Question about Kenmore Sewing Machines
Model 1802. The hand wheel will turn only with hand force.
Model 1802. The hand wheel will turn only with some force. Almost like the belt is stuck. The motor runs but will not turn any thing. The belt, when turning by hand squeeks .This has been a great machine and I need help. Thank-you
This might sound too simple but it might need to be thoroughly oiled. I just got one of these machines from a friend -- it had the identical problem: I couldn't turn the handwheel. The motor was working but the machine would not function. I blasted it with WD40 and then thoroughly oiled it with sewing machine oil. Within a half hour it was stitching just fine. If you use WD40 to free it up, be sure to thoroughly oil it with sewing machine oil immediately after because otherwise the lacquer in the WD40 will eventually gum it up again. Hope this helps.
Posted on Nov 14, 2011
  • Kenmore Master
  • 7,365 Answers
Sounds like it need to be serviced
Posted on Jul 31, 2010
Testimonial: "I thought that would be the answer. Thanks for confirming my hunch."
Singer 3232 machine was sewing fine now motor runs but needle does not move up and down
Check if the machine is in the bobbin winding mode. To wind the bobbin, the bobbin spindle has to be moved to the right. (The hand wheel will not turn if the bobbin spindle is in this position.) If it is, move the spindle to the left.
If the hand wheel turns, then check for a thread jam. Remove the top thread and take out the bobbin case. Gently turn the hand wheel forward and backwards until the thread comes free of the hook in the bobbin race. Follow this by cleaning any lint from the bobbin race of the sewing machine.
The last possibility is that the belt has failed. This belt transfers the energy from the motor to the needle bar. One source of the belt is http://www.sewingpartsonline.com/motor-belt-singer-007158xxl5.aspx . You can find YouTube videos on changing the belt. There are other parts that transfer the forces form the belt to the needle bar. However, I suggest you find a good sewing machine mechanic if any of these parts fail.
The manual has good pictures of the bobbin spindle on page 11 (page 18 of the PDF). Singer has the manual on their support page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/e06cb85928ace9753f1a7124f4a2df6168ffecf0.pdf .
I hope this helps.
Jul 28, 2017 | Singer Sewing Machines
Hand wheel do not turn, but motor runs, what"s the problem
possible internal belt broken
you have not mentioned a make or model to verify if it is belt driven but most are
take it in for a proper diagnosis and fix
get a quote
Mar 27, 2016 | Sewing Machines
Thread wrapped around sewing machine wheel & under belt, how do i get the wheel off to remove thread??? Singer HD 4423 model.
It depends on your model. If you look at it and it has what looks like a white disk in the center, that disk is covering a screw. Pop it off and take out the screw.
If it doesn't, then it's what's known as a "force fit." You need to squeeze it while gently rocking it until it comes off. Larger hands make the process easier.
Jun 05, 2015 | Singer Sewing Machines
Can't hand turn wheel
Do the following and you may have some progress:
1. Remove the bobbin and carrier. Try to turn. (Material stuck in the feed dog, bobbin, carrier or hook (pointed thing under the carrier) will cause the hand wheel to stick.This is the usual problem.
2. Remove the top and bottom and give it a good squirt of oil in areas that move. Wipe some off after you get it going.
3. At the end where the motor/hand wheel is remove the plate to see if the belt is broken or off of the pulley.
4. To get this going again you will have to do some forcing.
Apr 12, 2015 | Sewing Machines
Sewing machine grinding and needle won't go up and down without force. Air and cloth cleaned what I could.
THIS IS HARD W/O BEING THERE. ANYWAY HERE ARE SOME IDEAS:
1. REMOVE BOBBIN, CARRIER AND CLEAN AREA. OIL IN THE RACE (UNDER WHERE THE CARRIER GOES)-ONE DROP ONLY. TRY TO HAND ROTATE. IF IT IS OK THEN THE BOBBIN CARRIER WAS INSTALLED WRONG.
2. MOVE THE NEEDLE BAR BY MOVING THE HAND WHEEL. PLACE ONE DROP OF OIL ON THE BAR.
3. REMOVE THE TOP OF MACHINE AND MONITOR ALL MOVING PARTS AND CLEAN (USE QUE TIP). ANY PARTS STUCK TOGETHER MAY NEED A SMALL AMOUNT OF CARBURETOR CLEANER. OIL ALL MOVING METAL PARTS THAT MAKE CONTACT WITH EACH OTHER.
4. UNDER THE MACHINE REMOVE THE LID AND CLEAN AND OIL JUST AS ABOVE.
5. TRY TO MOVE THE HAND WHEEL.
6. IF THIS STILL DOESN'T WORK THE BELT MAY BE OUT OF ALIGNMENT. THE BELT HAS TO BE DONE BY REMOVING THE HAND WHEEL. ONCE THE BELT IS ACCESSED THE BOLT UNDER THE MOTOR IS LOOSENED. IF POSSIBLE TRY TO APPLY THE FOOT PEDAL A LITTLE WHILE ADJUSTING THE BELT. IT SHOULD NOT BE REAL TIGHT BUT MUST BE IN ALIGNMENT. PAY ATTENTION TO THE AMOUNT OF TURNS IT TAKES TO REMOVE THE OUTSIDE SHINY PART OF THE HAND WHEEL SO IT IS EASIER TO SET IT PROPERLY.
Nov 24, 2014 | Sewing Machines
Juki DDL-8500 bobbin stopped working, wheel slid over and rests against reverse bar.
Hi there
please check the silver wheel by hand move or stuck? if stuck please drop some gas or and cleaner inside it and move by hand until it be free.
regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Dec 16, 2013 | Juki Sewing Machines
Why is the hand wheel of my new consew 206rb-5 so tight? the machines hums when sewing, like beeind forced, is this part of the breaking in?
contact the one you bought the machine from & tell them how
tight the hand wheel is & see what they recommend
Jun 04, 2012 | Consew Sewing Machines
Error code 6 (thread in motor but there is none)
If you can turn the balance wheel by hand and the needle goes up and down it may be loose belts, if you can't turn the balance wheel by hand then there is definitely thread stuck somewhere in the raceway
Jun 24, 2010 | Brother CS6000i Computerized Sewing...
Kenmore 10 stitch needle won't move
hi there,
push or pull hand wheel clutch to engage
motion of needle and shutter.
if not check belt on downside of hand
wheel open cover motor,loosen bolt cover
see belt check if engage on pulley by
holding hand wheel move belt if
hand wheel move,if not tighten screw on
pulley from hand wheel and moter.
have a nice day and thanks
Apr 03, 2009 | Sewing Machines
Sewing Machines Logo
285 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
