Question about JVC Televison & Video
JVC television RM-C1100 (code on remote)
I have a tv as above which came over to me from germany. On trying to set it up everything worked fine apart from when playing a dvd there is no picture, just sound. All cables were just swapped over as they were on the old tv. Do you know if it is anything to do with the fact that it is from germany or what the problem could be?
techman
  • 3130 Answers
SOURCE: jvc av-28gt1sjf
This sounds like a microprocessor controller problem?? Try to reset the tv by unplugging overnight and starting fresh in the am. If it will go in av then your all set BVut if it dosent go into the menu to see if theres any kind of lockout in the set up for the av. If not then youll have to have the set looked at by a pro. Good Luck
Posted on Jun 07, 2006
  • 1694 Answers
SOURCE: Trying to get channels above 42 to 99
Many older sets have an upper channel limit = 42,46,54,64,etc.
If you can't dial direct ...4-3 enter, 4-4 enter,etc...........
If you CAN dial direct, then you would need a service remote
to program.............becuz it's a hotel TV.........
Posted on Dec 01, 2007
maklean
  • 1665 Answers
SOURCE: how to change video line without a remote
Just refer THIS link and it will tell you everything as how to set it up step by step with the diagrams.
Posted on Feb 19, 2008
SOURCE: Need set up code for old JVC TV
try 10053..
Posted on Jul 22, 2008
chessmaster2
  • 160 Answers
SOURCE: Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Posted on Dec 01, 2008
How to set up codes rm 136e jvc code
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 14, 2014 | JVC AV-27530 27" TV
Bt vision remote codes
This remote is for a forgein JVC tv set. It may not work with US models
Dec 06, 2013 | Televison & Video
Jvc hd-56fn97 tv but need codes for universal remote jvc rm-svd701u
try but this may not work and if programs at all be missing key features.
Nov 29, 2012 | JVC HD-56FN97 56" Television
Code chunghop RM 139ES for TV Mitsubishi?
The Mitsubishi TV codes for this remote are 011 and 051.
Programming instructions:
1. Switch on the TV
2. Press the "SET" button in the top-left corner of your Chunghop remote until the LED next to the "SET" button illuminates.
3. Enter the first code above 0 1 1 using the numerical buttons on the remote.
The LED next to the "SET" button will go out if you have correctly entered a code.
4. Test the remote with the TV. If it doesn't work - or doesn't operate the TV functions as you would expect - repeat the above steps for the other code.
Please note: Not all universal remotes will work with all TVs.
If the codes above don't work please post back for further assistance. It may be that your remote wont work with your TV or you may need to run the code search feature of the remote to find the correct code.
Hope this helps.
Regards,
BElectric
Dec 30, 2010 | Televison & Video
I have a jvc television and bought a universal remote. i dont know the code for the remote. do you know the code?
These are the steps on how to program your Universal Remote Control to your JVC TV even without the list of code.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button you want to set up
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-6.
Jun 14, 2010 | JVC RM-C18G-1H Remote Control
REmote control RM-C1257G not working even after trying new batteries
Try this
1. Get camera phone
2. set camera phone to to take picture
3. point remote at camera and look at the camera display
4. press buttons on the remote, you should a light from the Remotes IR.
5a. If NO light is seen, your remote is broken. you can try replacing the batteries to double check
5b. if Yes, light is seen. Your remote is working and you may have a problem with the TV.
As a double check, get a remote you know is working and try the same thing to verify that you are checking the remotes correctly.
May 27, 2009 | JVC LT-26X575 26 in. LCD HDTV
Remote Codes for Commtel Control Freak and JVC
0053, 1253, 1923 if those don't work, I have others.
Jan 18, 2009 | JVC RM-C18G-1H Remote Control
Opening the case of a JVC Remote Control
Not having seen that particular one, remote cases usually have a couple screws under the battery to lock the case together and then a number of plastic tabs around the perimiter that hold the joint closed. find the screws (sometimes they hide them under labels) - I don't know what it is about screws that manufacturers don't like to show. Either think they are not cosmetic or don't want us take-it-apart maniacs to get in. Anyway, get the screws loose then (this is the hard part) carefully pry open the case joint, feeling where and how the tabs snap out and then be careful not to have everything inside go flying when the last one lets loose. Almost impossible to not leave little gouge marks in the joint.
Hope Ya Fis It!
Jan 08, 2008 | JVC AV-27230 27" TV
Jvc av-28gt1sjf
Jun 07, 2006 | JVC AV-28GT1B 28" TV
Televison & Video Logo
1,043 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
