Question about Jenn-Air JSD2695KES Side by Side Refrigerator
The unit is making a short cranking noise.
The unit is making a cranking noise that occurs in regular intervals (every 2-3 seconds). When I open the freezer door, the noise stops. If I open the refrigerator door only, the noise continues.
  • Jenn-Air Master
  • 3,361 Answers
Sounds like the freezer fan motor to me.
Open the freezer door.
Push in and hold the light switch on the door and listen for the noise.
It will probably be at the back of the freezer where the fan motor is located.
Could be a motor going bad or a ice buldup around rge motor blades.
Posted on Jul 31, 2010
04 mazda lifter nouse but goes away and cones back at regular intervals has over head cam
I have to ask. when is the last time you had an oil and filter change? Done on regular intervals? This sounds like sludge in the engine. It builds up and eventually closes off the oil drain ports in the head/s. The pump will pull all the oil fro the pan, because the oil can't get back fast enough, the lifters start making noise. The real damage is to the crank shaft and bearings. Pull the valve cover, if there is a lot of sludge, put it back on. Do not clean it....You can change the oil, but find the thinnest out there, 0W20. Sythethic or not. Start saving for another engine. If you do clean it. Most likely the engine won't last 2 months.
Apr 16, 2016 | Mazda Cars & Trucks
My Maxtor external hdd switches on, tries to start (spins etc) then switches off within a few seconds
Does the noise sound like a clicking noise at regular intervals?
If so, I'm afraid it sounds like the hard drive is dead and needs to be replaced.
May 20, 2012 | Maxtor Computers & Internet
Gives beeping noise at regular intervals
On my Danby this was a reminder that you had nuked something and had left it in there. If it stops when you open the door then this is all it is. It should beep about once every 15 or 30 seconds.
Other than that I don't know of any other regular timed beep that my Danby made.
Jan 23, 2011 | Danby DMW1153 Microwave Oven
When my washer is in the wash cycle, it makes a loud clicking noise. It sounds like a maybe a gear is skipping through some teeth. It is loud and at a regular interval, although the rate at which the noise...
its most likely a bra wire caught in there as the bowl spins around it is hitting the plastic tank therefore making the clicking sound. its super hard to get em out and if it has put a hole in the plastic tank its really expensive to fix call your appliance service asap to have one of them take a look. this is a very common problem from a front load washing machine
Jan 09, 2011 | Maytag Neptune MAH5500B Front Load Washer
Cannon MP830 Printer cartridge jam
So you cant get the ink tanks in place properly?
Have you tried this method to ensure they're properly seated? Is the printer on or off when you try to seat the tanks?
Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Apr 04, 2009 | Office Equipment & Supplies
Danby Air Conditioner
I have the same problem with my Danby AC unit...every 5-20 seconds it makes a god awful clicking noise...Make me wanna cry
Jul 09, 2008 | Danby DPAC8020 Air Conditioner
RCA DVR40
My RCA dvr 40 did the same.I think it was overheating.I vacumed the fan opening and put small blocks of wood under the legs and that worked for about 3 mos. then it said powering up but wouldnt. i'm now replaceing the unit. Good luck
Apr 09, 2008 | RCA DVR40 DIRECTV DVR with TiVo
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
In response to previous 'click' problem.
Could be a shorted high voltage transformer. IE switches on at low power, finds a short, switches off and continually repeats this process.
Nov 21, 2005 | GE 46GW947 46" Rear Projection Television
Jenn-Air JSD2695KES Side by Side Refrigerator Logo
397 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
