Question about Whirlpool Heating & Cooling
I have model#ace124xro it will not cut on. Can it be repaired or should I just get another one?
What happens when you have a Mitsubishi HD 1080 model number w3-65311 when you turn it on and the green light cuts on but it cuts right back off
There is a repair kit for this model and it is usually caused by failure of the convergence circuit. Replacement parts and instruction kit can be found below and costs around $70
Google for model number and repair kit and you'll find it.
Feb 09, 2015 | Mitsubishi Televison & Video
Cuts off when heated up
Its the way the carburettor works..You have not named the model and brand, but I suspect the choke is staying on after it warms up. This is an easy fix but needs to go to small repair shop
Mar 18, 2014 | Garden
My EWave Microwave cuts off before time is done.
you have problem with a) power diode b) high voltage capacitor short, c) Magnetron defective.
you must consult to qualified tech for repair. or go to some repair shop TV for fix it.
God bless you
Jul 10, 2012 | Microwave Ovens
I cut the RCA model F31672ET off and now I get nothing. It simply does not cut on. Before I cut it off the picture was getting very dark and I could not control the sound. Family members say it's not...
It sounds like your power supply board has gone out. This is a fairly common issue, and the repair will cost you around 175-300 dollars at a repair shop.
Mar 19, 2011 | Televison & Video
STIHL TS760 cut off saw repair manual needed
Hello. Found the link for downloads, they also have contact info should your model not be online. http://www.stihlusa.com/information/info_product2.html
Hope this helped.
Mar 18, 2011 | Stihl Ts 510 760 Cut Off Saw Repair...
Power Cord was damaged in transit. Replace or Repair? Replace-How
You can only try to repair the section where they cut short and re-unite each with its respective color tape and you put him ready
Feb 05, 2010 | Exercise & Fitness
Power just cut off - like a circuit breaker or fuse blew
Yes, there is a fuse. But there are also other protective devices to shut the oven down if other parts fail. The oven's 8 years old, you say, so you would be better off just to replace it than to start trying to repair it. Microwaves are dangerous to work on, and basic countertop models are so cheap there's no point in paying for a repair (or even buying repair parts if you figure out what's wrong).
May 06, 2009 | Microwave Ovens
Heating & Cooling Logo
76 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
