Question about Canon EOS Rebel K2 with 28-90 lens 35mm Film Camera
I have a canon loom lens ef 28-90mm, when i look through the view finder i get a round image making cropping impossible unless i hold the camera a few inches away, then i cant see my functions. is this a problem with my camera or lens, because without the lens attached everything seems normal
Gryfox
  • 216 Answers
SOURCE: Canon S1 IS view finder / LCD monitor black out
This is a defective CCD that Canon is repairing free of charge. Go here for details: http://www.usa.canon.com:80/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8044&keycode=2112&id=29819
Posted on Nov 27, 2006
SOURCE: My camera wont turn off
I've purchased several of these cameras used as we liked our first on and it eventually failed with this same problem. I have had four of these now and they all end up with this same problem. Take the battery out then turn the selector to any new position and then off, put the battery back it and the lens should recline and camera turn off. One of the cameras would then work for a while after doing this but then hang up again. I think this is a very common problem based on my experience but no other confirmation than yours.
Posted on Sep 22, 2007
spotatohead
  • 95 Answers
SOURCE: My Cannon Rebel EOS 35mm film Camera is producing blank Film
If you are getting some photos where only part of the image is visible, then I suspect that they were photos where you used a flash.
Cameras have a specified maximum shutter speed for use with a flash, this is called its 'sync speed'. This is the fastest speed that the camera will need to open the lead shutter and close the trailing shutter in order to expose the entire surface area of the image and have it evenly lit by the flash unit. If you shoot too fast of a speed, then the shutter will only be partly completed its exposure and you'll get a photo with only part of the image showing. The faster the speed past the sync speed, the less the resulting area of the image. Most cameras will have a sync speed of 1/250 or less. I think a lot of the Rebel models are 1/90 - consult your manual.
Posted on Nov 29, 2008
mvititoe
  • 14 Answers
SOURCE: Canon 40D LCD Wont come on buSY flashes in view finder
Okay, this is simple. Your camera can take several pictures at one time in a burst. However when you release the shutter button your processor takes a second to actually SAVE the pictures to the card in the camera. One thing than has helped me in my wedding photography business is to buy the fastest speed cards I can find. It significantly reduced my "busy" time.
Posted on Dec 31, 2008
dotball
  • 64 Answers
SOURCE: Can't advance film, press shutter, no result
Do you have film in the camera? If so, is it an old film or you have just loaded it?
If it's an old film, could it be at the end of the roll - to check this, 'lightly' turn the rewind lever backwards and forwards. As the camera is pointing away from you, turning the rewind knob clockwise will normally rewind the film (don't press the rewind button in, we don't actually want to rewind the film yet), turning the knob clockwise should be tight and a firm stop, if the film is at the end, you will feel the same tight firm stop if you turn it counter-clockwise. Don't turn the rewind knob backwards (counter-clockwise) too hard, you'll unscrew it and it may fall apart. If turning it backwards rolls freely in a full circle, then you have film left.
Another option is that, since it's been so long since you used it, the loading of the film may have gone amis and sometimes the cassette will flip backwards, jamming the film in place so it wont advance - if you have loaded the film and not taken any pics or have not been able to advance it at all, it should be safe to open the back as the film will be in it's original loading position, if you have left the film in it from some time and don't know what stage it's up to it may be best to take it to a camera store where they will have a "Black Bag" to put the camera in and manually open and unload the film. Make sure you get an experienced person - some pimply-face teen that's never used a film camera can easily put their fingers through the shutter while it's in the black bag - I've seen it plenty of times.
OK, that's enough to get started, did this work or do we need to try more options?
**.The best way to acknowledge contribution is to rate it's relevance.**
Posted on Feb 03, 2009
Is the Raynox DCR 250 compatible with 75-300mm Canon lens?
Have a look at this page for discussion about this adapter. Depending on the lens you're using it with - the DOF can be extremely shallow and make focusing difficult. If you're in Auto Focus mode - try switching to manual and see if you can get better results.
Aug 21, 2012 | Canon EF 75-300mm f/4-5.6 II Lens
What are lenses that are compatible with the canon eos 5d mark ii
You can use Canon EF lenses. Be careful not to use EF-S lenses, as they cast a smaller image circle for cropped-sensor cameras, not big enough for full-frame cameras.There are other third-party manufacturers that make lenses with Canon EF mounts, such as Sigma and Tamron. Each manufacturer has their own designation for cropped-sensor lenses, so you'll have to check the specifications for each of them.
Apr 22, 2012 | Canon EOS 5D Mark II Digital Camera
WILL THE ABOVE LENSE WORK WITH A CANNON DIGITAL CAMERA AND CANNON 35MIL CAMERA
Yes, it's suitable for 35mm EOS mount Canons and all digital models. If the digital SLR has an APS-C sensor then the image will be cropped and will give the same viewing angles as a 112-480mm on a 35mm camera.
Oct 03, 2010 | Canon EF 70-300mm f/4-5.6 IS USM Lens
Item: Canon EF-S 17-85mm 1:4-5.6 IS USM Camera: Canon 20D Problem: At a focal length of below 35mm with the aperture set smaller than f4.0 in any programme mode an Err 99 appears in the view finder,and...
Check this article which will lead you through diagnosing the problem and a possible fix.
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Sep 20, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon Extender EF 2x II
There are 2 Canon fittings, EF for all EOS cameras and EF-S for 'crop' cameras. The Canon extender does not fit crop cameras. Whichever make you look at, make sure it will fit the type of mount you have.
If you have not yet bought your lens of choice, Sigma are good and do their own extender compatible with their own lenses but not Canon's. This may be a good option for you
Mar 07, 2010 | Canon EF 2x II Extender Lens 6846A004
Cannon lenses
All canon EF lenses (and compatibles e.g. Sigma EX) can be used with both analog and digital  EOS-bodies. Depending on the sensor size (usually smaller than a 35 mm negative) a crop-factor due to the smaller field of view must be considered.  Example: Canon EF 50mm/1.8 lens used on a digital EOS (40D, crop factor 1.6) equals a 80mm lens (50mm x 1.6) compared to analog cameras using 35mm film. Some digital EOS-models can also use EF-S lens-series.
Nov 28, 2008 | Canon EOS 40D Digital Camera
No Preview image on screen, Must use Viewfinder
yep
sorry you bought a DSLR...its impossible...
only with the new DSLR's its possible, (rebel XSi & rebel XS)
this feature is called 'live view'.
Nov 13, 2008 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
I see a circle when thru view finder
Sounds like the Focusing screen in the camera is missing. (its the frosted piece of glass that is above the mirror)
Sep 28, 2008 | Canon EOS-5D 12.8 Megapixel SLR Digital...
Fuzzy photos
Turn the small dial to the right of your view finder either "+" or "-" until picture is clear inth eview finder
Jan 09, 2008 | Canon Digital Rebel / EOS-300D Digital...
Blurred night time football pictures
The standard canon 75-300 lens is not considered a "fast" lens. Because of this, when zooming in on objects you are actually reducing the amount of light hitting the image sensor. Fast lenses cost $$$$. Just google "Canon L Glass" and you will see what I'm talking about. Try opening the field of view (zooming out) to allow more light to be absorbed bu the image senor. Crop your subject later in whatever software you use. You can also use one of the manual modes and up your f-stop to make the camera more sensitive to low-light conditions (higher f-stop means higher film speed.. higher film speed is how fast the "film"... aka image sensor absorbs the light. for action photos, faster film speed is key!!). have fun experimenting.
Sep 26, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Canon EOS Rebel K2 with 28-90 lens 35mm Film Camera Logo
107 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
