Question about Husqvarna Designer I
Broken wire/cable I remover the front of the mechine to fix a thread jam and one of the cables that connect the circut boards together pulled out and broke .This is a two wire cable with connectors at each end and is about 6 inches long.Where can I find the part number and where can I buy this? Thanks
  • Husqvarna Master
  • 7,365 Answers
Go to the husqvarna website & find a dealer they might have one
Posted on Jul 31, 2010
Machine just locked up, no obvious thread/needle issues, can't find answers in book...safety function on, Help! Someone said take bottom off and look for thread? Only used it a few times, but out of...
Can you turn the hand wheel at all ? If not, something is jammed tight somewhere.
Have you removed the bobbin from the bobbin case and cleaned thoroughly around it, removing all lint, dust, loose thread bits ?
If that does not help, can you try taking apart the shuttle assembly, which the bobbin fits into ?
Sometimes you may get thread wound around in these parts and it causes a jam. Please, observe how the parts of the shuttle assembly fit together so you know how to put it back together. There may be a small lever or pair of levers that must be moved to allow the parts to be pulled out. There aren't many, usually two or three pieces.
It's very useful to snap pics.. of it the way it looks before you touch it, and then each step as you take it apart, so you have a guide to putting it back.
It's also possible a gear is jammed. Most machines allow you to remove the upper casing and bottom casing. You'd have to take out some screws to do this. If anything is jammed between gears that you can see, remove it carefully. If you have to use a tool to pull out something jammed, take care not to damage the gear teeth, as that's a big repair job and often not worth the expense compared to buying another machine, sadly.
Mar 04, 2015 | Brother PC-420
Embroidery unit for the Pfaff 7570 keeps stating that theyarn is broken or ran out
Sounds like a tension problem take it back to correct the tension
Feb 02, 2015 | PfaFF Creative 7570
Remove thread jammed in bobbin case holder
Just open carefully the front of the machine (attention where everything has to be put back), identify the problem and try to remove the thread. Inspect the inside of the machine and the lower bobbin case for thread that may be tangled . Take it easy and you will fix it ; most of the times you we'll not need professional help. Post back to tell us where the problem was and how you fixed it.
Sep 29, 2014 | PfaFF Creative 7570
Mechine stops and is hard to turn withwheel on pe770
It's bound up with broken threads.. clean the bobbin area.
Oct 10, 2012 | Brother PE770 Computerized Sewing Machine
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
My sewing machine gears jammed.
One or more of the bushings is seized, the machine needs to disassembled, the bushings removed, cleaned, re-lubricated. Not something you can do yourself.
Apr 07, 2010 | Baby Lock Espire
The top spool of thread jams tight when I pull the
It sounds like the tension setting is too tight. The tension mechanism consists of two metal disks; the thread runs between these disks. When the pressure foot is down, the disks come together, trapping the thread between them. When the pressure foot is up, the disks separate and the thread can flow freely. (BTW, this is why you adjust the tension with the pressure foot down.)
Take a look at your tension setting and try loosening it. That should resolve the problem.
Let me know if this helps, ok?
Robbie
Jan 27, 2010 | Janome Sewing Machines
Needle wont go up or down
If the Handwheel (big knob) is moving but the needle is not moving, you need to engage the clutch ........depending on the model
- push handwheel in to engage, pull out to disengage
or
- if there is a smaller wheel inside the handwheel, tighten to engage, loosen to release.
BUT if all is jammed........
Check for threads that are jamming the motion of the hook around where the bobbin case is
If your bobbin goes in from the top, remove the needleplate and bobbincase remove thread jams by gently rocking handwheel back and forth until released.
Clean around the hook race with a rag moistened with methylated spirit, surgical spirit or similar, then reassemble.
If front loading, open the door for bobbin case area, release 2 retaining clips holding the collar on (take note of the position/orientation for when you re-assemble....even take a digi photo to refer to !?!).....
......then just do jam removal & clean out in much the same way as for the top loader.
In all cases, don't force too much or be too brutal, gentle and patient works best, try to judge where the jam is caught and work with it slowly......you may need to cut jammed threads, just ensure all are removed before you re-assemble.
Feb 15, 2008 | Singer Featherweight 132Q Mechanical...
Thread getting caught underneath
you need to replace your shukle that holds the tread bobbing below.it is either slack or broken . if it is slack then you tighten the little screw that holds a cover that gives the thread tension .if its broken then replace it.once the thread is slack below it will cause your thread to bundle up.
Mar 10, 2007 | Euro-Pro Shark 80 - 7133
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
