Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
How do i change inverter - HP Pavilion F1503 15" LCD Flat Panel Monitor
Lg inverter 2400btub..timer light 4blinks and returns to power light. This process repeated.
Change the inverter board if you are sure that the screen is ok . you can look for another tft lamp or led strip to test your inverter since u did not specify may be led or tft inverte ,if it light correctly then prepare to change your screen back light ,if not u change your inverter
Jun 26, 2015 | LG Televison & Video
Ow do i fix error 59
If you are talking about error code 59 then the error is E.HybC.
E.HybC means that the feedback card on the inverter has been changed.
You must confirm the change at parameter ec.0 or ec.10. The inverter reads the value from the feedback card so all you have to do it hit enter to confirm the value.
If you have not changed the feedback card but the error continues to come back then there is a problem with the feedback card or the control card.
Aug 20, 2014 | Inverter KEB COMBIVERT F5
Took lg plasma tv off wall when i put it back there is a fine vertical line which changes colour
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP IN SOLVING THE PROBLEM.....
Aug 09, 2011 | LG 42PC3RA 42 in. HD-Ready Plasma TV
Toshiba tw56x81 has audio but no video. Picture comes on sporadically then goes off for hours.
Most likely an inverter fault, some capacitors on the board have buldged or done dry dueto the heat these tv's produce. Id see about getting the inverter changed or trying to tackle changing the capacitors on the inverter board.
Aug 22, 2010 | Televison & Video
TV picture not available.
Hope this help....
Jun 21, 2010 | Vizio L37 Television
Keb inverter and lenze inverter
I would have to say that you will not be able to swap the KEB inverters with the Lenze inverters or the Lenze inverters with the KEB inverters.
The PLC ProfiBus system would most likely need to be re-programmed for the change.
Mar 11, 2010 | Inverter KEB COMBIVERT F5
I have an aspire 1711 SMI, who doesn't work properly since several months. The display was starting to fall down and now there's no diplay at all, completely black. Now, when I start the notebook, the...
Hi
This is a common problem. The problem is the inverter. I changed mine OK. Actually I changed the inverter once and the whole LCD screen twice! Now happy with working 1711.
two inverters here on ebay
http://cgi.ebay.com/ACER-Aspire-1700-1710-LCD-INVERTER-1702-1711-1712-1714_W0QQitemZ150404840875QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item2304d3bdab
http://cgi.ebay.com/Acer-Aspire-1700-1710-lcd-inverter_W0QQitemZ150404836278QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item2304d3abb6
search this massive thread and you will find instructions on fitting the inverter.
http://www.notebookforums.com/thread19756.html
Cheers
Oct 05, 2009 | Acer Aspire 1710 Notebook
I changed the inverted in my toshiba satellite
Sounds like the screen itself is bad or possibly the plug is bad to the inverter or motherboard.The videocard sounds like its ok.
Oct 03, 2009 | Toshiba Satellite M45-S331 Notebook
Inverter won't charge
check if the inverter has a fuse for the charger, if it does test it if it is still ok if not change it
Mar 09, 2009 | Xantrex Technology Heart Freedom 20 12...
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
96 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
