Question about Honda Arnold 21" Mower Blade 490 100 0034
Turn the right or left to remove the nut
Whuch way does the nut turn to replace the blade
  • 26 Answers
All most every blade mount bolt turns out in a counter clock wise rotation facing the bolt head
Posted on Aug 01, 2010
How do i replace the blades?
Raise the mower high enough that you can reach the nut that holds the blades. Remove the wires from the spark plugs so the engine can't start. Jamb the blade with a piece of 2x4 so it won't turn while loosening the holding nut. Remove the nut but keep track of the location and the direction of any washer that may be there. Some washers are cupped so make sure you know which way the cup goes. Then remove and replace the blade. Make sure you get the nut tight enough. You will need to jamb the blade again so you can tighten the nut. This is a good time to scape it clean under there too.
I use a putty knife and sometimes a wrecking bar to clean the underside.
Dec 25, 2015 | Garden
How do you change a blade on model 36-075
Lots of saws have left hand threads on the nut that holds the blade in place. It is designed so that if the saw starts up and the nut isn't snug, the nut and the blade slipping on the turning arbor would tend to tighten the nut as they slip against the force of the spinning arbor.
1. Unplug the saw.
2. Hold on to the blade tightly with one hand.
3. Put the wrench on the arbor nut and turn it in the direction you would turn it as if the wrench were turning the blade to cut wood.
If you've previously overtightened the blade, jamb a piece of wood against the teeth and the saw table top and then follow step 3.
If the motor is on the left side of the blade as you face the saw, then it's a standard right hand nut.
If the motor is on the right side of the blade as you face the saw, then its a left handed nut.
Sep 17, 2014 | Delta Circular Saw Blade, 10 Dia, 50T -...
How replace blade on 7 1/4 circular saw - Milwaukee
UNPLUG THE SAW first!! Look for the blade lock on the top or front of the motor body, Hold the lock button down while turning the blade nut with a wrench. After a bit you'll feel the lock button engage and hold the blade firm. Rotate the the wrench counter clockwise and remove the nut, Slide the blade out from under the guard and replace with a new one. Reinstall the nut following the above procedure.
Sep 15, 2014 | Milwaukee Tool Saws
Replacing a craftsman raial arm saw blade
Arbor nuts always loosen by turning them in the same direction the blade turns when cutting. This makes them self tightening while the saw is in use.
May 30, 2012 | Saws
PLEASE PROVIDE INSTRUCTIONS FOR INSTALLING AND REMOVING BLADES CHEERS DENIS
There are two nuts up by the blade that will be removed to get blade off also there is a small screw next to the blade itself on the opposite side. You must loosen 2 big nuts then back this small screw off a few turns will be inside a small hole near blade. Once blade chain is loose take nuts off drop blade replace do everything now in reverse.
May 06, 2011 | Garden
How do I change the blade on a dewalt compound (12 in) miter saw?
With the saw unplugged - The blade needs to be locked in place so it will not turn when you put a wrench on the nut located on the left side of the blade that holds the blade on. This is done with a locking pin on the right side of the blade. Push the pin in and rotate the blade by hand until the pin locks into the blade and prevents it from moving. With the pin pushed in put a wrench on the large nut on the left side of the blade and turn it. This may be reversed threaded, so you may have to turn the nut clockwise in order to loosen it. When tightening the nut after replacing the blade, you will have to once again lock the blade with the same pin.
Perhaps this video will help you locate the locking pin.
http://www.youtube.com/watch?v=oKmIB-0AE1w&feature=related
Aug 28, 2010 | Dewalt Saws
Replacing 10 in blade
Look at the threads on the saw blade arbor, that will tell you which way to turn the nut to get it off.
May 04, 2010 | Craftsman 10" Table Saw
How do I remove the blade from a Makita MK470 tile saw? I can't figure out how to hold the saw blade so that I can turn the nut hodling it on. The nut is on pretty tight and I need to lock the blade so I...
There is not a lock on this saw. If the blade is to tight to hold by hand you need to use an impact wrench. It will loosen the nut before the blade has time to start spinning.
Nov 11, 2009 | Saws
Cant get the old blade off
should be a blade lock button, if not i clip vise grips on mine let the table keep the blade from turning put wrench on nut and tap wrench with hammer see if ya can loosen nut good luck billy
Mar 18, 2009 | Husky Wet Tile/Stone Saw with with Laser...
Black and decker mm675 lawn hog
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
May 19, 2008 | Black & Decker 19" Electric Lawnhog...
Honda Arnold 21"  Mower Blade  490  100  0034 Logo
216 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
