Question about Regal Ware (RW58230R) 30-Cup Coffee Maker
Where can i find parts for a regalware k1355 55 cup coffee urn
I have a Regalware 55 cup coffee urn, model #K1355. I do not have a part's list for unit. The part I'm looking for is a small switch. It says WR-I think that stands for White Rodgers. It's a four terminal switch two terminals on each side. The numbers on switch are161491 085n, other numbers on switch are250c, 158E,andTf318c. can you help me find this switch.
Posted on Mar 07, 2011
Where can I locate Coffee Urn replacementThermostat?
Abtec seems to be the only place.
Search Results
DeLonghi DCU72 Coffee Urn Parts - eReplacement Parts
https://www.ereplacementparts.com/delonghi-dcu72-coffee-urn-parts-c-122345_1223... Need to fix your DCU72 Coffee Urn? We have parts, diagrams, accessories and repair advice to make your tool repairs easy.
Amazon.com ' Delonghi DCU72 Ultimate Coffee Urn: Coffee Urns
https://amazon.com/Delonghi-DCU72-Ultimate-Coffee-Urn/dp/B00064XTDK Enter your model number to make sure this fits. 20-60 Cup Capacity; Keep Warm Function - Once it's finished brewing it automatically switches to the warming cycle and keeps your coffee at the perfect temperature. Freshness Indicator is activated by the keep warm function and tells you how long the coffee has been ...
Delonghi coffee urns - Abtec Parts
abtecparts.com/Delonghi_coffee_urns.htm Large glass knob with nut for lid holes measuring 1.1/2 to 2.1/2 inches. ... Glass knob for models DCU50T, DCU60, DCU60T, DCU61, DCU62, DCU62B, DCU70, DCU70T, DCU72 manufactured before 2001. ... Glass knob (fits 2 inch diameter hole) for models DCU50T, DCU60, DCU60T, DCU61, DCU62, DCU62B ...
delonghi model dcu72 coffee urn thermostat Google Search
Mar 06, 2018 | Coffee Makers & Espresso Machines
I have a Regalware 55 cup coffee urn model #K1355. I do not have a parts list for it. The part I'm looking for is a small Switch. It say's W-R on it which means White Rodgers. The numbers on the switch...
It's an Inter Control type 161-491 Discomelt Plus thermal protection device. The 250°C bimetal disc switch failed, so the 318°C thermal fuse opened. West Bend uses the same device. They are readily available online as part # P200-97.
Mar 07, 2011 | Regal Ware (RW58230R) 30-Cup Coffee Maker
45 cup coffee urn How much water and how much coffee?
20 cups of coffee needs 2 cups of coffee grounds
30 cups of coffee needs 2 1/2 cups if grounds
40 cups of coffee needs 3 cups of grounds
45 cups of coffee needs 3 1/2 cups of grounds
1 cup brewed coffee = 5 fluid ounces
* use standard measuring cups
Oct 22, 2010 | Salton Melitta MEU45 Stainless Steel -...
How much coffee do I use to make coffee in the 55 cup urn? How long does it take to brew the full urn?
use 7- 8 0z cups fresh grounds. Time to brew depends on efficiency of urn. Maybe 15-20 minutes on average.
Feb 02, 2010 | Faberware 12-55 Cup Coffee Urn
Need a P13-1355 stem and spring for 55 cup urn know where i can find one?? i have checked all parts sites i can find on line all say out of stock
I called Farberware directly and they do not make this coffee urn any longer and no longer stock the part. They do however stock parts for a 36 cup urn that they said had the same size stem pump on the end. The difference was in the length. I ordered 2 of these and plan on using 1 to lengthen the other one to the correct length. My son is a welder and believes he can do this for me. We will see what happens.
Nov 23, 2009 | Faberware 12-55 Cup Coffee Urn
7006 percolater
262-626-2121 OR WWW.REGALWARE,COM
Jan 16, 2009 | Regal Ware (RW58230R) 30-Cup Coffee Maker
10-22 urn
If you have the L1350/155C, the manual states 1-1/4 cups coffee for 12 (5 oz) cups, for 30 cups use 3 cups coffee using standard measuring cups. Take the stem & filter out when the coffee has finished brewing so the bitter oils do not get into the coffee.
Dec 17, 2008 | Faberware 10-22 Cup Coffee Urn
How to make coffee with 101-cup percolator urn (Regalware)?
Simply fill with COLD water to the number of cups desired.
Place the stem and basket in the pot and put one 8 oz cup of coffee for every 20 cups of water into the basket...when doing 100 cups I add an extra 12 oz of coffee for a good coffee flavor.
Place the perforated lid on the coffee basket that is in the pot (if there is a lid--some do not have a lid). Put the cover for the coffee pot in place.
Plug in.
Turn on if there is a switch.
Give these large pots about 1 minute per cup, brewing time...that is a little over an hour usually to brew 100 cups. The coffee maker will percolate with the water coming up through the stem and over the coffee as the water heats. Usually there is an indicator light that comes on when it is finished.
If holding the coffee for awhile, it tastes best if you remove the stem and basket and it will maintain the heat without doing more "perking" and becoming stronger or bitter.
Be sure to wash it out and dry it well, leaving the lid loose or upside down for storage so that the pot doesn't become pitted. Blessings, Louise
Nov 14, 2008 | Regal Ware 426473 Black Satin Coffee Urn...
Regal Ware (RW58230R) 30-Cup Coffee Maker Logo
458 people viewed this question
Top Regal Ware Coffee Makers & Espresso Machines Experts
Tom Chichester
ray gallant
Are you a Regal Ware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
