Question about Milwaukee Tool Milwaukee 48 11 2830 Battery 28V
18 v batterys die will not charge - Milwaukee Tool Milwaukee 48 11 2830 Battery 28V
  • 700 Answers
This are new batteries and should be still under warranty, check your warranty papers.
if these are out of warranty, unfortunately you cannot do much, you need to buy new ones...
if you find this advice useful, please give me your vote, thanx!
Posted on Jul 31, 2010
I was taking pictures when the battery died. I charged the battery, and now the camera won't turn on. Any clue on what to do?
hello,i'm afraid your battery has died for good,as not too sure how often you have been charging it up after usage?,as all lithium battery's are a bit temperamental,and do not like been overcharged,it's always a good idea to vary the time of use,as well as the recharge period,so do not always give it the same period of charge each time,also a good idea to have your charger checked by a precision instrument to measure the rate,as a malfunctioning charger,will destroy your battery! hope that helps, cheers.
Aug 18, 2013 | Nikon D3200 24.2 MP CMOS Digital SLR with...
Nikon Coolpix: can't charge battery
Charge up the battery. Most digital cameras use a lithium battery and the battery needs to be removed from the camera and inserted into a charge adapter to be charged.
May 31, 2012 | Nikon COOLPIX L20 Digital Camera
The charge doesn't last or even charge correctly.
The battery is bad. they sometimes die rather suddenly. sometimes a cell shorts out. bur sometimes they just go bad. You can have them refurbished for about $40.
Aug 14, 2011 | Dewalt Accessories Batteries 18 Volt
BATTERY SHORTS WHEN YOU INSERT BATTERY
If it is new Nano Li-ion technology- try to fully charge battery, they work FULL power until they discharge, so they die instantly, NOT like Nickel batteries go slower till they die, so maybe that is only your first impression that it shorts...
May 06, 2010 | Dewalt 18 Volt Compact Drill Kit
Battery does not seem to hold charge on Advent 9115 laptop. 18 months old. Charged overnight. Switches off within half hour of switching on.
Sounds like your battery is dying.
Laptops should not be run on mains power all the time, it kills the battery. Should be run on battery until battery warning occurs, then plug in to recharge.
You'll need a new battery at this stage.
Apr 04, 2010 | Computers & Internet
Kinroad 125 XT-18 motorbike battery doesn't hold charge
its not likley to be the battery its the charging systen on the bike thats faled on you check the regulator is working then all the fuses are good ones
Jan 18, 2010 | 2005 Kymco Stryker 125
D80 battery dies when using larger lens
If your 70-300 lens is using VR and your 18-135 lens is not then this is correct. VR uses a lot of battery juice so you should try to keep it off if you are not using it. Also, try toset auto-focus off also if you are concerned about battery life.
Dec 09, 2009 | Nikon D80 Digital Camera with 18-135mm...
Latitude d505 not charging
If the system runs using the AC adapter, but the battery doesn't hold a charge and the battery indicator LED flashes orange, then replace the battery (A battery with an internal failure may flash 4 times orange then once green and repeat)
The normal lifespan of a PC battery is 300 to 500 recharge/discharge cycles (roughly 12 to 18 months)
Jan 31, 2009 | Computers & Internet
Jobmate 18 volt chordless drill charging
About 60 minutes...max 90 minutes. Do NOT leave it on the charger for hours and hours...that just cooks the battery.
And switch regularly between the two batteries...else the one that doesn't get used will die.
Jan 20, 2009 | Drills
Milwaukee Tool Milwaukee 48 11 2830 Battery 28V Logo
149 people viewed this question
Top Milwaukee Tool Drills Experts
Mike
andrew-loeb
Level 1 Expert
Are you a Milwaukee Tool Drill Expert? Answer questions, earn points and help others
