Question about Lenovo G550-29583AU Notebook
Starting window I am having the problem in my lenovo laptop,when power on the laptop the LED's are lighting and the LCD screen also displayed, but the screen stay on starting window and i can't enter in to the desktop window
    Guru:
  • 370 Answers
There's a possibility that the problem is with the HDD or just the Operating System. If its the HDD itself, you will have to replaced it or reimage it. But if its just the Operating system,what you can do is reinstall the Operating System using the One Key Recovery Sofware or the Recovery Disc that came with the computer. Follow these steps for you to be able to reinstall the Operating System using the One Key Recovery.
1. Turn off the computer.
2. Press the little button near the power button, it usually do have a drawing of an icon that looks like a horse shoe or a headset.
3. There will be a window that will appear which do have three option, One Key Antivirus, One Key Recovery and System Setup. Choose One key Recovery.
4. There will be another window that will appear which do have two option, Restore from initial backup and Restore from user backup,Choose Restore from initial back up
5. It will asked you if you want to continue, Just click on OK or YES.
6. Once done, Reboot the computer.
For Recovery Disc,
1. Insert the disc inside the drive.
2. Turn off the computer then turn it back on and keep on tapping F12
3. There will a window that will appear which do have three options, HDD,ODD/DVD/CD, and NAT, choose ODD/DVD/CD
4. It will asked you to press any key immediately, you will need to press any key immediately so that it will boot from ODD.
5. It will asked you to choose a partition, choose Disc 0 partition 1
6. Reboot computer once done.
I hope this information will be helpful. Thank you for using FixYa...
Posted on Feb 25, 2011
Lonovo ideapad tuns on but doesnt work
You turn on but it won't boot to your OS? or powers on (i.e LED power light comes on) but you get no display at all, not even Lenovo logo?
If it's not booting try booting from your windows CD/DVD and running a start up repair. This is a guide for Windows 7 but should be very similar process for Windows Vista.
http://pcsupport.about.com/od/toolsofthetrade/ss/windows-7-startup-repair.htm
If you get no display at all (Not even a Lenovo splash screen) and just lights, try popping your battery out and power the system up on mains only. If this works, pop your battery back in, it should be begin to charge. You laptop should continue to work from now on. This is a problem that occurs from time to time on any laptop and is cleared this way.
If removing the battery doesn't work I would try removing/re-seating/swapping out RAM.
Let me know how it goes, I may be able to help further.
Dec 05, 2013 | Lenovo IdeaPad S10-3 Netbook
Blank screen when powing on, won't start.
Toshiba laptop LCD screen. It is to provide you with high quality laptop inverter replacement. The design of the Toshiba laptop LCD screen is 100% compatible with the Toshiba digital or model manufacturers.
Product Features:
1. Model: Toshiba laptop LCD screen
2. Each test notebook computer LCD screen before shipment, 100% of the working conditions:
3.100% new high quality replacement Toshiba laptop LCD screen
4. Toshiba inverter can be used for the other models and Inverter part No
5. Toshiba the notebook LCD InverterDefective backlight inverter can have the following symptoms:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
In good working condition. The best match for your device. High-quality, durable, easy to install. http://www.lcdinverters.net/Laptop-Inverter/Toshiba/Toshiba.html
Nov 01, 2012 | Toshiba Computers & Internet
I have a Lenovo L520 with a dim screen.
You may have a faulty inverter, this supplies high voltage to the CCFL lamp that provides the back light for the LCD screen.
Sep 10, 2012 | Lenovo ThinkPad L520 15.6" LED 2.1GHz 4GB...
T42p display lights for a couple of minutes through startup then goes dark
But fan still runs, and it sounds like the harddrive is spinning?
Diagnose.
Do you have a VGA monitor available?
You can use a CRT type, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
http://en.wikipedia.org/wiki/VGA_connector
1) Laptop OFF, monitor OFF, connect the VGA monitor cable to the left side of the ThinkPad T42. (DisplayPort)
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default, the display should show on the external VGA monitor.
If not;
There are at least three display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY.
Press, and hold down on the Fn key, and at the same time tap once on the F7 key. The F7 key is the Display Toggle-Over key.
3) Good display on external monitor?
Problem is the video cable, or inside the Display Assembly.
Since the display goes dark after a couple of minutes, I can tell you the problem is the screen Inverter, or Backlight.
(Inside the Display Assembly)
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED's.
(Light Emitting Diode)
The Lenovo ThinkPad T42 series of Notebook PC's, uses a single CCFL for a Backlight,
http://www.screentekinc.com/IBM__ThinkPad__T42-series-laptops-lcd-screens.shtml
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height ]
A screen Inverter converts the power from the laptop, for the LCD screen, and Backlight.
(Older versions of backlighting that used a series of LED's, used a screen Inverter. Newer versions do not. For these replace the LCD screen)
A screen Inverter and an LCD screen are a MATCHED unit. Make sure you get the correct screen Inverter, or LCD screen, when buying.
Primer over.
One example of a screen Inverter for the T42's,
http://battery-adapter.com/product_info.php/products_id/3381/vThinkpad+T42
Pictorial guide for replacing a screen Inverter, in a ThinkPad T42 series of Notebook PC,
http://www.insidemylaptop.com/replace-screen-inverter-in-ibm-thinkpad-t40-t40p-t41-t41p-t42-t42p-laptops/
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Lenovo Support link to the Hardware Maintenance Manual, for the ThinkPad T42 series of Notebook PC's,
(HMM. It is a Service Manual),
http://support.lenovo.com/en_US/guides-and-manuals/default.page?
Click on the bold black subheading -
Hardware maintenance manuals
Then click on the blue -> [+] Click for files
It is a PDF file.
It may take up to 30 seconds before the first page comes up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 29, 2012 | Lenovo ThinkPad T42 Notebook
HP Pavilion dv6-3007tu
what exactly is your problem? will it not start?
Jul 25, 2011 | HP Pavilion dv6-1122us Notebook
I own a lenovo laptop G465 which I bought from lenovo sm cubao last april 2011. One morning when I turned my laptop on I was dismayed to find out that there was no screen display. I've been very...
Does the laptop indicate any power? does the LED turn on and stay on but you can't see anything on the screen? Is there no power at all, No LED light turns on and everything is switched off?
Since you bought it April 2011 it's only been a month so there should still be warranty for your laptop. If you are comfortable enough try removing the memory sticks, the hard drive, the WLAN card the battery and try to plug it in the power outlet without those and check if it will turn on. Otherwise find your receipt and bring it back to the store "SM" where you bought it and have it checked by one of their technicians or possibly get it replaced.
Hope you find this helpful.
BTW: I'm also from the Philippines.
May 10, 2011 | Lenovo Computers & Internet
My s10e lenovo is on but there is no display please guide me what is the solution of it. all lights are on but display is totally blank
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 16, 2010 | Lenovo IdeaPad S10e Notebook
Starting window
You have a corrupted operating system try to reinstall your OS. :)
Jul 31, 2010 | Lenovo 3000 Y410 Laptop
Lenovo G550-29583AU Notebook Logo
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
