Question about Whirlpool Ovens
Where can I get a spare top element for a Whirlpool oven Type FCES 6, Model AKP503/NB/-2 ? Am located in Pretoria FHS
    Genius:
  • 1,417 Answers
you can order for the part from the below site
www.candmdomesticappliances.co.uk
shop.ukwhitegoods.co.uk
espares.co.uk
frontwasher.com
the above site offer set of good part to customer so you can go on shopping
thank you .
Posted on Jul 31, 2010
Appears the heating element has gone out - or maybe part of it - no light in the top of the oven. How to replace and purchase parts
Depends where you live. Just Google
make model spares
make model oven element
you can also get the common ones at places like Home Depot or Canadian Tire.
Jan 22, 2016 | Ovens
Both Oven elements do never come on Together, Top Works When turn on Broil and Bottom when On Bake & Auto. Pls help.
that's normal. The top element is meant for broiling only while the bottom one is meant for baking.
Mar 11, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Oven will not maintain heat
possible thermostat problem in the switch
call the technician or get the part from tyhe servide agent spares
Feb 28, 2018 | Whirlpool Ovens
Cooker trips mcb when put on a setting that requires heat,would it be element or thermostat,model number is fcsm6
Hi and welcome to FixYa, I am Kelly.
Most likely it is the element. You can prove that the element is bad by disconnecting one wire and reading the terminal to the outside of the element. If you read a short (ZERO Ohms) the element is bad. It is possible for only one terminal to read to the outside case of the element.
You can find replacement elements in the UK on line here:
http://shop.ukwhitegoods.co.uk/Cooker+%252526+Oven+Parts/Whirlpool+Spares.htm
Your replacement oven element (if it is the bad element) will be listed on the label inside the oven door and will look like this: 5320R488 IRCA 240V 2000W RL6 02476
Since you did not metion if it was a cook top or oven element I listed both.
Thanks for choosing FixYa.
Kelly
Oct 06, 2010 | Whirlpool Ovens
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
Nothing on the oven works, however the burners work on top, but when we turn the oven on nothing happens I even grabbed hold of the heating element in the stove and felt no heat or burn myself or anything
Check the thermal fuses / sensors mounted on the top exterior of the heating chamber and also the heating element. Both accessible from the rear of the oven. The element is most likely to have gone. It will be a 2 or 3 turn coil type with the fan mounted to the middle of it or a flat element with no fan. You will need to check the number of turns of the coiled element and also the mounting holes to ensure you get the right type. Turn off the mains power at the breaker or distribution point. You can get to the element behind the rear plate of the oven cavity by removing the side shelf slides, and rear panel by undoing the securing screws on the plate (2 or 4 depending on the exact model you have). Often a good idea to take a photo of the element mounting and take the model and serial no of the oven so that you can take this to the domestic appliance shop or email it to an online supplier to make sure that the element they supply is correct for your exact oven.
Nov 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Dec 11, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool oven heating element
Are you trying to replace the stove top element, or oven element? For the stove top element, just lift up the side opposite where it plugs in and pull straight out.
The oven element usually have one or two screws holding a plate in near where the elements go into the back of the oven. Remove the screws and pull straight out. Reverse the procedure to install a new element. The top broil element will be secured in with a couple brackets to hold it up, these must be unscrewed, removed, and then pull the broil element out.
Remember to turn off power to the range before replacing any of the elements.
Aug 27, 2008 | Whirlpool RBS305PD Electric Single Oven
Ovens Logo
91 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
