Question about Kenmore Dryers
My Kenmore dryer will not heat or turnoff. I have
My Kenmore dryer will not heat or turnoff. I have replaced the timer and still has not solved the problem. The dryer keeps running and the timer does not advance.
  • Kenmore Master
  • 2,699 Answers
The timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Posted on Jul 31, 2010
  • Sal De Aug 01, 2010
    if it's electric check the thermostats on the heater box but first make sure you have 240 volts going to the dryer,with a meter check the power where the cord connects to the dryer,from the red to the white you should have 110 or 120 volts and from the black to the white you should have the same,if you don't then you have a problem in the fuse box or a bad breaker not the dryer.next if that checks good unplug the dryer and with a meter check the thermostats,if the lint filter is on top remove the vent line and remove the back panel and also read out the heating element,you have to remove at least one of the wires off the part you're reading out,if the filter is inside then all your parts are in the front of dryer,if it's gas check the thermal fuse,the ignitor,sensor,if the ignitor is glowing but not liting you have bad gas coils or a bad gas valve,no heat the timer will not advance in auto or more or less.let me know what you find
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My Kenmore HE4 electric dryer runs for 2 minutes and stops
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replac it. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it
Oct 01, 2013 | Kenmore Elite HE4 Electric Dryer
The dryer wont heat up and the timer does not turnoff dryer
Good chance you heating element is bad, hence it will not heat or trigger the turn off timer. Look on line for your model number and make...these are pretty easy to install.
Mar 02, 2010 | Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore Elec Dryer timer & Heat Element Failed
Hello there:
I would have to tell you that i dont think that the two would fail at the same time but it can happen but not too often
deffinatly replacethe timer and the heating element and this will solve the problem
also since you have the unit opened i would inspect all of the wiring for loose connections and moisture cause this will cause things like these to fail prematuraly ok?
I hope that this has peeb very helpfull for you
best regards michael
Nov 04, 2009 | Kenmore 659 Electric Dryer
My dryer does not shut off! continues to heat
HI. This is a defective, or damaged timer control module. It must be replace asap. If this continues, it will damage the element. Replace the timer, if possible. Once replaced, the issue will be solved.
Oct 15, 2009 | Kenmore 62602 Electric Dryer
No heat....i turned the dial while it's running
Your complete problem may lie with a bad timer. Replace the timer and it will stop at the end of the cycle. If it still does not heat, update your post for the next step.
However, replacing the timer may solve both problems.
Apr 10, 2009 | Kenmore Dryers
Kenmore Electric dryer runs on cool down forever.
Call the mfr and ask them about it. This problem may be pretty complicated. There may be a problem with your board that tells it to go to cool down. Can you set the timer for 45-60 minutes and it stay on heat for that long?
Feb 11, 2009 | Kenmore Dryers
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
431 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
