Question about Vacuums
Bissel pro heat turbo. I beleive it is clogged with ahir and fiber. i don't see water going up through the front How do I unclog
    President:
  • 1,673 Answers
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad.
Posted on Apr 24, 2008
My Bissell pro heat pet 2x model 9200 does not allow the shampoo to mix with the water. Something must be clogged, and I don't know how to unclog
The 2X is designed with 5 solenoids. I am not allowed to tell you that it's a flaw in the design, but I will say that is the only machine on the market that our store refuses to work on. Buy a Hoover F5914-900 machine and end your pain.
Jun 08, 2017 | Bissell Vacuums
How do i fix my Bissell pro heat turbo x2 carpet cleaner it wont suck up anything?
Check the vacuum hose and head for link clogs from carpet fibers
Oct 30, 2016 | Bissell Vacuums
The handle hose on my bissel proheat turbo 2x is clogged, how do I unclog it?
Try suctioning clean water from a sink or bucket with the attachment removed from the hose. If the attachment is clogged, soak in hot tap water for 30 minutes and clean the end with an old toothbrush.
Here's a link to locate a BISSELL Authorized Service Center if you continue to have problems.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 10, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
How to unclog a bissell proheat turbo carpet cleaner
proheat 9300
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Nov 24, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell 9300 m pro heat turbo 2x . i need the hose diagram for my machine please
I have had problems with the little red clips that squirt the water getting clogged, tiny little holes! I had to remove them and use a needle, then blowed them out with air compressor. I am also trying to find a diagram for this 9300-M model but cant find one.
Aug 26, 2010 | Bissell Vacuums
Bissell proheat turbo sprays water but does not spray the cleaning solution. How do I unclog it?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rsttsr
Jun 14, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Will not **** the dirty water back in.
check for clogs in hoses and head.mine gets clogged up all the time.
Jun 06, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Need owners manual for bissell pro heat turbo
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
May 12, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Lost instruction book for my bissell pro heat turbo deep clean
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
Nov 15, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
