Question about Echo Garden
Engine starts right up but head won't spin --it's not tangled with debris
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Its ounds that if the head will not spin the drive shaft is not connecting to tthe head Not good take head of and see if drive shaft can be pulled out
Posted on Jul 31, 2010
Husqvarna trimmer starts but head doesn't spin, made a high squelling sound but continued to cut, the next time I went to start it the cord pulled quickly then caught started turned briefly then quit while...
Make sure there is not debris stopping the head. Try removing the trimmer head and make sure the shaft turns freely. If it does the problem could be either the engine or clutch.
Jun 25, 2014 | Husqvarna 28cc Gas Line Trimmer
I over heated,the serpentine belt snapped. Opened the hood to find steam rapidly coming out of both the antifreeze and out of the engine right by the head gasket. It wasn't smoke not blue or black jus
Perform a compression test on your cylinders. One unfortunate result of overheating is the blown head gasket. Without compression your motor will not run. Tester are not super expensive or some stores will lend tools.
Jul 09, 2013 | Cars & Trucks
1993 Subaru loyale no compression, have spark at the coil just won't start
The engine can't run without compression in the cylinders. The plug will still spark, but without a compressed air/fuel mixture to burn and power the cylinder down, the starter will just keep spinning the engine over, cranking forever and not starting.
Check if your timing belts are good and not broke. Cylinder compression is dependent on good piston rings, intake and exhaust valves that open and close at right times and that seal good when closed, and a head gasket that seals up the cylinder from leaks where compression could blow into the water passages, or oil passages, or to outside of engine.
If the timing belts are good, a leak-down test of each cylinder will pinpoint where compression is lost.
Good luck with the Sube, great cars, great engines, but the head gaskets are a common problem.
Jun 11, 2013 | Cars & Trucks
My dc28 main brush won't spin even though there is nothing tangled
Hi Kevin,
I'm sorry to hear you're having difficulty with your DC28's brushbar. We should be able to help but we'd need to discuss this with you directly.
Please give our Helpline a call on 1-866-693-9766 - alternatively, if you email us at askdysonUS@dyson.com, someone will be in touch as soon as possible to provide assistance.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jun 17, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
The pull cord will not pull to start the trimmer
i had a problem like this on an old mower, the cord had become tangled inside the unit, it limited the pull of the cable so it would now spin the engine enough to start. it is not too difficult to to pop the top off the unit and check for tangles or knots
Apr 05, 2012 | Garden
Troy-bilt tb539e head wont spin starts, and idles great but I cant get the head to spin
Since this is a split-boom machine, disassembly and inspection will be required. This unit has basically, 2 drive shafts and a clutch (up near the engine at the end of the engine's crankshaft). There is a drive shaft in the upper boom and one in the lower boom. Either the clutch or one of the drive shafts has malfunctioned.The string head SHOULD NOT spin with the engine idling. There is a centrifugal clutch that engages when the engine reaches a certain speed, in turn, it turns the upper drive shaft.
First, check the string head area for tangled string, wire, line or debris around the center shaft. Long grass can end up wrapped around that area and severely affect movement. Dissasemble the head and inspect. Make sure you can turn the string head by hand. If so, good/
To inpect lower drive shaft, just uncouple it from the upper one. Grasp the end of the driveshaft and turn it. Does it feel OK? Does the string head turn when you turn the drive? If not, you at least have a problem in the lower boom. If all is well, then proceed to inspect the upper boom.
Unscrew the main (uppper) boom from the front of the engine. If you can remove it out of the clutch drum and off then you will be able to inspect it. If the throttle cable and/or wires from the STOP switch are restricting you, you will need to remove the throttle cable from the engine's carburetor and try to get some slack in the switch wires. Those wires go to the ignition coil module under the engine cover.
When you have the upper boom off and can access the drive shaft, turn it to check it. Make sure the other end of it turns. If both drive shafts check out OK, then the clutch will need to be inspected. Post back if needed.
Oct 26, 2010 | Troy Garden
How do i put threed into the bobbin and keep it from not getting tangled?
Is it getting tangled while you're spooling the bobbin on the top right corner of the Singer 1507 machine? If this is the case, you have to pull the thread through the top tiny hole in the bobbin, and hold on to the thread end. Then click the bobbin to the right to lock it in place, power up your machine. Keep holding the thread as you begin spooling the bobbin. Let go of the thread once the bobbin starts to spin a few rounds and the thread should not get tangled.
Sep 29, 2010 | Singer 1507
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
The pull gets stuck halfway up. Feels like it's tangled inside where the cord retracts. Is that possible?
It's possible it could be tangled, but more than likely you just need to oil the drive shaft. Dirt and debris and grass can get caught up in there and keep the shaft from spinning and the blade from turning.
If you turn your mower over and apply some oil or WD-40 on the shaft where it disappears into the body of the mower, then spin the blade (carefully!) and shoot some more oil in, the blade should begin to turn easier, and that should take care of your problem.
May 15, 2010 | Poulan Pro " Pro" Self Propelled Mower
Garden Logo
334 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
