Question about Konica Office Equipment & Supplies
Konica 7022 error F-34-1 - Konica Office Equipment & Supplies
    Habit-Forming:
    New Friend:
  • 106 Answers
F-34-1 means Fuser (fixing) problem, check the heater lamp, thermostat and its wirring if all Ok. Reset it from Tech. Rep. mode
Posted on Nov 03, 2014
4 Suggested Answers
  • 6 Answers
SOURCE: Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
Posted on Aug 09, 2008
SOURCE: I have Konica 7022 copy
I am not an expert. I am someone that is lucky a lot when I have to fix something. I also had the F28-3 error code. The copier would begin to copy. However, when the unit began the printing process, the error code would indicate.
1) I downloaded the Service Manual (not the user manual) and checked the error code. This is what it says: Abonormal separation spark detected 5 times in 20 ms intervals, 5 times in succession for the same job.
2) I went on-line and found a couple of blogs from techs which stated that it in their opinion, it was one of three things, the T/S Corona Unit; an insulation failure which should be indicated by discoloration and a burnt smell where arcing has occurred; and the high voltage unit.
3) After removing the drum assembly and inspecting around all corona units, I could not see or smell any signs of arcing. So, I inspected the T/S Corona Unit and found one of the wires broken.
4) I removed the T/S Corona Unit, disassembled it using the instructions in the Service Manual.
5) I reinstalled the T/S Corona Unit and gave it a try. So far, so good. Copies normally again and no more error codes.
Good luck.
Posted on Dec 24, 2008
MTSTech
  • 16 Answers
SOURCE: Hi, I have a Konica
I would call for service. Below is the official repair method. Sounds like a fuser has failed or at least the thermistor on the fuser. This ensures there is enough heat in the device to properly transfer the image to the page.
F35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Posted on Mar 01, 2011
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Error code F 26-3 on Konica 7022
Sir/mam, you might have a bad drum density sensor or it was not cleaned or was destroyed by static electricity, if a vacuum cleaner was use to remove the old developer, NEVER use a vacuum cleaner for that procedure. Remove the drum and will see a small sensor near where the cleaning blade sits need to clean it replace it. Worse case the main control board is bad that what sensor talks to .Was the L Detect procedure run after the developer was replaced, and before you replaced the developer did you clear the developer counter, to let machine know it has new developer, because clearing the counter is the only way the copier has new developer, did you clear the counter for the new drum? The machine use the counters to determine voltages for certain assemblies. If L detect was not run and copies or prints where made get new developer and start over.
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7022 26-3
Yes I stated what I recommended to do in your last post!
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
I have a Konica Minolta 7022 printer, scanner, fax, and copier machine. How do I get it to scan?
Please see this website complete manual for Konica MInolta 7022 printer I think i can help your problem
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Thanks
May 10, 2011 | Konica Minolta Office Equipment & Supplies
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
Error code f-51-6
this is your WRITE UNIT CODE.''''PRIT HEAD''''
you chould try to reseat all connectors ,and especially the write unit ,how handy are you?????
let me know
Oct 23, 2008 | Konica Minolta Di1610 Copier
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
221 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Andrew Taylor
Andrew Taylor
richie46
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
