Question about JVC GR-DVL767 Mini DV Digital Camcorder
My JVC GR-DVL767EK mini camcorder has a tape jammed in it. The eject mechanism is part way up but won't slide out to release the tape. It won't go back down either so I can close it either The error code I get is E04 - unit in safeguard mode - eject and re-insert the tape. I've tried removing the battery which produces a slight movement in the carriage but then it goes back into safeguard mode.
    President:
  • 1,197 Answers
The tape can only be removed if the camera is fully powered. Since You say that you have removed and replaced the battery... make sure if the battery is charged? if no battery, then connect the AC adaptor... if still it wont open it needs enough juice ..... rek('_tx6');In this model, it's hard to access the mode motor to drive it manually. Open cassette door, see the motor on the left side try to access and drive it by 3V battery to its contact. Otherwise; send it to service center.
There are a number of things that can cause a no ej problem on this mech and tape being sticky is one.Once tape is removed and mech cleaned,a clearer picture will be given.If problem persists,eject switch load motor,drum or capstan motors can be evaluated for problem.But,oftentimes it comes down to a defective tape.That being said,this is a fairly invasive procedure to manually remove tape from this mech.Disassebly is kind of tricky as ribbon cables are easily torn during tear down,and to remove tape,complete disassebly will be necessary.To a qualified tech this would be a fairly routine diagnosis and would be well worth anestimate fee(even just to get tape out).I would suggest that any reputable service facility in your area familiar with Jvc should be able to help
This is not to say that you cannot do it.... but if you are going to proceed yourself unless you have prior experience you might fnd it hard.... and your camcorder is not something you can take a chance on
If you have the AC adapter, then just plug it in. The camcorder should work with that power - even if there is no battery attached. If you don't have the AC adapter, then the only other method will be to take the camcorder apart - but good luck putting it back together
Good Luck with your fix
Posted on Jul 31, 2010
GR-DV2000 tape jammed. Ejector mechanism whirrs in repeating loop but fails to eject cassette
its look like if the mode switch or sensor
are defective you may go to your repair shop
its not a big job fora qualify technicien.
Feb 24, 2010 | JVC Cybercam GR-DV2000 Mini DV Digital...
Tape jammed in jvc camcorder
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape.
Sep 08, 2009 | JVC GR-D250 Mini DV Digital Camcorder
Will not eject tape
If your camcorder is JVC GY-DV550 and having a tape jam problem, It could be mechanical problem such as pinch roller or tape may be loose inside. I will try this just in case of loose tape. At VCR mode, press FF serveral times then REW same. Now try eject. If that did not work, you should take it to professional service facility near you for further diagnostic. Good luck, -james
Mar 27, 2009 | JVC GY-DV550 Mini DV Digital Camcorder
Jvc digital video camera gr-d244u mini dv
My jvc gr d244u digitial camcorder it torn up. when i go to eject the tape and it pops out it want retract it back in. what can i do to fix this problem.
Jan 04, 2008 | JVC GR-D244 DV Digital Camcorder
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 27, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Safeguard Mode 03
E03 is a mechanical fault on the mechanism,it may be the reel pulleys are bent and need to be straightened.If this is not a solution, take it to JVC agents,the mechanism is likely to be damaged if not repaired by the agents.
Aug 26, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Removing dv cassettes manually
open the unit and look for a small motor that ejects the tape through a series of mechanical gears, slides and hinges. Now turn this motor by hand.
Jun 06, 2007 | JVC GR-D270 Mini DV Digital Camcorder
JVC GR-DVL767 Mini DV Digital Camcorder Logo
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
