
Posted on Aug 08, 2009
SOURCE: GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Posted on Aug 14, 2009
Hi yesterday i set up the wifi on my wii console (after 3 yrs not knowing it was possible), then after kids playing few games when trying to shut down the console wouldnt power off, fixed that (hold button...
Well it sounds like thar there is an over heating problem or the fan is not working right so you could send it to the Nintendo repair center give them a call if it's under warranty it will cost nothing to have it fixed or if the warranty is up it will cost money to have it fixed. X box 360 and ps 3's consoles have the same issue too the new consoles don't last as long like the old Consoles do the old ones live a lot klonger so just play on an NES console then like I do lives a lot longer too
Oct 12, 2012 | Nintendo Wii Console
Under counter beverage air refrifgerator stop
It needs to fill the the circuit of the refrigerator motor with gas.
Feb 04, 2010 | Beverage-Air Undercounter Refrigerator one...
I have a maytag neptuen washer purchased in 1999. During spin cycle is making a lot of noise and I have repair man check and he said it would be over $500 to fix as it's the bearing and the drum would need...
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it.
Nov 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a undercounter front opening doorDelfield freeze
Hi debbie. Before you hire any repair man please price a new one. The new ones run on 1/6th the electric as the old and they are often under $200. Check them at Home Depot or lowes, even KMart which now handles the Kenmore/searss line. I believe you will end up replacing as opposed to repairing.
Aug 04, 2009 | Freezers
Condenser bad?
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Jun 03, 2009 | Beverage-Air DP46 Commercial Refrigerator
I have Marvel 6bar beverage refrigerator that suddenly stopped cooling- any suggestions on how to fix- I am trying to avoid paying a couple hundred dollars for repair thank you for your time
If light work but not running at all, then change the temp control (thermostat). If compressor and condenser fan motor are running but not cooling, then you have sealed system problem
Dec 01, 2008 | Marvel 6BAR-BD Beverage Cooler
Skybox
Go to www.apdepot.com and enter your model number under Brand :Maytag you will see a parts breakdown and you can buy it online
Oct 20, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Grinding noise,unit stopped, burning smell?
broken or slipping drive belt, motor to spin pulley defective drive clutch, spin brake fails to release to transmission is frozzen
Oct 07, 2008 | Admiral AW22 Top Load Washer
Side by side F/F is making a noise it sounds as if a fan is having trouble in the twin cooling area. could it be too cold? do I need to get an expert I to look at it?
If it is a high pitched noise that you hear it is the fan motor bearings. The evaporator fan motor should be replaced in this case.
Call the store where it was purchased from and if they have a repair man they can send him out to make the repairs for you.
May 28, 2008 | Samsung Refrigerators
My firdge is operating, but not cool nor freezing
Did he check it out and make sure its bad... these ge models are tricky... sometimes they take out the mother board with a bad evap fan motor.. seems like it should still be his problem to help fix, if his repair didnt solve the problem
Aug 28, 2007 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
GE Monogram ZDBN240NBS Stainless Steel Beverage Center, Beverage Shelf on Full-Extension Slides, 12... Logo
27 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
