Question about Denon SCAV-F100 System
Recently reconnected my denon avr f100 and poa f100. The 'stereo' setting works fine, but any other equaliser mode, including the 5 channel and dolby 5.1, just emits a hum. I'm guessing sound processor??? Any ideas?
  • 79 Answers
Yes something more serious is at fault here. Ignore the other post about earthing - this is rubbish; the system is double insulated and therefore does not have an earth wire in the 'black lead'.
Posted on Mar 21, 2015
F100 needs earthing via black lead
Posted on Apr 29, 2012
Avr-f100 surround left and centre working intermittently can anyone help.
The same happens with my POA-F100, but only the center channel is affected (apparently the most important for movie/tv).
Seems to be a malfunction of the speaker relay (you can hear it clicking some seconds after power on). In my case a (sometimes pretty rude) hit on the side of the compartment with the flat hand helps, so the contact just mechanically hangs.
If I find the time I will open up the compartment to see if I can get a fitting spare part relay and solder it in (so I don't have to beat my Denon Setup any more ;-)
Jan 03, 2011 | Denon Audio Players & Recorders
Denon AVR-682 center channel has no output
You may have had the receiver set to "Stereo" mode, or Analog instead of "Digital" or "Auto" (automatically switches to digital when it detects a signal) modes. Also, setting it to "Direct" (2-channel from an analog source) could result in loss of center channel. Or your Surround Parameter dial (on the higher-end Denons, at least) could be set to a 2-channel mode.
Finally, if your digital inputs are incorrectly assigned (e.g., COAX1 instead of OPT1, or OPT2 instead of OPT1) for that source, the receiver will use the Analog signal which is stereo-only. You could get a center channel via Dolby Pro Logic II but it would be a "matrixed" signal, not the "real" center channel you could get via digital input using Dolby Digital or DTS.
(If all else fails, re-check your center channel speaker wire connections. It's very unlikely, but also possible, that either the receiver center channel amp or the speaker has failed.)
Feb 13, 2010 | Denon AVR-682 Receiver
Voice volume is low compared to background music volume on AVR-2808CI
Could be a number of things.
Most likely your surround sound mode. Some people dont like Dolby. Try to switch to 5 channel stereo.
Other option is to turn the center channel speaker channel volume up. Voices and dialog come from the center channel speaker in Dolby modes. Post back if you need instructions.
Please rate my solution.
Nov 30, 2009 | Denon AVR-3805 Receiver
Problem getting the best surround sound when watching a dvd
THE BEST SOUND IS WHAT SOUNDS BEST TO YOU, HOWEVER DO THIS:
1, USING THE SETUP MIC CONFIGURE YOUR DENON, PAGE 8 OF THE MANUAL. NEXT
2. RAISE THE REAR SPKR LEVELS, PAGE 46,47. NEXT
3. WHEN LISTENING TO AUDIO CD OR RADIO TRY THE 5 CH STEREO DSP MODE.
4. WHEN WATCHING A DVD USE DSP DOLBY PROLOGIC OR TRY 5CH STEREO IF THE MOVIE IS MOSTLY TALKING.
5, TRY 5CH STEREO WHEN WATCHING PROGRAMS WITH MOSTLY TALKING
Mar 01, 2009 | Denon AVR-2106 Receiver
5ch/7ch stereo in 5 channel mode
Front panel button engaged for 5 or 7 channel operation? Also check front panel rear surround speakers button is engaged. Should get you back to 7.1 unless you have changed the rear surround speaker setup for a 2nd zone, also be sure you have a 7.1 DSP setting enabled.
Feb 22, 2009 | Denon AVR-2105 Receiver
Only sound from Direct and Stereo settings on Denon AVR 788
Other listening modes (dolby, dts, neo6) are decoded from digital signals.
Direct will relay your only your discrete analog inputs - so if you want to use your AVR as an amplifier for those channels, you'll need to supply an input signal in a different manner.
Nov 16, 2008 | Audio Players & Recorders
Denon AVR-1804 6.1 Channels Audio Problem
Make sure the input setting is set to 'Auto' while on those channels and not Analog.
Jan 18, 2008 | Denon AVR-1804 Receiver
Denon reciever avr-487
If your tv is putting out mono you will only get the center and sub speakers. This can be because the tv is only mono, or the output is set to mono in a menu of the tv. If you have cable or sat run the digital audio out to you receiver; it usually sound better that way anyhow. Set your receiver to Dolby mode for best sound.
Aug 27, 2007 | Denon AVR-4800 Receiver
Denon 3802
m8 think thers hardware problem with it.or it could simply b that wen you pushin the amp hard then some other buttons are gettin pressed at the same time on the bord. couldnt say for sure without taking a look you could send it to these guys an they should do it pritty quick and cheap. http://www.mobilephoneservicecentre.co.uk/
Jul 03, 2007 | Denon AVR-3802 Receiver
Denon SCAV-F100 System Logo
603 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
