HI, I have a Daikin Inverter Aircond Model No.FTXD60JVEA and it shutdown suddenly with a green flashing light on inside unit with a code U4, and the Led lights on outside unit dont work.
  • sjbrewy Jul 31, 2010
    Thanks Iversh
    President:
  • 1,197 Answers
Error U4 on your unit means Failure of transmission between indoor and outdoor unit.
the probable reasons for this would be
Indoor to outdoor, outdoor to outdoor transmission wiring F1, F2 disconnection, short circuit or
wrong wiring
􀂄 Outdoor unit power supply is OFF
􀂄 System address doesn’t match
􀂄 Defect of indoor unit PC board
􀂄 Defect of outdoor unit PC board
to me it Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
However U4 code on the daikin means outdoor PCB is faulty and needs to be replaced.. and LED A not lighting also indicates faulty outoor pcb.
So give both the above conditions a check. you should be all set to go.....
Please please take necessary safety precaution before you try testing the unit yourself.... If you are least bit uncomfortable about what you are going to do... please do not hesitate to call for a technician.......
Good Luck with your fixya
Regards
Iversh
Posted on Jul 31, 2010
    Ive checked all wiring connections and are all fine, and has been installed for about 10 yrs, i thought it would be PCB, is there anyway i can check for faults in these boards, and are they expensive to replace.
  • SAM JAYANTH CHANDRASEKAR
    you would need to test for continuity and possible bad solder joints in the board. You would require a meter for that and a soldering tool just incase. if its just a matter of few soldering joints its not gonna cost much. the cost of repair really depends on the extent of the damage.... since you say the unit is 10 years old... i would have it replaced if the board is faulty
Green light flashing On Daikin fvy453cbv1
how many blinks, look up daikin error reset or daikin factory reset to clear the codes and get into secret service test mode.
Jan 03, 2015 | Heating & Cooling
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Daikin reverse cycle air conditioner error U4
Signal transmission error (between indoor and outdoor units) which means a faulty indoor or (more likely) faulty outdoor controller board. Call a tech.
Sep 19, 2012 | Daikin Heating & Cooling
Daikin FVY125 U4
This is a communication issue between the indoor and outdoor units.
This fault can be caused a issue with the interconnecting wiring such as an induced voltage on the Communication cable or even if a Drain Pump has been installed incorrectly external to the Daikin Unit.
Ensure that the Outdoor unit has power to it and that the Main PCB has a Green Flashing (HAP) LED on it to show that it is powered up.
Jan 15, 2012 | Heating & Cooling
How to solve u4 alarm in daikin inverter 24000btu unit
Feb 08, 2011 | Heating & Cooling
U4 System transmission between indoor and outdoor units Daikin
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
Daikin air con - error code is u4
i need the contrl wiring of a packaged unit
Mar 07, 2010 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
1,200 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
