Question about Keurig B60 Coffee Maker
I need a replacement K cup holder system for the Special Edition Brewing System
    Sniper:
  • 67 Answers
I think you are talking about the black funnel part, the replacement k cup holder, i know of this great site that sells all kinds of replacement keurig parts i hope this helps http://stores.ilikenew.com/-strse-14/coffecoffee,-tea,-shakes,-diet,/Detail.bok
Posted on Jan 27, 2011
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 68 Answers
If your looking for the replacement k cup holder check this site out BNTPrice
Posted on Nov 15, 2012
Bought a Keurig coffee maker from a charity garage sale. It was missing the K-cup holder. Keurig won't replace it because the serial # showed the brewer was already replaced. Don't know the original owner, still need a k-cup holder. Help..........
Posted on Sep 02, 2010
  • robbie1968 Dec 22, 2010
    Just so you are aware, when Keurig replaces a brewer under warranty, you have to send back the k-cup holder. You are then directed to discard the brewer because it is sealed and cannot be repaired. It sounds like someone "donated" a broken brewer and you are the lucky soul who bought it....good for the charity, bad for you.
My keurig B60, I think?? I don't have the manual, either spits out water everywhere or brews the grounds into the cup?
You need to clean the innards once in a while with vinegar. Try their website for the manual. It has cleaning instructions.
Oct 01, 2014 | Keurig B60 Special Edition Brewing System...
Why doesn't it brew a full cup?
The settings are incorrect. See manual for setting up volume measures and reset.
Sep 19, 2012 | Keurig B60 Special Edition Gourmet...
1. It sometimes doesn't give me a full cup as per the setting. 2. It was hardly working and I descaled with vinegar - it worked while I cycled the vinegar through but then quit working entirely
If your brewer is not brewing the full amount selected, it may be caused by the following:
The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
First try to make a descale maybe repeat it the next day.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Then try also this
http://www.youtube.com/watch?v=DqRs4Ott21s
Jul 04, 2011 | Keurig Special Edition B60 Coffee Maker
The k cup holder got thrown away by accident. Can I buy a replacement?
i know of this wonderful website that sells the replacement k cup holder, check it out i hope this is what you needed http://stores.ilikenew.com/-strse-14/coffecoffee,-tea,-shakes,-diet,/Detail.bok
Dec 27, 2010 | Keurig Special Edition B60 Coffee Maker
My keurig will not dispense right amt of water
Try brewing a cup without a K-cup in it on the largest cup button (will brew just hot water). This will help clean it out in the event it is clogged. If that doesn't work, completely remove the K-cup holder where the needles are (careful not to get **** ) by pushing up from the bottom and rinse using hot water, preferably with a sink sprayer if you have one. Sometimes the needle can get clogged, especially if you ever use the hot cocoa K-cups, so the manufacturer recommends brewing a "blank" cup of just hot water after each hot cocoa K-cup brewed. Hope that helps...Best of luck!
Jan 02, 2010 | Keurig Special Edition B60 Coffee Maker
My Keurig B60, 1 month old is not brewing enough coffee
Check the needle inside the k-cup holder to ensure it isn't clogged. You can completely remove the k-cup holder and rinse it out using your kitchen sprayer to help loosen any debris stuck inside the needle. The needle is what punctures the k-cup and extracts the coffee from within the cup and can become clogged. Make sure when you replace the k-cup holder, that you align the arrows and snap the top or arrow-side in first. If simply rinsing your k-cup holder and needle don't do the trick, try inserting the end of a small paper clip into the needle to push out any remaining debris. This technique is actually recommended by the manufacturer, so it won't void any warranty or damage the needle. After replacing the k-cup holder back into the machine, try brewing a cup of coffee to see if it did the trick.
As a side-note, if you regularly use any "Hot Cocoa" k-cups, you need to make sure and immediately brew a cup of just hot water (no k-cup) to help clean it out and prevent the needles from clogging. The Hot Cocoa k-cups are notorious for clogging the needles up thus causing the problem you described above.
Hope that helps...best of luck!
Apr 11, 2009 | Keurig Special Edition B60 Coffee Maker
Coffee grinds on K cup holder
try removing the K-cup holder and inspecting the bottom hole opening. This is where the bottom of the K-cup holder would go through. Sometimes grounds can rest on that edge and fall into the coffee. I hope I could help!
Feb 15, 2009 | Keurig Special Edition B60 Coffee Maker
Keurig B60 Coffee Maker Logo
1,049 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
