IT IS WORKING BUT NO WATER INCOME - Washing Machines
  • Washing Mach... Master
  • 2,699 Answers
Shut off the hot and cold water.disconnect the water line from the washer and stick them in the washer,turn the water back on,make sure you have someone hold the lines so when the water is on the hoses don't spray all over the place from the pressure in the lines,if no water comes out you have a bad home water valve and need to change it out,if water comes out check the valve where the water lines connect to on the back of the washer,if there are screens inside the opening on the valve pull them out and clean them or you'll have to change the valve out.you didn't send the model number so i don't know what kind of machine you have,if it's a newer washer you could have problems with the electronics or something else,also i've seen water lines with pressure valves in them,if you have this change them out to regular burst proof hoses.good luck
Posted on Jul 31, 2010
Is there a filter on this model if so where can i find it
george
no details as to make model year top or front loader so no answers
post the question again with the details if you want an answer
May 22, 2016 | Washing Machines
Manual
Those machines use the incoming water temp to start and then boost it, so check the incoming water temp. If it is too low then you need to increase it. It could be the heater that is not working but you need to check the incoming water temp first.
Jun 06, 2013 | Jet Tech Systems 24 in. F18DP...
New tankless bosch unit, luke warm h20, gas line 1 inch direct to tankless, gas company came and gas psi ok. Plumber said we can not adjust the gas pressure above 5.5 inches of water at the meter. hel
1) Add tempering tank to preheat incoming cold water.
http://waterheatertimer.org/Tempering-tank.html
2) Read product manual or call Bosch to make sure unit works with pre-heated incoming water. Some incoming water sensors will not trigger combustion is incoming water exceeds certain limit.
2a) Read product manual for required yearly/monthy maintenance.
Train wife to delime tankless yearly.
3) Install bigger gas meter.
4) Solve entire moneypit problem today for $325
http://waterheatertimer.org/How-to-install-gas-water-heater.html
5) Don't install tankless unless you have a lot of money and time for headaches.
Don't believe promotional literature. Tankless promotion is BS for average do-it-yourself folks who want to save a buck on water heating. Estimated yearly saving of $100 means Tankless do not save money long term. All costs are energy: Purchase price and installation negates several years saving up front. One repair will negate another 5-8 years energy savings. By then you need new unit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 03, 2013 | Water Heaters
Ice maker not working
Could be a filter, or the incoming water valve, Located in the back. Follow this incoming water line till you see an electrical connection in side the lower back of the fridge
Jan 21, 2013 | Admiral Refrigerators
E10 error code on Frigidaire affinity how to repair it
Your fill time, water fill time, is too long. Have a professional complete the following:
. Is the incoming water flow normal? Yes, go to step (4). No, go to step (2). 2. Are the incoming water faucets turned on? No, turn water faucets on. Yes, go to step (3). 3. Is the incoming water pressure above (30) psi? No, have customer correct pressure problem. Yes, check for kinked or blocked incoming water hoses, clean incoming water screens. If problem still remains, replace the water inlet valve assembly. 4. Does the fill water continue to enter the washer? Yes, go to step (5) no, go to step (6). 5. Remove power from washer. Did the water fill stop? Yes, go to step (6). No, replace the inlet valve assembly. 6. For Better models, check the electronic pressure sensor. For Good models, check the pressure switch. Pressure sensor checks good. Go to step (7). Pressure sensor checks incorrect. Replace pressure sensor. 7. Replace the Main Control Board
Aug 16, 2012 | Frigidaire Affinity ATF7000ES Front Load...
No water in the humidifier (General 1042L). What's wrong? Thanks
I would first check to make sure you have water to incoming side of the solenoid valve. Most inlet and outlet fitting are compression type so you can carefully loosen nut on incoming side to see if you have water there.You don't want to take the nut off just back it off a liitle to see if you have pressure there.If so then retighten nut on incoming side and loosen nut on leaving side. Turn up thermostat to actuate solenoid valve.You should be able to hear a slight click when the valve opens.
If you have water on incoming side and you can tell that valve is working but you are not getting water flow then shut off water supply to humidifier and remove inlet nut and and slip pipe back to see if there is a blockage there. Clean as needed or replace solenoid if it's not working.If you have flow into unit but not out then check outlet side for blockage. I hope this helps . Thank you.
Dec 30, 2010 | General Filters 1042-LH Humidifier
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
Not hot water EF0 code
Check for kinked or blocked
incoming water hoses, clean the incoming
May 16, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
