Question about Gaggia Classic Espresso Machine
I want to change the head gasket but cannot remove it.
I want to change the head gasket but cannot remove the old one. After removing the 2 Allen screws, the whole thing seems seized up and won't move. How can I free it without damaging the assembly?
  • 1,089 Answers
Hi
Remove the water tank and drip tray. Then turn the machine upside down. That way you can see the gasket. Stick you allen wrench into the hole the screws were in and pry the center out. Now you can get a screw driver under the gasket and pry it out. It might come out in pieces but that is OK. They get hard and that is why they won't seal. They should be replaced once a year to work good.
Posted on Jul 31, 2010
Lane deadlock removal...approx 20 years old. Seams to have 2 holes on the back set...no screws.The front & back fittings are turning/spinning???
Deep within the 2 holes at the back are 2 allen headed screws. On mine they needed a 2mm Allen Key to remove.
May 21, 2011 | Garden
Need to change head gasket have removed 16 bolts from the head two more to remove having problems removing these (striped the allen key trying to remove these)
not sure where you live but you can get a special socket to fit around the outside of the bolt to get this out. lowes has a gorilla socket, orielly had Thompson sockets but one of your local parts stores can aid you in a socket to grip the bolt on the outside to remove it. hope this helps
Mar 24, 2011 | Mitsubishi Pickup Cars & Trucks
Leaking oil from primary cover, I road my bike to work is it safe to ride it home . I checked the engine oil it's still full . and how hard is it to change this cover?
All old harleys leaked oil, so its no big deal. First try tightening all bolts to primary cover, they should be allen head, so you will need a allen wrench of correct size. To change gasket you will first need to remove floorboard to primary bolts, then all the allen bolts. Put a pan under to catch oil. scrape old gasket off and install new gasket with a small bit of rtv to hold it in place. Put everything back together.
Aug 21, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
How do you change the gasket in the coffee dispensing part of the KitchenAid Pro Line KPES100PM Espresso Machine? My coffee is smelling like a rotten gasket. Seems to me I should be able to dig it out...
Remove the filter grille with the single cross head screw in the middle, then undo the 2x allen head screws now exposed. It may require some sideways levering with a large screwdriver once the allen screws are out to move the aluminium puck. You really do need to get it out to clean the puck up. Make sure the 4 holes thru the puck are cleaned out properly with a drill and buff all surfaces up with a wire brush. Remove the old brew head seal and clean up where the puck came from then refit the puck and push the new seal into place.
Aug 22, 2017 | KitchenAid PRO LINE KPES100PM Espresso...
How to change oil pan gasket . 2003 wide glide
The oil pan is on the bottom of the transmission on your Dyna Wide Glide. To change the gasket start by draining the engine oil and transmission lubricant by removing both plugs on the bottom. Once drained, disconnect the hoses going to the oil pan. Remove oil fill cap, remove two screws and remove the oil spout, pull up on the dip stick cover to remove it. Now, remove the allen head bolts and remove the oil pan. Replace gasket and all bolts. Torque all bolts to 7-9 foot pounds. Refill with oil. Transmission take 20-24 ounces of transmission lube and the oil tank takes 2 quarts 14 ounces of oil if you did not replace the oil filter. Since the oil filter is still full of oil, if you put the full three quarts of oil in the tank, the oil cap will blow off when the oil gets hot as it's overfilled. Good luck
Mar 22, 2010 | Harley Davidson FXDWG Dyna Wide Glide...
One one has removed the two allen bolts holding the `group in a Coffee Gagia, how does one remove the group holder to get to change the large gasket?
All you need is another gasket then use an ice pick or a scratch awl and remove the old gasket, it might come out in pieces.
Mar 12, 2010 | Coffee Makers & Espresso Machines
How do you replace the cimbali junior gasket?
Easiest way, remove the 3 bolts, or 2 bolts and allen wrench screw(depending on model) around the group head bell that will give you access to the gasket and make replacement super easy.
Jan 22, 2010 | Coffee Makers & Espresso Machines
Trouble installing replcement gasket in Solis Crema SL 70
SL 70/90 Brew Head Gasket Replacement Time 1 to 2 hrs Tools # 2 allen wrench # 1 Phillips screw driver # 2 Phillips screw driver # 13mm wrench First unplug the machine. Next remove the screw in the top back of the machine. Push the top forward with your fingers. This unlocks the top and it can be placed behind the machine with the wire connected. Next rotate the steam knob counter clockwise till it stops. Inside next to the micro switch there is a brown cam. On the backside of the cam is the #2 allen screw. Loosen this screw and the rotate the steam knob clockwise until it is removed. Now remove the clip on the steam manifold that holds the steam wand. There may be a plastic tie that is securing the clip. Cut it. Pull out the steam wand and let it rest on the bottom cover. Next remove the 4 large screws that hold the cover plate around the brew head. This will allow the cover plate to drop down and swivel on the steam wand, exposing the nuts that hold the boiler on the bottom metal plate. The nuts that hold the boiler on are # 8. Before you loosen the nuts you need to remove the water inlet nut on the side of the boiler. It is a #13 wrench. Remove the water line. Now remove the nuts that hold the boiler on.
Jun 16, 2009 | Solis Crema SL-70 Espresso Machine
Air compressor 3 gallon
When I turn compressor on it does not build up any pressure ?
Sep 09, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Gaggia Classic Espresso Machine Logo
199 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
