Question about Cobra 25 LTD 40-Channels Base CB Radio
I have a cobra 25 nw st and i do not have a swr meter. how do i tune it to the antenna. the antenna will be used on several trucks.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 184 Answers
You really should have or borrow a meter for this task. Just tune it for the for the lowest SWR, mounted in the position it will hopefully be mounted on all the trucks. I presume you are a Trucker, and will be placing on another Tractor, with a similar or West Coast mirror style mount. Let us know how this works out on the various vehicles. Thanks, Bill
Posted on Sep 01, 2010
Can hear but they can't hear me
It could be a number of problems but most likely your RF power amplifier has blown. Also, try and check your antenna SWR. if it is very high, then your antenna needs retuning. A poorly tuned antenna can cause the RF amplifier to fail.
Mar 03, 2014 | Cobra 29 WX NW ST 40-CHANNEL NIGHTWATCH CB...
Cobra 29 refuses to calibrate
Check for a short in the Coax. Is the antenna near the cab of a truck or other body part? Is the antenna grounded? Has your radio been peeked and tuned?
Mar 09, 2013 | Cobra 29 WX NW ST 40-Channels Base CB...
What antenna do i need for a conversion van fiberglass top radio is cobra 29 wx nw st
you are not planning to talk on this radio are you? Install your antenna where you can get the most out of it.Such as on the front right side near the windshield or install a mount near the top drivers side rear.Any way you should make sure you have a good ground and an SWR under 3:1 @ 3:1 you are losing 75% of your power to the radio and coax and 25% to the antenna but the lower the better . Try different places on your vehicle as to where you get the best place to put the antenna. Get a feild strength meter also,it will help you find the best position.
Feb 08, 2013 | Cobra 29 WX NW ST 40-Channels Base CB...
My cobra 18 wx st comes on and goes tru all channels but has no noise at all coming thru it. none of the signal strength lights come on or anything. its brand new.
Sounds like a antenna issue. Make sure coax is in good order.and antenna is connected properly. You might have to get a "swr" meter to put in line between radio and antenna to make sure antenna is "tuned" to were the radio is operating. Radio shack sells a ok low budget swr/power meter.
Nov 09, 2012 | Cobra 18 WX ST 40-Channels Base CB Radio
I cannot get my swr meter to calibrate to check swr. My radio has been tuned and peaked. I have 18ft of coax, and I have run extra grounds to the antenna and the radio. Why can't I get it to calibrate?
where do you have it mounted?Is the antenna an adjustable one with set screws? You may have to move the antenna up and down to get a good match. Anything under a 2.0 is good.
Oct 08, 2012 | Cobra 29 WX NW ST 40-Channels Base CB...
Everything works but can only send and receive within 50 yards of other radio
check swr's and the antenna installation. if all is good. have the radio checked out. ITS should be FREE!!!! to see if it has any rf power out put could have a bad rf final transistor.....
Feb 04, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
I have a cobra 29 wx nw st withwilson little wil entenna. I am having issues with a no swr reading on channel one even if I turn my swr cal all the way up. My 40 cal reads on the swr at .5 no matter how...
first of all you are going about it wrong. To set your SWR you check it on channels 1 , 19 , and 40. If you reading is higher on 1 than on 40 you have to shorten your antenna . if its higher on 40 than on 1 then you have to lengthen it. before you do any adjustments to it ,loosen the set screws and let the antenna fall to the bottom then bring it up 1/4 " and tighten the screws. You should also use an external SWR meter not the one on the radio. Thats good for making checks every once and a while. With the meter you key the mic and have the needle go to set then put it on for and key the mic to obtain you reading . Anything under a two is good .
Dec 16, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Not sure how to use the swr meter on my cobra nw
The SWR meter connect between your antenna and your rig,
So the Out of the rig, goes into the SWR meter, and the antenna plugs into the SWR meter.
Jan 19, 2010 | Cobra 29 LTD CB Radio
Cobra 29 NW LTD Classic wont calibrate and red antenna light keeps coming on
The calibrate knob only calibrates the radios SWR meter, the owners manual will show you the procedure for that. If your ANT light is coming on, it is telling you that your SWR is to high, and may cause damage to the radio from reflected power. You should purchase an in line meter as the radios internal meter may be somewhat unreliable. You need to tune the antenna to the lowest SWR possible. Typically anything under 2.0:1 is acceptable. Radio Shack sells a meter for about $50, and is pretty accurate. Antenna mounting can also cause high reflection if it is to close to other objects. Google "CB antenna tuning" or read the instruction manual for you antenna, and you should be able to figure out how to properly tune the antenna.
Jul 07, 2009 | Cobra 25 NW LTD 40-Channels Base CB Radio
Cobra 29 nw ltd classic
Hello candy_72_99,
Hello candy_72_99,
If I am correct what you are saying is that your radio has poor modulation? ok. First I need you to run two tests for me.
1) Power output Test: connect a power meter to the antenna jack and the other connector of the meter to the antenna, Key up the mic and record the power reading is should be 4W PEP or 36.02dbm
2) Then I want you to take an oscilloscope and put a 1khz tone in to the mic while measuring the RF output at 100% modulation the wave form should not clip.
If these two test are good then your modulation is ok. What I believe you are asking for is more power or better power efficiency.
Try to tune your antenna for 1:1.0 or 1:1.2 SWR with a SWR meter this should deliver the full power to your antenna.
I hope this helps
Thank you,
Shuttle83
Nov 04, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 LTD 40-Channels Base CB Radio Logo
78 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
