Question about HP DeskJet 610cl InkJet Printer
Directions for putting in cartridges on Hp deskjet610cl printer
  • 906 Answers
Link
Kindly refer to above link. This instruction from HP will surely help you how to replace cartridge.
Thank you.
Posted on Jul 31, 2010
Dear customer service My 2510 xi photosmart printer keeps flashing "insert black or photo print cartridge" even after inserting brand new Hp no 56 printer cartridge. Please help Mukund sargur
do one thing try to connect the printer directly to wall outlet bypassing the serge protector.
disconnect the power chord from the back of the printer. wait for a minute press the on button for 10 times .reconnect the power chord to the back of the printer .then took out the cartridges take a lynt free cloth clean the copper contacts on the cartridges as well as in side the printer where we put in the cartridges.if still the issue is there call hp tech support they might help you
the hp tech support number is 18004746836
Oct 06, 2009 | Office Equipment & Supplies
Says cartridge cannot be used after initialization but brand new HP 363 cartridge sent directly by HP to me. This happens ever time I put a new cartridge in when prompted by printer to do so. Do I put new...
The following are common issues.
The following ink cartridges cannot be used after device initialization and must be replaced
Cause The wrong ink cartridge(s) are installed.
Solution The indicated ink cartridge(s) cannot be used after the device has undergone first time setup. Replace the ink cartridge(s) with the appropriate ink cartridges for the HP All-in-One. To find out the reorder number for all the ink cartridges that the HP All-in-One supports, see the printed documentation that came with the HP All-in-One.
If you are using compatible cartridges make sure they are reset for use.
Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might need to be cleaned. If there are no ink cartridges missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge.
Sep 21, 2009 | HP Photosmart 3310 Printer
Unable to load new cartrige in my hp 5150 printer
Open the unit to where you would normally access the printer cartridges. Unplug and after a minute replug the power cord. Printers are designed so that when the unit is open it stops at the middle so you can access the printer cartridges. Here is the manual for the 5150. There is a link on the left of the screen to give visual directions for replacing the cartridges.
http://www.viking-direct.co.uk/speciallinks/gb/vkg/source/DJ5150.pdf
Richard
Jul 07, 2009 | HP Office Equipment & Supplies
I have a HP Deskjet 882C printer and for the past month we are having problems printing text (B&W). We have removed the black ink cartridge and it still has a lot of ink in the cartridge. When we put a...
To clean the HP Inkjet print cartridges from the HP Toolbox, using a Windows operating system, perform these steps:
  1. Double-click the HP Toolbox icon on the computer screen.
  2. Click the Printer Services tab.
  3. Click Clean the print cartridges and follow the directions on the screen.
If the print quality improves after completing this sequence once, but the quality is still not quite good enough, repeat procedure. Start at Step 1, or click the Clean Again button on the final cleaning window. If this process does not improve the print quality, the HP Inkjet print cartridges might be low on ink. See the document that is provided with the black HP Inkjet print cartridge for instructions about how to use the ink level sensor to determine if the cartridge is low on ink. Replace the HP Inkjet print cartridges, if appropriate.
Jun 25, 2009 | HP DeskJet 882c InkJet Printer
NEEDING TO PUT THE COLOR DRUM BACK INTO THE PRINTER. TRYING TO PUT THE COLOR DRUMS BACK INTO THE PRINTER
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover theprint cartridge with a sheet of paper.
1.Open the print cartridge door, and remove the old print cartridge. See the recyclinginformation inside the print cartridge box.
CAUTION
To prevent damage to the print cartridge, hold the print cartridge at each end.
2.Remove the new print cartridge from the packaging, and gently rock the print cartridgefrom front to back to distribute the toner evenly inside the cartridge.
3.Pull the tab until all the tape is removed from the print cartridge. Put the tab in the printcartridge box to return for recycling.
4.Insert the new print cartridge in the printer, making sure that the print cartridge is inposition. Close the print cartridge door.
CAUTION
If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water.
Hot water sets toner into the fabric
You can see the pictures of it at: http://www.scribd.com/doc/4212097/hp-laserjet-1020-users-guide-manual
Jan 14, 2009 | HP LaserJet 1020 Printer
I need to change the ink cartridge, but i can't get it out
Look at the directions on the new cartridge on how to put it in and then do everything in reverse to get the current cartridge out of the printer.
Dec 17, 2008 | HP Deskjet 6940 InkJet Printer
Printer will not recognize refilled black HP cartridge (#74)
Try to get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Please post if that worked.
Dec 03, 2008 | HP DeskJet 5150 InkJet Printer
I am trying to take out the color cartridge and I can't get it out. Also I need to know how to put the new cartridges back in. Please help. G.J.
printer should be turned on...open the cover..cartridge will come in the middle and press the cartridge down and take it out...and put the new one in upward direction and you will hear a clicking sound.
Nov 26, 2008 | HP Officejet 5610 All-In-One InkJet...
HP DeskJet 610cl InkJet Printer Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
