Question about Panasonic DECT 6.0 Expandable Cordless Phone System with Digital Answering System
The phone screen says test standby and then when talk is pressed it says normal* and Trickle. It was working yesterday and then said key check NG. Thanks
Can't return from standby mode. the vga, sound,
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
May 31, 2011 | Computers & Internet
Tip
All nokia secret codes
Tips / undocumented functions:
- At the top of the main-menu and every folder, the keys 1 to 9 are shortcuts to the icons 1-9
- A shortcut on the left menukey in standby-mode will take more time to open than a shortcut on the right menukey. Reason: The left key is also used for the keylock so it shortly waits for pressing the * button.
- While writing text press and hold "#" to switch between Alpha mode and Number mode. You can also press a key long to insert its number.
- In standby-mode, press and hold 0 to launch your wap home page.
- If you have your keylock activated just press the on/off button to turn on your backlight to look at the time when it's dark without having to unlock the keypad.
- To keep the backlight on, run Torch (freeware), press and hold the Menu button and go somewhere else on the phone.
- To check your current firmware version simply type *#0000# in standby screen.
- To check your IMEI (International Mobile Equipment Identity) type *#06# in standby screen.
- To check your Bluetooth device address type *#2820# in standby screen.
- Start up in Safe Mode (no 'auto start' apps will be running): Hold down the pencil key when you turn on the phone and hold it on until you have to enter your PIN code.
- Format the phone memory by typing *#7370# in standby screen.
- In standby mode,
45# + <talk> dials the number on your sim in memory slot 45.
50# + <talk> dials slot 50 and so on
on May 12, 2010 | Cell Phones
I dialed ##8378<SEND>, then clicked
Typing ##8378 Send brings up the phone test screen. When you select #2 (Field Test) and then select OEM monitor and select "enable" the phone resets and enters test mode.
In test mode you can press the volume up button to bring up the test menu. You can navigate this menu using the 1 and 3 keys on the number pad.
The most notable screen in test mode is found by pressing 3 until you reach SHDR protocol monitor will bring up the screen that displays real time reception and transmission information.
Other screens display other system information, but I caution against "playing around" with these menus too much.
To temporarily hide the test mode screen you can press the volume keys again. To take the phone out of test mode completely follow these steps:
1. dial ##test or ##8378 and press send 2. select 2 (field test) 3. scroll down to and select 10 (OEM monitor) 4. scroll down and select Monitor DISABLE 5. the phone will reset and return to normal mode.
Feb 13, 2011 | Casio G''zOne Type S Cellular Phone
Unlock screen
  1. 1
    Press any button to wake the phone up from sleep mode. The phone will go into standby mode, which means it will light up and be ready for you to use it.
  2. 2
    Press the "Talk" key. Hit the "Menu" key, or the "Volume" key. Press the "Left/Right Soft Key." Each Samsung is a little different, and your user manual will tell you exactly what key to push.
  3. 3
    Enter your four-digit unlock code when the phone prompts you to enter it. This code is given to you when you activate the phone. The phone will unlock and you can now use the device.
Dec 08, 2010 | Samsung Lands Phones
Samsung SGH D900I- cannot turnoff keypad sound
The steps are outlined in the article below:
D900 FAQ – How do I disable or mute the keypad tone on my SGH-D900? admin March 6, 2009 --> Note: In order to disable the keypad tone, the Dialing Display Font Type must first be set to “Normal”
To change the dialing display font type follow the steps below:
  1. From the standby screen, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Display Settings (3)
  4. Select Dialing Display (6)
  5. Select Font Type (1)
  6. Highlight either Normal or Theme, using the navigation keys
  7. Press the left soft key to Save the Dialing Display Font Type setting
To turn off the keypad tone follow the steps below:
  3. Select Sound Settings (4)
  4. Select Keypad Tone (2)
  5. Highlight Off, using the up navigation key
  6. Press the left soft key to Save the Keypad Tone setting
Aug 29, 2009 | Samsung SGH-D900 Cellular Phone
I just got the phone yesterday and the keyboard locked up and won't unlock. Battery is fully charged. Have tried taking battery out and reinstalling. Phone turns on temporarily, cannot select anything, and...
It shouldn't be a factory defect but could be...
Try pressing the star button followed by the green talk button and that should unlock it.
Another thing is hold down the standby key at the top of the unit.
If the problem still occurs then i would reccomend taking it into the store you got it from
Good Luck!
Aug 12, 2009 | AT&T Blackberry Curve 8300 Smartphone
3650 phone start up failed pls help me
u have to reset or mobile ..to do that follow this
1. Removed your MMC card first.
2. Make sure you have at least 3/4 charge of battery before performing the
" Safe Mode, and follow-by phone reset *#7370# ". Or maybe you can have the
charger on and plugged into the phone to act as a full power source.
3. Press and hold the ABC key and then press the power button.
Remember not to release the ABC key till you seen the
"Safe Mode" standby screen.
(Fyi, there's no special indicator that telling yo're on a "Safe Mode"
standby screen.)
4. Once in the "Safe Mode" stanby screen press *#7370# to carry-out "Phone Reset"
task.
5. Once "Phone Reset" task completed and back to normal standby screen again,
switch off your phone and re-insert your MMCmag-glass_10x10.gif card.
If any error showing on the phone boot-up, please have the memory card formatted and by next phone
start-up you will not have the error msg again.
If you some important data or programs files on your MMC card, please use
a card reader to have them copied onto a pc before performing memory card
formatting
Dec 04, 2008 | Nokia 3650
How to increase volume in samsung E250
Try the code below at your own risk. I will not be liable for any damage this may cause to your phone.
Type the following codes on standby menu
*#0206*8378#
after typing you will be presented to a Test Mode menu
Select H/W Test
Select Audio Settings
Select IIS Normal (option 10) this is the normal volume for the phone. Scroll down to select Rx vol. then change level 14 to a higher value. Maximum is 30,000, i set mine at 5000
You can do the same for IIS Normal2 this is the volume for Music Player
Aug 16, 2008 | Lands Phones
MY LAPTOP GIVE ME A BLACK SCREEN
hi!
black screen at startup? do you still see the Dell logo at startup? try pressing Fn+F8 at the same time at the black screen and see if it works. Or else, try a working external monitor and check if its a OS problem or a screen problem. You can also run a diagnostic test by holding down the Fn key while its off and then press the power button while still pressing on the function key to check if you will still see the diagnostic test for the LCD.
Dec 09, 2007 | Dell INSPIRON 6000 CENTRINO...
Uniden 900MHz phone model EX17960A
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
Each pause counts as a digit.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
number has been stored.
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
Dialing a Stored Number
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
beep rapidly, and the phone will not dial.)
Nov 13, 2007 | Lands Phones
Panasonic DECT 6.0 Expandable Cordless Phone System with Digital Answering System Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
