Question about Sony Playstation 3 (PS3) Console
My fan is on constantly 2mins after switching on
    Novelist:
  • 105 Answers
Unfortunately the PS3 fan is a bit noisy, unless you have the slim version. I wouldn't say it is a problem, mine does the same since i bought it.
Posted on Jul 31, 2010
Cooling fans running constantly is this normal susuki vitara 2007 2ltr petrol
No... constantly is not normal...!!
Hello John Burns,
The vehicle (by design) is targeted to operate at
180 degrees Fahrenheit ... Look for a thermostatic switch on or near the top of the radiator. For these purposes I STRONGLY RECOMMEND workshop or FACTORY repair manuals.
I have noted that most makes will keep the fan running AFTER the ignition is off... but that could easily be verified by looking at (make & model needed here) your UNDISCLOSED
vehicle's WIRING DIAGRAM ...
Present complete issue statement:
"Cooling fans running constantly is this normal"
Popular USA market vehicles TOTALLY FREE
wiring & TECHNICAL SERVICE BULLETINS
are available on BBB Industries website (below)
Hope this helps...
I see issue now show Suzuki 2007...
I do know engines BEGIN to run correctly ABOVE
180 degrees Fahrenheit..
Buy a NEW THEMOSTATIC FAN SWITCH
Apr 14, 2017 | Cars & Trucks
Mercedes C180 W203 coolant fan on constant
The fan is on because the wire is cut. If the ecu does not detect a signal from the fan switch it will default as on. Replace the wire and fan temperature switch and all will be ok
Nov 02, 2012 | Mercedes-Benz Cars & Trucks
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
Computer switchs itself off after about 2mins
Have you been through the power options to see if it has been altered in that mode to save power and also check from the bios menu which you can access before the pc boots by pressing a required key(should be displayed by the pc).
Check from the bios if the hard drive has been set to go off during a particular time.
Do let me know if you need more help.
Good luck
Jul 04, 2010 | Acer Aspire One PC Notebook
2006 vw passat. car wont release hand brake. dash board says check manual. the warning lights are all on
or disconnect battery wires, positive then negative wait 2mins then reconnect negative 1st then positive, this should reset your electrics, it worked for me anyway.
Mar 21, 2010 | 2004 Volkswagen Passat
Peugeot 406 - interior fan on constantly
change the switch / balast resister
Feb 24, 2010 | 2005 Peugeot 405
Light and fan work but does not work with wall switch
This would mean that that constant power to the fan and light is not wired through the switch right, or not wired into the switch at all. Most ceiling fans that have a light kit will have a Black, White, Green, and Red wire that comes from the ceiling and hooks into the fan and light. If it was done correctly, then the Green wire would be ground, the White is your neutral which is hooked to the other White wire, the Black wire is usually power to the light kit which will also hook to another black wire, and the Red is to the fan. Sometimes the Red and Black are reversed. If any of these wires are wired wrong, that could possibly lead to a constant power to the fan and light kit.
Feb 02, 2010 | Hunter Dryers
I have a vokera unica 28 which pulses when firing
your fan may need attension fan runs after boiler shuts down is normal on some Vokera,s too clear fumes out the flue 2mins approx
Oct 04, 2009 | Water Heaters
Eletric fan runs when focus 16 tdci is turned off 2006 model
This is normal for a car that has an electric fan system for the cooling system. There is a sensor that operates based on engine temp. When you turn your vehicle off the coolant stops flowing and the water temp goes up in the engine block. The electric fan may run for approximately two or so minutes.
Feb 07, 2009 | 2006 Ford Focus
Sony Playstation 3 (PS3) Console Logo
82 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
