Question about Bosch 18 in. SRS56L08 Logixx Slim-Line Built-in Dishwasher
Logixx dishwasher tablet door will not open in use
    Scholar:
  • 59 Answers
The wax plunger is most likely the culprit. Take off the door liner and the wax plunger is a little brown shaped device at the back of the dispenser . get a new one and replace the old one. make sure the dispenser door moves freely first though. it could be gunked up with soap residue.
Posted on Aug 01, 2010
Seriel PAA41010 dishwasher does not dissolve tablets
Tablets dissolve in the water, normally by the drawer opening and the tablet falling out into the wash. Is the door sticking (tablet door not loading door) or is the wash arm not spinning freely or blocked? These can interfere with the cycle
Nov 02, 2017 | Dishwashers
Bosch Logixx won't start - Stuck on "Close the door" even though door is closed.
Open the door, look along the top stainless on the door and you should find the ENr number (model number) etched into the stainless, may need to give it a wipe and look at an angle to read it. Post the ENr and that should help with diagnosis.
Mar 15, 2013 | Bosch 24 in. SGS69L02 Logixx Built-in...
My Bosch logixx dishwasher is sticking on 1 minute at end of cycle; the dishes will be clean but still wet rather than dry.
100% add the jet dry until it is completetly filled then close the dispenser door and lower then raise the door.repeat this at least three times then check and fill if you can still add more. then after doing that b4 you start the machine run the hot water to get the right temp. when the water is hot enough then start the machine.
Mar 03, 2010 | Bosch 24 in. SGS09L12 Logixx Free-standing...
Bosch logixx dishwasher draining constantly even with door open
there is a leak . when the unit stays in drain mode that means there is water at the bottom of the base. The float switch stays in drain mode untill the water is removed. you must take off the side panel to remove the water,let me know what happens.:)
Nov 08, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
Dishwasher opens tablet door but tablet is not used
are these self desolving tablets with covered in plastic film?  If they are use another brand of tablet, or turn the heat up on your water heater as it is set too low.
Had the same problem
Mar 15, 2009 | Dishwashers
When door opens dishwaher does not switch off.
Hi siphoxolo,
I'm Harvey the Master Plumber.
Your problem is: Normaly when you open the door the machine should switch off - the pump constantly pumps. You have checked the water inlet etc no problems there.
Sounds like a bad door switch. It's in the top of the door panel. You have to take the door apart to replace it. Not a job for the average homeowner. You might consider the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 06, 2008 | Bosch 24 in. SGS65L02 Logixx Built-in...
Dishwasher tablet not releasing
sounds like the dispenser solenoid is faulty you will need to replace the whole unit, this involves removing the door panel.
Jun 08, 2007 | Indesit 24 in. DE73 Evolution...
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Jul 02, 2006 | Hoover 24 in. DT999 Free-Standing...
Bosch 18 in. SRS56L08 Logixx Slim-Line Built-in Dishwasher Logo
173 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
