Power supply fan is makeing a lot of noise - Computers & Internet
  • Nicoline Jun 13, 2008
    Suddenly the fan started making a lot of noise but the computer seems "dead". What's going on?
  • Anonymous Jul 17, 2008
    Once the computer warms up the hard drive starts with the fan noise. It drives me crazy. I keep turning the computer off when done with it.
    Novelist:
  • 150 Answers
1) Unplug the power cord and give the fan a good cleaning
with a soft paint brush and a vacuum cleaner.
i.e. Let the fans spin up by the vacuum and than bring
the brush against it.
2) If this fails, it's time to replace the fan:
a) Upgrade or replace the power supply enclosure with more
power/higher quality.
This is usually a good investment anyway.
b) Replace the fan only as described below:
Open up the computer (remove sides)
Unplug all the power supply harnesses from
the mother board, drives and chassis fans.
Unscrew and remove the complete power supply
enclosure at back of computer (ie top of the tower)
Vacuum it out as much as possible.
Disassemble the power supply enclosure by removing
more screws and removing the metal cover.
Unplug the fan from the circuit board, remove it
and take it to a computer store/ builder.
buy another fan just like it
reverse the process to put your computer back together.
1) A new power supply should cost $65 to $120
depending on power and quality. The bigger the better.
But make sure it fits mechanically into the existing chassis
and that the AT generation matches ***********-board.
2) A new fan should cost $15 to $25. Makes sure it runs on
the same voltage, and that it is physically compatible.
Martin
Posted on Apr 24, 2008
The motherboard may have the bulging capacitor issue.
The fan is getting no instruction from the mobo so just goes spin crazy.
Do you have a solid amber or flashing amber power LED?
Posted on Jun 22, 2009
2 Suggested Answers
  • 1149 Answers
SOURCE: acer m5100 desktop fan is making noise
Hi:
Often, just dust can make fans noisy. You can unplug everything, take the side cover off of your tower, and blow it out with a can of the air duster you can buy at a computer store, paying close attention to the fans. If you are not comfortable with this, a local shop should be able to clean it up for you for not a lot of cash, and if a fan is really bad, they could identify which one it is for you too.
Posted on Oct 26, 2009
My desktop computer will display anything when turned on, and the fan and hardrive both make a loud constant noise.
Maybe you need a larger power supply depending on if you might have added more hardware such as a graphics card, or an extra monitor to your system. This sometimes results in an inefficient supply of power, making your fan to your power supply work harder, thus making noise.
Nov 19, 2012 | Gateway Computers & Internet
A fan is making a horrible noise
hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Dec 09, 2010 | HP Pavilion Elite m9510f PC Desktop
The fan in my all-in-one desktop keeps making a grinding noise. How can I get a replacement fan?
The grinding noise is probably from the power supply.
If you are not doing regular maintenance on your computer, the fan of the power supply may be filled with dust. With the fan operating like that, your computer is at a risk of components overheating.
The best way is to open the case and clean the fan in the power supply with some kind of compressed gas. These are available in hardware stores.
If the noice is still not going away after that, then the best ting to do is replacing the power supply.
(Note: it is also possible that there is another component that makes the noise. The best way to make sure it is the fan in the power supply, is to turn the computer on, with the case opened. )
Sep 21, 2010 | Averatec Computers & Internet
Thought it was the western digital harddrive,bought a new harddrive and the problem is the same. The computer when running gets very loud. Now I am wondering if the problem is actually the power supply....
Your P.C. may need cleaning inside, Dust may of gathered in Fans, HeatSink, etc. When you connect things to your P.C. normally extra power is needed from help run the process. Hence why your P.C. gets more noisier and things get hotter needing the fans to cool them. Or your Power Supply Unit (PSU) replacing for more Watts.
Aug 22, 2010 | Dell XPS 200 PC Desktop
My cooling fan (not the one with the shroud) makes a lot of noise. Can I get and easily install a replacement.
yes you can replace the all fan inside, except the power supply fan . In these situation is normaly the power supply box is changed.
Jul 12, 2010 | Gateway 550GR PC Desktop
My gateway model gx70183 will not power on or off. Fan was making a lot of noise and the computer quit
hi there, there is already problem on fan,noise of fans could develop overload current on system and this system is protected by overload protection,it will trip off of your cpu.replace fan where ever it was located,there is fans on Power supply unit(PSU) ,also in processor,also in video card,On PSU you can replace PSU,try to find another PC which is not use,use temporary the power supply to check if ignore the tripping of your pc.Also clean the terminals of your memory card by eraser head of pencil,also with the video card.have a nice day,dont forget to fix my rate,thanks a lot.
May 10, 2010 | Computers & Internet
Lot of noise from the fan
no need to replace the power supply just open the power supply and replace the fan if not possible then insert some oil drops in the fan sound will definetly end
Feb 26, 2010 | Dell (C3760) 305-Watt Power Supply
Hp compaq dc5000sff cpu fan sounds like a jet taking off
Not sure how long you have had the Desktop. However it will be one of two things. If it used to run quitely and now is making lots of noise then immediately take it to be replaced. Fans on power supplies cannot be fixed. If it should stop completely then the heat that builds up in your desktop could damage your components. Second, if it is fairly new and has always sounded that way then you are ok. Yes, there are some fans that are very loud, again you can have it replaced. They sell "quite fans" now that make no noise at all. But first and foremost if you start having problems like unusual reboots, lock ups, etc then your computer is getting overheated and the power supply which houses the fan needs to be replaced. Hope this helps.
Dec 24, 2008 | Computers & Internet
Shuttle XPC - fan on the back does not stop
I would suggest you have a fan with faulty bearing
and i thing the power supply could want changing
Sep 01, 2008 | Shuttle first SFF barebone with the power...
Sony vaio cpu is makes a lot of noise
im not 100% sure nut i think its the power supply cause some power supplys are very noisy and it might be why the cpu is overheating
Aug 09, 2008 | Sony VAIO PCV-RS720G (027242658103) PC...
Computers & Internet Logo
2,165 people viewed this question
David Payne
David Payne
